#include<stc15.h>
/*共阴数码管编码*/
unsigned char code tab1[]={
0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f};
/*位选编码*/
unsigned char code tab2[]={
0xfe,0xfd,0xfb,0xf7,
0xef,0xdf,0xbf,0x7f};
unsigned char dis_buf[8]={0,0,0x40,0,0,0x40,0,0};
sbit duanxuan=P1^0;
/*按键位定义*/
sbit key0=P1^0;
sbit key1=P1^1;
sbit key2=P1^2;
sbit key3=P1^3;
sbit key4=P1^4;
sbit key5=P1^5;
sbit key6=P1^6;
sbit key7=P1^7;
/*秒、分、时的初始化*/
unsigned int tt=0;
unsigned char i=0;
char sec=0,fen=0,shi=12;
unsigned int sign=1;
/*延时函数*/
void delay(unsigned int n)
while(n--);
/*定时器0初始化函数*/
void chushihua() //1毫秒@12.000MHz
AUXR &= 0x7F; //定时器时钟12T模式
TMOD &= 0xF0; //设置定时器16位自动重载模式
TL0 = 0x18; //设置定时初值
TH0 = 0xFC; //设置定时初值
TR0 = 1; //定时器0开始计时
EA=1;
ET0=1;
/*按键设定函数*/
void sheding()
if(key0==0)
delay(3500);
if(key0==0)
sign=0;
if(key1==0)
delay(3500);
if(key1==0)
sec++;
if(sec>59)
sec=0;
while(!key1);
if(key2==0)
delay(3500);
if(key2==0)
fen++;
if(fen>59)
fen=0;
while(!key2);
if(key3==0)
delay(3500);
if(key3==0)
shi++;
if(shi>23)
shi=0;
while(!key3);
if(key5==0)
delay(3500);
if(key5==0)
sec--;
if(sec<0)
sec=59;
while(!key5);
if(key6==0)
delay(3500);
if(key6==0)
fen--;
if(fen<0)
fen=59;
while(!key6);
if(key7==0)
delay(3500);
if(key7==0)
shi--;
if(shi<0)
shi=23;
while(!key7);
if(key4==0)
delay(3500);
if(key4==0)
sign=1;
/*显示函数*/
void display()
P7=tab2[0];
P6=tab1[sec%10];
delay(3500);
P6=0x00;//消影
P7=tab2[1];
P6=tab1[sec/10];
delay(3500);
P6=0x00;//消影
P7=tab2[2];
P6=0x40;
delay(3500);
P6=0x00;//消影
P7=tab2[3];
P6=tab1[fen%10];
delay(3500);
P6=0x00;//消影
P7=tab2[4];
P6=tab1[fen/10];
delay(3500);
P6=0x00;//消影
P7=tab2[5];
P6=0x40;
delay(3500);
P6=0x00;//消影
P7=tab2[6];
P6=tab1[shi%10];
delay(3500);
P6=0x00;//消影
P7=tab2[7];
P6=tab1[shi/10];
delay(3500);
P6=0x00;//消影
/*主函数*/
void main(void)
chushihua();
sheding();
display();
/*定时器0中断函数*/
void time0() interrupt 1
if(sign)
tt++;
if(tt>=1000)
tt=0;
sec++;
if(sec>=60)
sec=0;
fen++;
if(fen>=60)
fen=0;
shi++;
if(shi>=24)
shi=0;
