查看: 2146|回复: 1
8253、8255、8259中断控制器实验汇编代码+原理图
ID:801368 发表于 2020-7-12 07:48 | 显示全部楼层 |阅读模式
;代码如下
DATA    SEGMENT                             ;数据段
    MESS   DB    'PRESS ANY KEY TO EXIT',0AH,0DH,'$'
    TAB  DB   3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH,77H,7CH,39H,5EH,79H,71H,76H
    INT_SEG    DW    ?
    INT_OFF    DW    ?
    INTSOR     DB     ?
    FLA  DB  0
DATA    ENDS
STACK    SEGMENT                           ;堆栈段
    STA    DW    512    DUP(?)
STACK    ENDS
CODE    SEGMENT                             ;代码段
    ASSUME    CS:CODE,DS:DATA,SS:STACK
START:MOV    AX,DATA
    MOV    DS,AX
    MOV    AX,STACK
    MOV    SS,AX
    MOV    SP,SIZE STA
    MOV    CL,0
    MOV    DX,0283H                           8253和8255的初始化
    MOV    AL,36H
    OUT    DX,AL
    MOV    DX,0280H                          ;8253初始化
    MOV    AL,0E8H
    OUT    DX,AL
    MOV    AL,03H
    OUT    DX,AL
    MOV    DX,0283H
    MOV    AL,76H
    OUT    DX,AL
    MOV    DX,0281H
    MOV    AL,0E8H
    OUT    DX,AL
    MOV    AL,03H
    OUT    DX,AL
    MOV    DX,028BH                          ;8255初始化
    MOV    AL,90H
    OUT    DX,AL
    MOV AL,0BH
    MOV AH,35H                                ;取该中断向量
    INT 21H
    MOV INT_SEG,ES                        ;保存向量段基址
    MOV INT_OFF,BX                        ;保存向量偏移量
    CLI                                                ;修改向量前关中断
    PUSH DS
;填写中断向量表
    MOV AX,SEG INT_PR
    MOV DS,AX
    MOV DX,OFFSET INT_PR
    MOV AL,0BH
    MOV AH,25H
    INT 21H
    IN  AL,21H
    MOV INTSOR,AL                          ;保护原中断屏蔽字
    AND AL,0F7H                              ;开放中断请求
    OUT 21H,AL                                 ;开中断
    POP    DS
    STI
    LEA    DX,MESS
    MOV    AH,09H
    INT    21H
    STI
LOOPA:
    HLT
    MOV    AH,01H
    INT    16H
    JZ     LOOPA
    CLI
    MOV    AX,INT_SEG
    MOV    DS,AX                            ;DS指向向量段基址
    MOV    DX,INT_OFF                   ;DX指向向量偏移量
    MOV    AL,0BH
    MOV    AH,25H                          ;恢复中断向量
    INT    21H
    MOV    AL,INTSOR                    ;恢复原中断屏蔽字
    OUT    21H,AL
    STI
  ;中断子程序
INT_PR   PROC
    PUSH DS
    STI
    MOV DX,0288H
    IN  AL,DX
    CMP AL,0FH
    JA LOP1                                    ;大于0fh跳转至lop1
    MOV BX, OFFSET  TAB            ;display 低四位
    XLAT                                         ;查表
    JMP LOP3
LOP1:    CMP FLA,0
         JNZ LOP2
         MOV AL,76H                       ;数码管置为 'H'
         MOV DX,0289H
         OUT DX,AL
         INC FLA
         JMP LOP4
LOP2:    MOV CL,4                          ;display 高四位
         SHR AL,CL
         MOV BX,OFFSET TAB
         XLAT                                       ;查表
         MOV DX,0289H
         OUT DX,AL
         DEC FLA
         JMP LOP4
LOP3:    MOV DX,0289H
         OUT DX,AL
LOP4:    CLI
         POP DS
         MOV AL,20H
         OUT 20H,AL
         STI                                           ;开中断
         IRET
INT_PR   ENDP
CODE     ENDS
         END START
电路图如下
ID:328014 发表于 2020-7-12 13:11 | 显示全部楼层
楼主你好 能分享一下Proteus仿真工程文件吗?
