查看: 4074|回复: 6
STM32蜂鸣器模拟播放歌曲--《世间美好与你环环相扣》《生日歌》
ID:763998 发表于 2020-6-7 01:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*函数名:BEEP_Init
*功  能:蜂鸣器初始化
*参  数:无
*返  回:无
*备  注:
引脚          点蜂鸣器电平                模式                                                速度
PC3                        高电平                                        通用推挽输出                50M
void BEEP_Init(void)
   #if 1
   RCC->APB2ENR |= 1<<4;//开启PC口时钟
   GPIOC->CRL &=~(0XF<<4*3);//清PC3
   GPIOC->CRL |=(0X3<<4*3);//通用推挽输出 50M
   GPIOC->ODR &=~(3<<1);//关蜂鸣器
   #else
    GPIO_InitTypeDef  GPIO_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能C端口时钟
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //通用推挽输出
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//速度50MHz
    GPIO_Init(GPIOC, &GPIO_InitStructure);//PC3
    GPIO_ResetBits(GPIOC,GPIO_Pin_3);//关蜂鸣器
   #endif
//控制发声
void Sound(u16 frq)
        u32 time;
        if(frq != 1000)//休止符
                time = 500000/((u32)frq);
                BEEP = 1;
                delay_us(time);
                BEEP = 0;
                delay_us(time);
        }else
                delay_us(1000);
//生日歌
void play_Music_1(void)
        //音谱         低1  2   3   4   5   6   7  中1  2   3   4   5   6   7  高1    2   3     4    5    6    7  不发音
        uc16 tone[] = {262,294,330,349,392,440,494,523,587,659,698,784,880,988,1047,1175,1319,1397,1568,1760,1967,1000};//音频数据表
        //编号          0   1   2   3   4   5   6   7   8   9   10  11  12  13  14   15   16    17   18   19   20  21
        //音谱
        u8 music[]={4,4,5,4,
                                                        7,6,21,
                                                        4,4,5,4,
                                                  8,7,21,
                                                        4,4,11,9,
                                                        7,6,5,21,
                                                        3,3,9,7,
                                                        8,7,21,
        //节拍
        u8 time[] = {2,2,4,4,        //时间--2代表半拍(100ms) 4代表一拍(200ms) 8代表两拍(400ms)
                                                         4,4,4,
                                                         2,2,4,4,
                                                         4,4,4,
                                                         2,2,4,4,
                                                         4,4,4,4,
                                                         2,2,4,4,
                                                         4,4,4,
        u32 delayShow;
        u16 i,j;
        delayShow = 10;//控制播放快慢
        for(i=0;i<sizeof(music)/sizeof(music[0]);i++)//放歌
                for(j=0;j<((u16)time[i])*tone[music[i]]/delayShow;j++)
                        Sound((u32)tone[music[i]]);
//世间美好与你环环相扣
void play_Music_2(void)
        //             低1  2   3   4   5   6   7  中1  2   3   4   5   6   7  高1    2   3     4    5    6    7  不发音
        //              0   1   2   3   4   5   6   7   8   9   10  11  12  13  14   15   16    17   18   19   20  21
        //音调
        u8 music[]={11,11,11,10,9,9,8,8,7,8,
                                                        9,9,11,11,9,8,8,9,9,
                                                        7,7,7,7,7,9,9,9,8,8,8,7,8,
                                                        9,9,9,11,8,21,
                                                        11,11,11,11,10,9,8,7,8,
                                                        9,9,11,11,9,8,8,7,7,
                                                        9,11,11,21,21,9,
                                                        8,21,21,4,5,4,
                                                        9,9,12,9,10,9,9,7,8,9,8,8,7,7,
                                                        7,7,9,7,8,7,7,5,6,7,6,6,
                                                        9,9,9,4,5,4,
                                                        9,9,9,9,11,9,9,7,8,9,8,8,7,7,
                                                        7,7,9,9,9,7,5,6,6,7,6,6,
                                                        5,7,8,8,7,7,8,8,9,8,
                                                        7,7,7,21,21
        //节拍
        u8 time[] = {2,2,2,1,1,2,2,2,1,1,        //时间--2代表半拍(100ms) 4代表一拍(200ms) 8代表两拍(400ms)
                                                         1,2,1,2,1,1,2,2,4,
                                                        1,1,1,1,2,1,1,2,2,1,1,1,1,
                                                        3,1,2,2,4,4,
                                                        1,2,1,2,1,1,6,1,1,
                                                        1,2,1,2,1,1,2,2,4,
                                                        2,2,4,4,2,2,
                                                        4,4,2,2,2,2,
                                                        1,1,1,1,1,1,1,1,1,2,1,2,1,1,
                                                        1,1,1,1,1,1,1,1,2,1,1,4,
                                                        3,1,6,2,2,2,
                                                        1,1,1,1,1,1,1,1,2,1,1,2,1,1,
                                                        2,1,1,2,2,2,1,1,2,2,
                                                        2,2,4,4,4,
        u32 delayShow;
        u16 i,j;
        delayShow = 7;//播放速度
未使用到用定时器、PWM,也能实现播放歌曲.....
收藏收藏7 分享淘帖 顶 踩
ID:15020 发表于 2020-6-7 09:24 | 只看该作者
抽个时间试验一下
ID:753333 发表于 2020-7-11 21:19 | 只看该作者
BEEP怎么定义的
ID:299497 发表于 2020-7-14 10:19 | 只看该作者
蜂鸣器一直响,但是我这个怎么听不出来是乐曲,是delay_us参数设置的有问题?
ID:763998 发表于 2020-7-16 11:38 | 只看该作者
看我写的这篇文章---》有全部程序
文章名称:《父亲节》STM32蜂鸣器实现筷子兄弟的<父亲> 附源程序
文章链接:http://www.51hei.com/bbs/dpj-190970-1.html
看我写的这篇文章---》有全部程序
ID:475858 发表于 2021-3-23 15:01 | 只看该作者
学习一下电子琴
