查看: 2569|回复: 1
不欺人,复制就能用 stm8 stvd驱动a4988驱动
ID:205182 发表于 2020-5-9 01:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* MAIN.C file
* Copyright (c) 2002-2005 STMicroelectronics
#include <stm8s105k4.h>  //驱动A4988
#define u8     unsigned char
#define u16    unsigned short
#define u32    unsigned long
#define v8     unsigned int
void delay_ms(v8 ms);
void delay_us(u8 t);
u8 key_scan(void);
void GPIO_Init(void);
void TIM1_Init(void);
u8 num;
int DIR;
main()
        CLK_SWCR =0x02;
        CLK_SWR =0xb4;
        GPIO_Init();
        TIM1_Init();
        _asm("rim");
        delay_ms(20);
        while (1)
                u8 i;
                i=key_scan();
         if(i==1)
                        PD_ODR|=0x08;
                        i==0;
                        PD_ODR&=0xf7;
        v8 x,y;
        for(x=ms;x>0;x--)
                for(y=300;y>0;y--)
void delay_us(u8 t)
        u8 m = t;
        while(m--);
void GPIO_Init()
        PD_DDR |=0x04; //PD2 为输出引脚 1   STEP
        PD_CR1 |=0x04; //PD2 为推挽输出 1
        PD_CR2 |=0x04; //PD2 为10MHZ速率1
  PD_ODR &=0xfb; //PD2 为step输出 0
        PD_DDR |=0x08;  //PD3 为输出引脚 1   DIR
        PD_CR1 |=0x08;  //PD3 为推挽输出 1
        PD_CR2 &=0xf7;  //PD3 为2MHZ速率 0
        PD_DDR &=0xcf;  //PD4,5 为输入引脚        0
  PD_CR1 |=0x30;  //PD4,5 为若上拉输入模式  1
  PD_CR2 &=0xcf;        //PD4,5 关外部中断        0
        TIM1_CR1 =0x80;         // TIM1寄存器由预装载寄存器缓冲
        TIM1_PSCRH =0x00;       //预分频F(CK_CNT)=F(CK_PSC)/(PSCR[15:0]+1)
        TIM1_PSCRL =0x9f;        //159+1==160, 100khz
        TIM1_IER=0x01;       //中断使能
        TIM1_ARRH =125/256;        //自动重装载计数器125
        TIM1_ARRL=125%256;
        TIM1_CR1|=0x01;     //TIM1寄存器CEN位为1
u8 key_scan()
          u8 i;int c;
          i=PD_IDR;
          i&=0x30;
          if(i==0x20)
                        delay_ms(10);
                        if(i ==0x20)
                        c==0;
                        return 1;
   if(i ==0x10)
                 delay_ms(10);
                 if(i ==0x10)
                   c==1;   //正
                 return 0;
@far @interrupt void TIM1_UPD_OVF_HandledInterrupt(void)//中断
        PD_ODR^=0x04;
       TIM1_SR1&=0xfe;
/*        BASIC INTERRUPT VECTOR TABLE FOR STM8 devices
*        Copyright (c) 2007 STMicroelectronics
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
        unsigned char interrupt_instruction;
        interrupt_handler_t interrupt_handler;
@far @interrupt void NonHandledInterrupt (void)
        /* in order to detect unexpected events during development,
           it is recommended to set a breakpoint on the following instruction
        return;
extern void _stext();     /* startup routine */
extern @far @interrupt void TIM1_UPD_OVF_HandledInterrupt(void);
struct interrupt_vector const _vectab[] = {
        {0x82, (interrupt_handler_t)_stext}, /* reset */
        {0x82, NonHandledInterrupt}, /* trap  */
        {0x82, NonHandledInterrupt}, /* irq0  */
        {0x82, NonHandledInterrupt}, /* irq1  */
        {0x82, NonHandledInterrupt}, /* irq2  */
        {0x82, NonHandledInterrupt}, /* irq3  */
        {0x82, NonHandledInterrupt}, /* irq4  */
        {0x82, NonHandledInterrupt}, /* irq5  */
        {0x82, NonHandledInterrupt}, /* irq6  */
        {0x82, NonHandledInterrupt}, /* irq7  */
        {0x82, NonHandledInterrupt}, /* irq8  */
        {0x82, NonHandledInterrupt}, /* irq9  */
        {0x82, NonHandledInterrupt}, /* irq10 */
        {0x82, TIM1_UPD_OVF_HandledInterrupt}, /* irq11 */
        {0x82, NonHandledInterrupt}, /* irq12 */
        {0x82, NonHandledInterrupt}, /* irq13 */
        {0x82, NonHandledInterrupt}, /* irq14 */
        {0x82, NonHandledInterrupt}, /* irq15 */
        {0x82, NonHandledInterrupt}, /* irq16 */
        {0x82, NonHandledInterrupt}, /* irq17 */
        {0x82, NonHandledInterrupt}, /* irq18 */
        {0x82, NonHandledInterrupt}, /* irq19 */
        {0x82, NonHandledInterrupt}, /* irq20 */
        {0x82, NonHandledInterrupt}, /* irq21 */
        {0x82, NonHandledInterrupt}, /* irq22 */
        {0x82, NonHandledInterrupt}, /* irq23 */
        {0x82, NonHandledInterrupt}, /* irq24 */
        {0x82, NonHandledInterrupt}, /* irq25 */
        {0x82, NonHandledInterrupt}, /* irq26 */
        {0x82, NonHandledInterrupt}, /* irq27 */
        {0x82, NonHandledInterrupt}, /* irq28 */
        {0x82, NonHandledInterrupt}, /* irq29 */
ID:205182 发表于 2020-5-9 01:13 | 只看该作者
谢谢管理员提醒,发帖只为与大家交流,不为积分。
大的化小,准备给小孩做个玩具。慢慢来。ad什么以后奉上。说明很详细了。
