查看: 2164|回复: 0
BASCOM-AVR 驱动数码管简洁代码
  1. ''''''''''''''''''''''  BASCOM-AVR 驱动一个数码管显示数字 0-9 下载附件查看原理图 代码 实物照片 ''''''''''''''''''''''''''''''''''''''''''''''''''''''''
  2. $regfile = "m16def.dat"                                     'ATMega16 单片机
  3. $crystal = 8000000                                          '8兆赫晶振
  4. Dim I As Byte
  5. 'PORTB 8个引脚PB0-PB7连接了数码管 A B C D E F G H
  6. Config Porta = Output
  7. Config Portb = Output
  8. Porta.0 = 1                                                 '第1位数码管不亮
  9. Porta.1 = 1
  10. Porta.2 = 1
  11. Porta.3 = 0                                                 '第4个数码管亮
  12. '====================
  13. '数码管显示0-9,1秒钟切换1次
  14. Do
  15.    Wait 1
  16.    I = I + 1
  17.    If I >= 10 Then I = 0
  18.    If I = 0 Then Portb = &HC0
  19.    If I = 1 Then Portb = &HF9
  20.    If I = 2 Then Portb = &HA4
  21.    If I = 3 Then Portb = &HB0
  22.    If I = 4 Then Portb = &H99
  23.    If I = 5 Then Portb = &H92
  24.    If I = 6 Then Portb = &H82
  25.    If I = 7 Then Portb = &HF8
  26.    If I = 8 Then Portb = &H80
  27.    If I = 9 Then Portb = &H90
  28. Loop
BASCOM-AVR驱动数码管代码+原理图+实物图片
BASCOM-AVR单个数码管显示.rar
4.25 MB, 下载次数: 4, 下载积分: 黑币 -5
