基于单片机的温度控制系统资料水温控制系统
1.采用液晶显示当前温度值,温度上限和温度下限;
2.采用DS18B20温度传感器测温;
3.按键可以设置报警值,当温度超过设定的上限或低于下限(显示比例:32%,双击查同时相应的继电器吸合
4.加键和减键。可设置上下限温度控制范围;
5.温度测量范围0到99.9摄氏度,精度为0.1摄氏度;
- #include<reg52.h>
- #include"1602.h"
- #include"ds18b20.h"
- #define uint unsigned int
- #define uchar unsigned char
- sbit speaker=P1^5; //定义蜂鸣器
- sbit red=P2^0; //定义报警灯
- //sbit green=P2^1;
- sbit key1=P3^0; //定义温度按键
- sbit key2=P3^1; //定义时间按键
- uint tem; //定义采集温度
- int htem,time; //定义温度、时间
- int cnt1=1,cnt2=1; //定义计数变量
- int min,i;
- uchar mode=0; //定义模式变量
- uchar code t3[]={"high temp: C"};
- uchar code t4[]={"time: MIN"};
- //延时函数
- void delay1(uint i)
- while(i--);
- //显示函数1
- void display(uint dat,uchar add)
- uchar bai,shi ,ge;
- bai=dat/100;
- shi=dat%100/10;
- ge=dat%10;
- writelcd_cmd(add);
- writelcd_dat(bai+0x30);
- writelcd_dat(shi+0x30);
- writelcd_cmd(add+3);
- writelcd_dat(ge+0x30);
- //显示函数2
- void display2(uint dat,uchar add)
- uchar bai,shi ;
- bai=dat/100;
- shi=dat%100/10;
- //ge=dat%10;
- //writelcd_dat(ge+0x30);
- //显示函数3
- void display3(uint dat,uchar add)
- uchar ge;
- //bai=dat/100;
- //shi=dat%100/10;
- ge=dat%10;
- //writelcd_dat(shi+0x30);
- //writelcd_dat(bai+0x30);
- //writelcd_cmd(add+3);
- //按键扫描函数
- void keyscan()
- { uchar i,j;
- writelcd_cmd(0x80);
- for(i=0;i<16;i++)
- {writelcd_dat(t3[i]);}
- writelcd_cmd(0xc0);
- for(j=0;j<16;j++)
- {writelcd_dat(t4[j]);}
- while(mode!=0)
- display2(htem,0x8b);
- display3(time,0xca);
- while(mode!=0)
- switch(mode)
- case 1:writelcd_cmd(0xc0+10);writelcd_cmd(0x0f);break;
- case 2:writelcd_cmd(0x80+11);writelcd_cmd(0x0f);break;
- default:mode=0;break;
- if(key1==0&&mode==1)
- delay(50);
- if(key1==0)
- cnt1++;
- while(key1==0);
- switch(cnt1%10)
- case 1:time=1;min=1000;display3(time,0xca);writelcd_cmd(0xca+11);break; //1分钟
- case 2:time=2;min=2000;display3(time,0xca);writelcd_cmd(0xca+11);break; //2分钟
- case 3:time=3;min=3000;display3(time,0xca);writelcd_cmd(0xca+11);break; //3分钟
- case 4:time=4;min=4000;display3(time,0xca);writelcd_cmd(0xca+11);break; //4分钟
- case 5:time=5;min=5000;display3(time,0xca);writelcd_cmd(0xca+11);break; //5分钟
- case 6:time=6;min=6000;display3(time,0xca);writelcd_cmd(0xca+11);break; //6分钟
- case 7:time=7;min=7000;display3(time,0xca);writelcd_cmd(0xca+11);break; //7分钟
- case 8:time=8;min=8000;display3(time,0xca);writelcd_cmd(0xca+11);break; //8分钟
- case 9:time=9;min=9000;display3(time,0xca);writelcd_cmd(0xca+11);break; //9分钟
- default:break;
- if(key2==0&&mode==2)
- delay(10);
- if(key2==0)
- cnt2++;
- while(key2==0);
- switch(cnt2%4)
- case 1:htem=20;display2(htem,0x8b);writelcd_cmd(0x80+11);break; //20摄氏度
- case 2:htem=50;display2(htem,0x8b);writelcd_cmd(0x80+11);break; //50摄氏度
- case 3:htem=80;display2(htem,0x8b);writelcd_cmd(0x80+11);break; //80摄氏度
- default:break;
- lcd_init();
- //中断初始化函数
- void init()
- lcd_init(); //lcd初始化
- speaker=1;
- red=0;
- mode=0;
- htem=20;
- time=1;
- EA=1; //总中断开启
- EX0=1; //外部中断0允许
- ET0=1; //定时器0允许
- TMOD=0X01; //定时中断0,模式1
- IT0=1; //下降沿触发
- TH0=0Xee; //0.5us
- TL0=0X00;
- //TR0=0;
- //主函数
- void main()
- red=0;
- init(); //中断初始化
- while(1)
- if(mode!=0)
- {keyscan();}
- else if(mode==0)
- delay(100);
- tmpchange();
- tem=tmp(); //温度值获取
- if(tem>=(htem*10)) //高于设定温度
- TR0=1; //中断开启
- red=1; //报警灯亮
- else //低于设定温度
- TR0=0; //中断关闭
- red=0; //报警灯灭
- delay(10);
- display(tem,0xca);
- delay(100);
- TR0=0;
- //外部中断服务函数
- void exter()interrupt 0
- delay(50); //按键消抖
- if(P3^2==0)
- mode++;
- mode=mode%4 ; //每按4次置0
- //定时中断服务函数
- void timer0()interrupt 1
- TH0=0Xee; //重装载
- TL0=0X00;
- min--;
- if(min<=0) //计时时间到
- red=1; //报警灯闪烁
- delay(200);
- speaker=~speaker;delay1(1); //蜂鸣器报警
- TR0=0; //定时中断关闭
所有资料51hei提供下载(求大神指点,如何加入pid啊):
PID温度控制.zip
(126.37 KB, 下载次数: 294)
