标题:
uIP网络开发学习资料和源码
[打印本页]
作者:
asdfasf
时间:
2020-5-28 10:44
标题:
uIP网络开发学习资料和源码
(8.04 KB, 下载次数: 45)
下载附件
2020-5-28 13:35 上传
(255.31 KB, 下载次数: 16)
下载附件
2023-3-7 19:05 上传
#define DEBUG_PRINTF(...) /*printf(__VA_ARGS__)*/
#include "uip.h"
#include "uipopt.h"
#include "uip_arch.h"
#if UIP_CONF_IPV6
#include "uip-neighbor.h"
#endif /* UIP_CONF_IPV6 */
#include <string.h>
/* Variable definitions. */
/* The IP address of this host. If it is defined to be fixed (by
setting UIP_FIXEDADDR to 1 in uipopt.h), the address is set
here. Otherwise, the address */
#if UIP_FIXEDADDR > 0
const uip_ipaddr_t uip_hostaddr =
{HTONS((UIP_IPADDR0 << 8) | UIP_IPADDR1),
HTONS((UIP_IPADDR2 << 8) | UIP_IPADDR3)};
const uip_ipaddr_t uip_draddr =
{HTONS((UIP_DRIPADDR0 << 8) | UIP_DRIPADDR1),
HTONS((UIP_DRIPADDR2 << 8) | UIP_DRIPADDR3)};
const uip_ipaddr_t uip_netmask =
{HTONS((UIP_NETMASK0 << 8) | UIP_NETMASK1),
HTONS((UIP_NETMASK2 << 8) | UIP_NETMASK3)};
#else
uip_ipaddr_t uip_hostaddr, uip_draddr, uip_netmask;
#endif /* UIP_FIXEDADDR */
static const uip_ipaddr_t all_ones_addr =
#if UIP_CONF_IPV6
{0xffff,0xffff,0xffff,0xffff,0xffff,0xffff,0xffff,0xffff};
#else /* UIP_CONF_IPV6 */
{0xffff,0xffff};
static const uip_ipaddr_t all_zeroes_addr =
#if UIP_CONF_IPV6
{0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000};
{0x0000,0x0000};
#if UIP_FIXEDETHADDR
const struct uip_eth_addr uip_ethaddr = {{UIP_ETHADDR0,
UIP_ETHADDR1,
UIP_ETHADDR2,
UIP_ETHADDR3,
UIP_ETHADDR4,
UIP_ETHADDR5}};
#else
struct uip_eth_addr uip_ethaddr = {{0,0,0,0,0,0}};
#endif
#ifndef UIP_CONF_EXTERNAL_BUFFER
u8_t uip_buf[UIP_BUFSIZE + 2]; /* The packet buffer that contains
incoming packets. */
#endif /* UIP_CONF_EXTERNAL_BUFFER */
void *uip_appdata; /* The uip_appdata pointer points to
application data. */
void *uip_sappdata; /* The uip_appdata pointer points to
the application data which is to
be sent. */
#if UIP_URGDATA > 0
void *uip_urgdata; /* The uip_urgdata pointer points to
urgent data (out-of-band data), if
present. */
u16_t uip_urglen, uip_surglen;
#endif /* UIP_URGDATA > 0 */
u16_t uip_len, uip_slen;
/* The uip_len is either 8 or 16 bits,
depending on the maximum packet
size. */
u8_t uip_flags; /* The uip_flags variable is used for
communication between the TCP/IP stack
and the application program. */
struct uip_conn *uip_conn; /* uip_conn always points to the current
connection. */
struct uip_conn uip_conns[UIP_CONNS];
/* The uip_conns array holds all TCP
connections. */
u16_t uip_listenports[UIP_LISTENPORTS];
/* The uip_listenports list all currently
listning ports. */
#if UIP_UDP
struct uip_udp_conn *uip_udp_conn;
struct uip_udp_conn uip_udp_conns[UIP_UDP_CONNS];
#endif /* UIP_UDP */
static u16_t ipid; /* Ths ipid variable is an increasing
number that is used for the IP ID
field. */
void uip_setipid(u16_t id) { ipid = id; }
static u8_t iss[4]; /* The iss variable is used for the TCP
initial sequence number. */
#if UIP_ACTIVE_OPEN
static u16_t lastport; /* Keeps track of the last port used for
a new connection. */
#endif /* UIP_ACTIVE_OPEN */
/* Temporary variables. */
u8_t uip_acc32[4];
static u8_t c, opt;
static u16_t tmp16;
/* Structures and definitions. */
#define TCP_FIN 0x01
#define TCP_SYN 0x02
#define TCP_RST 0x04
#define TCP_PSH 0x08
#define TCP_ACK 0x10
#define TCP_URG 0x20
#define TCP_CTL 0x3f
#define TCP_OPT_END 0 /* End of TCP options list */
#define TCP_OPT_NOOP 1 /* "No-operation" TCP option */
#define TCP_OPT_MSS 2 /* Maximum segment size TCP option */
#define TCP_OPT_MSS_LEN 4 /* Length of TCP MSS option. */
#define ICMP_ECHO_REPLY 0
#define ICMP_ECHO 8
#define ICMP6_ECHO_REPLY 129
#define ICMP6_ECHO 128
#define ICMP6_NEIGHBOR_SOLICITATION 135
#define ICMP6_NEIGHBOR_ADVERTISEMENT 136
#define ICMP6_FLAG_S (1 << 6)
#define ICMP6_OPTION_SOURCE_LINK_ADDRESS 1
#define ICMP6_OPTION_TARGET_LINK_ADDRESS 2
/* Macros. */
#define BUF ((struct uip_tcpip_hdr *)&uip_buf[UIP_LLH_LEN])
#define FBUF ((struct uip_tcpip_hdr *)&uip_reassbuf[0])
#define ICMPBUF ((struct uip_icmpip_hdr *)&uip_buf[UIP_LLH_LEN])
#define UDPBUF ((struct uip_udpip_hdr *)&uip_buf[UIP_LLH_LEN])
#if UIP_STATISTICS == 1
struct uip_stats uip_stat;
#define UIP_STAT(s) s
#else
#define UIP_STAT(s)
#endif /* UIP_STATISTICS == 1 */
#if UIP_LOGGING == 1
#include <stdio.h>
void uip_log(char *msg);
#define UIP_LOG(m) uip_log(m)
#else
#define UIP_LOG(m)
#endif /* UIP_LOGGING == 1 */
#if ! UIP_ARCH_ADD32
void
uip_add32(u8_t *op32, u16_t op16)
uip_acc32[3] = op32[3] + (op16 & 0xff);
uip_acc32[2] = op32[2] + (op16 >> 8);
uip_acc32[1] = op32[1];
uip_acc32[0] = op32[0];
if(uip_acc32[2] < (op16 >> 8)) {
++uip_acc32[1];
if(uip_acc32[1] == 0) {
++uip_acc32[0];
if(uip_acc32[3] < (op16 & 0xff)) {
++uip_acc32[2];
if(uip_acc32[2] == 0) {
++uip_acc32[1];
++uip_acc32[0];
#endif /* UIP_ARCH_ADD32 */
#if ! UIP_ARCH_CHKSUM
static u16_t
chksum(u16_t sum, const u8_t *data, u16_t len)
u16_t t;
const u8_t *dataptr;
const u8_t *last_byte;
dataptr = data;
last_byte = data + len - 1;
while(dataptr < last_byte) { /* At least two more bytes */
t = (dataptr[0] << 8) + dataptr[1];
sum += t;
if(sum < t) {
sum++; /* carry */
dataptr += 2;
if(dataptr == last_byte) {
t = (dataptr[0] << 8) + 0;
sum += t;
if(sum < t) {
sum++; /* carry */
/* Return sum in host byte order. */
return sum;
u16_t
uip_chksum(u16_t *data, u16_t len)
return htons(chksum(0, (u8_t *)data, len));
uIP学习资料.7z
(3.73 MB, 下载次数: 23)
2020-5-28 13:35 上传
点击文件名下载附件
下载积分: 黑币 -5
欢迎光临 (http://www.51hei.com/bbs/)
Powered by Discuz! X3.1
