查看: 2205|回复: 4
求助 单片机+max7219级联第三片出现鬼影、残影
打算用max7219驱动点阵显示时钟,但是在max7219驱动中出现问题:
  问题描述:第一片和第二片显示正常,第三篇出现残影,仔细观察第三片的残影是第一片的数据。
检查过硬件和软件,硬件应该没有问题,就三根数据线,芯片为stc15w408as的IO口直连接动三片max7219级联,max7219驱动部分程序如下,请各位前辈不腻赐教!
#define  _max7219_C
#include "max7219.h"
#include "main.h"
#include "DS3231.h"
#include "DS18B20.h"
#include <intrins.h>
/************************************************************************************************/uchar code disp1[10][8]={
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
{0x10,0x18,0x14,0x10,0x10,0x10,0x10,0x10},//1
{0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
{0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
{0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},//4
{0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0},//5
{0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0},//6
{0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8},//7
{0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
{0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E},//9
/*n毫秒的延时程序*/
void Delay_xms(uint x)
uint i,j;
for(i=0;i<x;i++)
  for(j=0;j<112;j++);
//向MAX7219写入字节
void Write_Max7219_byte(uchar DATA)
            uchar i;
                Max7219_pinCS=0;                                //CS=0有效,CS=1锁存
            for(i=8;i>=1;i--)
            Max7219_pinCLK=0;
            Max7219_pinDIN=DATA&0x80;//&10000000, 编译器对位操作的理解:非0即为1
            DATA=DATA<<1;
            Max7219_pinCLK=1;        //上升沿把数据送出去
/*向M第一片MAX7219写入数据*/
void Write_Max7219_1(uchar add1,uchar dat1)
   Max7219_pinCS=0;
         Write_Max7219_byte(add1);           //写入地址,即数码管编号
   Write_Max7219_byte(dat1);          //写入数据,即数码管显示数字
        Max7219_pinCS=1;
/*第二片MAX7219的写入数据*/
void Write_Max7219_2(uchar add2,uchar dat2)
        Max7219_pinCS=0;
        Write_Max7219_byte(add2);
        Write_Max7219_byte(dat2);
        Max7219_pinCLK=1;
        Write_Max7219_byte(0x00);  //片1写入空
        Max7219_pinCS=1;
/*第三片MAX7219的写入数据*/
void Write_Max7219_3(uchar add3,uchar dat3)
        Max7219_pinCS=0;
        Write_Max7219_byte(add3);
        Write_Max7219_byte(dat3);
        Max7219_pinCLK=1;
        Write_Max7219_byte(0x00);//片1写入空
//        _nop_();_nop_();
        Write_Max7219_byte(0x00); //片2写入空
//                Max7219_pinCLK=1;
        Max7219_pinCS=1;
/*初始化芯片*/
void Init_MAX7219(void)
Write_Max7219_1(0x09, 0x00);       //译码方式:BCD码
Write_Max7219_1(0x0a, 0x00);       //亮度
Write_Max7219_1(0x0b, 0x07);       //扫描界限;8个数码管显示
Write_Max7219_1(0x0c, 0x01);       //掉电模式:0,普通模式:1
Write_Max7219_1(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
Write_Max7219_2(0x09, 0x00);       //译码方式:BCD码
Write_Max7219_2(0x0a, 0x00);       //亮度
Write_Max7219_2(0x0b, 0x07);       //扫描界限;8个数码管显示
Write_Max7219_2(0x0c, 0x01);       //掉电模式:0,普通模式:1
Write_Max7219_2(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
Write_Max7219_3(0x09, 0x00);       //译码方式:BCD码
Write_Max7219_3(0x0a, 0x00);       //亮度
Write_Max7219_3(0x0b, 0x07);       //扫描界限;8个数码管显示
Write_Max7219_3(0x0c, 0x01);       //掉电模式:0,普通模式:1
Write_Max7219_3(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
/**********************显示程序**************************/
void dis(void)
unsigned char i,k,l,m;
DS3231_Read_time();//读时间
  l=RTC_Data[0]/10;//秒
  k=RTC_Data[0]%10;//秒
  m=RTC_Data[1]%10;//分
   for(i=1;i<9;i++)//i是数字
  Write_Max7219_1(i,disp1[k][i-1]);
        Write_Max7219_2(i,disp1[l][i-1]);
        Write_Max7219_3(i,disp1[m][i-1]);
/**********************主程序**************************/
void main ()
Delay_xms(1000);
Delay_xms(1000);
  dis();        //显示函数
ID:258542 发表于 2020-7-12 21:14 | 只看该作者
ID:739545 发表于 2020-7-13 13:18 | 只看该作者
鬼影残影的主要原因就是PWM的分配问题,显示频占比,改变占比时间就行了,或者有漏电流,换个led
ID:258542 发表于 2020-7-16 21:55 | 只看该作者
这个是max7219芯片自带的动态扫描,单片机只管给7219显示数据 ,无需pwm配置。  问题是第二片显示清晰,但是第三片会出现鬼影,不知为何?
ID:917386 发表于 2021-6-26 13:44 来自手机 | 只看该作者
绊脚石13 发表于 2020-7-16 21:55
这个是max7219芯片自带的动态扫描,单片机只管给7219显示数据 ,无需pwm配置。  问题是第二片显示清晰, ...
请问解决了吗,同样的问题,拜托赐教
