查看: 1788|回复: 0
第六届蓝桥杯决赛-智能物料传送系统单片机源程序
ID:492026 发表于 2020-7-25 17:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一、注意点
程序已经上传;
有漏洞欢迎私聊指教,一起进步
二、主函数:
#include<STC15F2K60S2.H>
#include "intrins.h"
#include "iic.h"
#define uint unsigned int
#define somenop {_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_(); _nop_();}
sbit TX = P1^0;  //发射引脚
sbit RX = P1^1;  //接收引脚
uchar code tab[]={0XC0,0XF9,0XA4,0XB0,0X99,0X92,0X82,0XF8,0X80,0X90,0XBF,0XFF};
uchar yi,er,san,si,wu ,liu,qi,ba;
bit flag_S5,flag_S4,flag_led;
uchar zhuangtai,dianya,huowu_lei,flag_S6,S7_choose;
uint tt,aa;
uchar huowu_1,huowu_2,huowu_time1,huowu_time2;
unsigned int intr = 0;
bit s_flag;
unsigned int distance;
unsigned int t = 0;
void send_wave(void);
void Timer0Init(void)        ;
void Timer1Init(void);
void flash_led();
void dianya_panduan();
void delayms(int ms);
void allinit();
void mode_1();
void mode_2();
void mode_3();
void chaosheng();
void display1(uchar yi,uchar er);
void display2(uchar san,uchar si);
void display3(uchar wu,uchar liu);
void display4(uchar qi,uchar ba);
void keyscan();
void tingzhi_led();
        Timer0Init();
  Timer1Init();
        EA = 1;
        ET0 = 1;  //打开定时器0中断
        allinit();
        yi=11;er=11;san=11;si=11;wu=11;liu=11;qi=11;ba=11;
        if(EEPROM_read(0x40)!=20)
                EEPROM_write(0x40,20);
                delayms(2);
                EEPROM_write(0x55,2);
                delayms(2);
                EEPROM_write(0x56,4);
                delayms(2);
        huowu_1=EEPROM_read(0x55);
        delayms(2);
        huowu_2=EEPROM_read(0x56);
        delayms(2);
        huowu_time1=huowu_1;
        huowu_time2=huowu_2;
                keyscan();
                dianya=AD_read(0x03);
                dianya_panduan();
                //数据处理
    chaosheng();
                tingzhi_led();
                mode_1();
                mode_2();
                mode_3();
                display1(yi,er);
                display2(san,si);
                display3(wu,liu);
                display4(qi,ba);
                EEPROM_write(0x55,huowu_1);
                delayms(2);
                EEPROM_write(0x56,huowu_2);
                delayms(2);
void mode_3()
        if((S7_choose==2)|(S7_choose==1))
        yi=3;er=11;san=11;
        si=huowu_1/10;wu=huowu_1%10;
        liu=11;
        qi=huowu_2/10;ba=huowu_2%10;}
        else if(S7_choose==3){yi=11;er=11;san=11;si=11;wu=11;liu=11;qi=11;ba=11;S7_choose=0;}
void chaosheng()
        if(s_flag) // 200毫秒更新一次数据
                s_flag = 0;
                send_wave();  //发送方波信号
                TR1 = 1;  //启动计时
                while((RX == 1) && (TF1 == 0)) //等待收到脉冲
                        if((TH1==0x80)|(TH1==0xA0))
                                display1(yi,er);
                                display2(san,si);
                                display3(wu,liu);
                                display4(qi,ba);
                TR1 = 0;  //关闭计时
                if(TF1 == 1)//发生溢出
                        TF1 = 0;
                        distance = 99;  //无返回
                        t = TH1;// 计算时间
                        t <<= 8;
                        t |= TL1;
                        distance = (unsigned int)(t*0.017);  //计算距离
                        distance = distance/12;
                        //t*340   // t/1000000*340/2*100
                TH1 = 0;
                TL1 = 0;
        if(distance<=30) huowu_lei=1;
        else if(distance>30) huowu_lei=2;
        if(zhuangtai==3) {flash_led();}
        if((dianya>0)&&(dianya<51))
        {if(S7_choose==0){P2=0x80;P0=0xfe;yi=11;er=11;san=11;si=11;wu=11;liu=11;qi=11;ba=11;}zhuangtai=1;}
        else if((dianya>=51)&&(dianya<204))
        {zhuangtai=2;
         if(!flag_S5){P2=0x80;P0=0xfd;}}
        else if(dianya==0)
        {P2=0x80;P0=0xff;yi=11;er=11;san=11;si=11;wu=11;liu=11;qi=11;ba=11;zhuangtai=1;}
        else if(dianya>=204)
        {zhuangtai=3;}
void mode_1()
        if(zhuangtai!=1)
        {yi=1;er=11;san=11;si=distance/10;wu=distance%10;liu=11;qi=11;ba=huowu_lei;}
void mode_2()
        if((zhuangtai==2)&&(flag_S4==1))
        yi=2;er=11;san=11;si=11;wu=11;liu=11;
        if(huowu_lei==1){qi=huowu_time1/10;ba=huowu_time1%10;}
        else if(huowu_lei==2){qi=huowu_time2/10;ba=huowu_time2%10;}
void flash_led()
        if(flag_led){P2=0x80;P0=0xfb;}
        else if(!flag_led){P2=0x80;P0=0xff;}
void tingzhi_led()
        if(flag_S5)
  if(flag_led){P2=0x80;P0=0xf7;}
void Timer0Init(void)                //2毫秒@11.0592MHz
        AUXR |= 0x80;                //定时器时钟1T模式
        TMOD &= 0xF0;                //设置定时器模式
        TL0 = 0x9A;                //设置定时初值
        TH0 = 0xA9;                //设置定时初值
        TF0 = 0;                //清除TF0标志
        TR0 = 1;                //定时器0开始计时
void Timer1Init(void)                //2毫秒@11.0592MHz
        AUXR |= 0x40;                //定时器时钟1T模式
        TMOD &= 0x0F;                //设置定时器模式
//定时器0中断服务函数
void isr_timer_0(void)  interrupt 1  //默认中断优先级 1
        if(++intr == 100)
                s_flag = 1;
                intr = 0;
        tt++;
        if(tt==250)
        {tt=0;flag_led=~flag_led;}
        aa++;
        if(aa==1000)
        {aa=0;
         if((flag_S4==1)&&(flag_S5==0))
                P2=0xa0;P0=0x10;
         if(huowu_lei==1){huowu_time1--;if(huowu_time1==0){huowu_time1=0;flag_S4=0;        P2=0xa0;P0=0x00;}}
         else if(huowu_lei==2){huowu_time2--;if(huowu_time2==0){huowu_time2=0;flag_S4=0;        P2=0xa0;P0=0x00;}}
        if(flag_S5){P2=0xa0;P0=0x00;}
//TX引脚发送40KHz方波信号驱动超声波发送探头
//使用软件延时注意RC振荡器频率
        unsigned char i = 8;  //发送8个脉冲
        do
                TX = 1;
                somenop;somenop;somenop;somenop;somenop;somenop;somenop;somenop;somenop;somenop;
                TX = 0;
        while(i--);
        int i,j;
        for(i=ms;i>0;i--)
                for(j=845;j>0;j--);
void allinit()
        P2=0XA0;
        P0=0X00;//关闭蜂鸣器,继电器
        P2=0X80;
        P0=0XFF;//关闭LED灯
        P2=0XC0;
        P0=0XFF;//选择所有数码管
        P2=0XFF;
        P0=0XFF;//关闭所有数码管
                P2=0XC0;//打开位选573   U8
                P0=0X01;//选择第一个数码管
                P2=0XFF;//打开段选573   U7
                P0=tab[yi];
                delayms(1);
                P0=0X02;//选择第二个数码管
                P0=tab[er];
                delayms(1);
                P0=0X04;//选择第三个数码管
                P0=tab[san];
                delayms(1);
                P0=0X08;//选择第四个数码管
                P0=tab[si];
                delayms(1);
                P0=0X10;//选择第一个数码管
                P0=tab[wu];
                delayms(1);
                P0=0X20;//选择第一个数码管
                P0=tab[liu];
                delayms(1);
                P0=0X40;//选择第一个数码管
                P0=tab[qi];
                delayms(1);
                P0=0X80;//选择第一个数码管
                P0=tab[ba];
                delayms(1);
void keyscan()
        if(P30==0)
                delayms(5);
                if(!P30)
                        if(S7_choose==1)
                        {huowu_1++;if(huowu_1==11){huowu_1=0;}}
                        else if(S7_choose==2)
                        {huowu_2++;if(huowu_2==11){huowu_2=0;}}
                while(!P30);
        if(P31==0)
                delayms(5);
                if(!P31)
                        if(zhuangtai==1)
                                if(flag_S6==0){flag_S6=1;S7_choose=1;}
                                else if(flag_S6==1){flag_S6=2;S7_choose=2;}
                                else if(flag_S6==2){flag_S6=0;S7_choose=3;}
                while(!P31);
        if(P32==0)
                delayms(5);
                if(!P32)
                        if(flag_S4==1) flag_S5=~flag_S5;
                while(!P32);
        if(P33==0)
                delayms(5);
                if(!P33)
                        if(zhuangtai==2) {flag_S4=1;aa=990;huowu_time1=huowu_1;huowu_time2=huowu_2;}
                        else if((zhuangtai==1)|(zhuangtai==3)) flag_S4=0;
                while(!P33);
智能物料传送系统.zip
71.19 KB, 下载次数: 23, 下载积分: 黑币 -5
第六届蓝桥杯.pdf
338.43 KB, 下载次数: 17, 下载积分: 黑币 -5
收藏收藏1 分享淘帖 顶 踩
