查看: 1493|回复: 3
单片机程序应该加入什么关于蜂鸣器的代码可以让它实现闹铃的功能
ID:812792 发表于 2020-8-11 15:15 | 显示全部楼层 |阅读模式
这个是51单片机电子日历并且可以显示温度的DS1302时钟+12864LCD显示,现在想要给这个程序通过加入一个蜂鸣器以让它实现在特定时间发出声音的功能,也就是一个闹铃的功能,菜鸡请问大家应该加入什么样的代码可以让它实现这样的功能呢?
单片机显示时间(可调整)(DS1302时钟 12864LCD显示).docx
54.14 KB, 下载次数: 3
ID:812792 发表于 2020-8-11 15:17 | 显示全部楼层
/*        带温度显示的电子日历                */
#include<reg51.h>
#include<intrins.h>
#include<string.h>
#define uint unsigned int
sbit DQ=P2^7;
sbit CS1=P2^1;    //定义选择芯片左半屏信号
sbit CS2=P2^2;    //定义选择芯片右半屏信号
sbit DI=P2^5;     //定义选择显示类型
sbit RW=P2^4;     //定义读写信号
sbit E=P2^3;      //定义数据锁存信号
sbit IO=P1^0;          //DS1302数据线
sbit CLK=P1^1;          //DS1302时钟线
sbit RST=P1^2;          //DS1302复位线
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
uchar Time_Buffer[7]; //日期缓存,0-6依次为秒、分、时、日、月、周日、年
uint Temp,Temp1;
bit Temp_Flag;
uchar s1num;
uchar flag_year=0,flag_moon=0,flag_day=0,flag_hour=0,flag_min=0,flag_sec=0,flag_week=0;
uchar tempa;
uchar t0_num;
void delayms(uint xms);
void Write_1302(uchar addr,uchar dat);
void keyscan();
void time_adj();
/*--年,月,日,星期,时,分,秒,汉字点阵(16*16)--*/
uchar code Date_Time_Words[]=
0x40,0x20,0x10,0x0C,0xE3,0x22,0x22,0x22,0xFE,0x22,0x22,0x22,0x22,0x02,0x00,0x00,//年
0x04,0x04,0x04,0x04,0x07,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x00,
0x00,0x00,0x00,0x00,0x00,0xFF,0x11,0x11,0x11,0x11,0x11,0xFF,0x00,0x00,0x00,0x00,//月
0x00,0x40,0x20,0x10,0x0C,0x03,0x01,0x01,0x01,0x21,0x41,0x3F,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,0x00,0x00,//日
0x00,0x00,0x00,0x3F,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xBE,0x2A,0x2A,0x2A,0xEA,0x2A,0x2A,0x2A,0x2A,0x3E,0x00,0x00,0x00,//星
0x00,0x48,0x46,0x41,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x49,0x49,0x41,0x40,0x00,
0x00,0x04,0xFF,0x54,0x54,0x54,0xFF,0x04,0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00,//期
0x42,0x22,0x1B,0x02,0x02,0x0A,0x33,0x62,0x18,0x07,0x02,0x22,0x42,0x3F,0x00,0x00,
0x00,0xFC,0x44,0x44,0x44,0xFC,0x10,0x90,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x00,//时
0x00,0x07,0x04,0x04,0x04,0x07,0x00,0x00,0x03,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,
0x80,0x40,0x20,0x98,0x87,0x82,0x80,0x80,0x83,0x84,0x98,0x30,0x60,0xC0,0x40,0x00,//分
0x00,0x80,0x40,0x20,0x10,0x0F,0x00,0x00,0x20,0x40,0x3F,0x00,0x00,0x00,0x00,0x00,
0x12,0x12,0xD2,0xFE,0x91,0x11,0xC0,0x38,0x10,0x00,0xFF,0x00,0x08,0x10,0x60,0x00,//秒
0x04,0x03,0x00,0xFF,0x00,0x83,0x80,0x40,0x40,0x20,0x23,0x10,0x08,0x04,0x03,0x00
//星期几的汉字点阵
uchar code Weekday_Words[]=
0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xC0,0x80,0x00,//一
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x00,//二
0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x18,0x10,0x00,
0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x04,0x00,0x00,//三
0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
0x00,0xFE,0x02,0x02,0x02,0xFE,0x02,0x02,0xFE,0x02,0x02,0x02,0x02,0xFE,0x00,0x00,//四
0x00,0x7F,0x28,0x24,0x23,0x20,0x20,0x20,0x21,0x22,0x22,0x22,0x22,0x7F,0x00,0x00,
0x00,0x02,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0xC2,0x82,0x02,0x00,0x00,0x00,//五
0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x30,0x20,0x00,
0x10,0x10,0x10,0x10,0x10,0x91,0x12,0x1E,0x94,0x10,0x10,0x10,0x10,0x10,0x10,0x00,//六
0x00,0x40,0x20,0x10,0x0C,0x03,0x01,0x00,0x00,0x01,0x02,0x0C,0x78,0x30,0x00,0x00
//温度显示汉字点阵
uchar code Templt[]=
0x10,0x22,0x64,0x0C,0x80,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0xFF,0x02,0x00,0x00,//温
0x04,0x04,0xFE,0x01,0x40,0x7E,0x42,0x42,0x7E,0x42,0x7E,0x42,0x42,0x7E,0x40,0x00,
0x00,0x00,0xFC,0x24,0x24,0x24,0xFC,0xA5,0xA6,0xA4,0xFC,0x24,0x34,0x26,0x04,0x00,//度
0x40,0x20,0x9F,0x80,0x42,0x42,0x26,0x2A,0x12,0x2A,0x26,0x42,0x40,0xC0,0x40,0x00,
0x00,0x00,0x00,0x00,0x80,0xC0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//:
0x00,0x00,0x00,0x00,0x31,0x7B,0x7B,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x02,0x05,0xE2,0x18,0x04,0x02,0x02,0x02,0x02,0x02,0x02,0x04,0x1E,0x00,0x00,//℃
0x00,0x00,0x00,0x07,0x18,0x20,0x40,0x40,0x40,0x40,0x40,0x40,0x20,0x18,0x00,0x00
//半角数字点阵
uchar code Digits[]=
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//0
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//1
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//2
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//3
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//4
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//5
0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//6
0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//7
0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//8
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//9
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//.
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00        //' '
/*--屏幕显示--*/
void left()//左半屏显示
CS1=1;
CS2=0;
void right()//右半屏显示
CS1=0;
CS2=1;
/*--判断LCD是否繁忙--*/
void LCD_Check_Busy()
do
E=0;
DI=0;
RW=1;
P0=0xff;
E=1;
_nop_();
E=0;
while(P0&0x80);//P0.7口
/*--向LCD发送命令--*/
void LCD_Write_Command(uchar c)
        LCD_Check_Busy();
        P0=0xFF ;
RW=0;
DI=0;
        P0=c ;
        E=1;
E=0;
/*--向LCD发送数据--*/
void LCD_Write_Date(uchar d)
        LCD_Check_Busy();
        P0=0xFF ;
RW=0;
DI=1;
E=1;
_nop_();
        P0=d ;
        E=0;
_nop_();
/*--设置初始页--*/
void page_first(uchar p)
uchar i=p;
p=i|0xb8;
LCD_Check_Busy();
        LCD_Write_Command(p);
/*--设置初始列--*/
void col_first(uchar c)
        uchar i=c;
        c=i|0x40;
        LCD_Check_Busy();
        LCD_Write_Command(c);
/*--任意位置显示汉字--*/
void Display_Word(uchar page,uchar col,uchar*s)
        uchar i,j;
        page_first(page);//上半部
        col_first(col);
        for(i=0;i<16;i++)
                LCD_Write_Date(*s);
s++;
        page_first(page+1);//下半部
        col_first(col);
        for(j=0;j<16;j++)
                LCD_Write_Date(*s);
                s++;
/*--任意位置显示字符--*/
void Display_Char(uchar page,uchar col,uchar*s)
        uchar i,j;
        col_first(col);
        for(i=0;i<8;i++)
                LCD_Write_Date(*s);
s++;
        col_first(col);
        for(j=0;j<8;j++)
                LCD_Write_Date(*s);
                s++;
/*--初始化LCD --*/
void LCD_initialize()
        CS1=1;
    CS2=1;
        LCD_Write_Command(0x38); //8位形式,2行字符
        LCD_Write_Command(0x0F); //开显示
        LCD_Write_Command(0x01); //清屏
        LCD_Write_Command(0x06); //画面不动光标右移
        LCD_Write_Command(0xC0);//设置起始行
/*--向DS1302写入一字节--*/
void Write_A_Byte_To_1302(uchar x)
        uchar i;
        for(i=0;i<8;i++)
                 IO=x&0x01; CLK=1;CLK=0;x>>=1;
/*--从DS1302读取一字节--*/
uchar Receive_A_Byte_From_1302()
        uchar i,b=0x00;
        for(i=0;i<8;i++)
                 b |= _crol_((uchar)IO,i);
                CLK=1;CLK=0;
        return b/16*10+b%16;
/*--从DS1302指定位置读数据--*/
uchar Read_1302(uchar addr)
        uchar dat;
        RST = 0;CLK=0;RST=1;
           Write_A_Byte_To_1302(addr);
        dat = Receive_A_Byte_From_1302();
           CLK=1;RST=0;
        return dat;
/*--向DS1302某地址写入数据--*/
         CLK=0; RST=0;
         Write_A_Byte_To_1302(dat);
         CLK=0;RST=0;
/*--读取当前日期时间--*/
void Get_Time()
        uchar i;
        for(i=0;i<7;i++)
                Time_Buffer[i]=Read_1302(0x81+2*i);
/*--定时器0每秒刷新LCD显示--*/
void T0_INT() interrupt 1
        TH0=(65536-50000)/256;
           TL0=(65536-50000)%256;
        t0_num++;
    left();//显示左半屏
        if(flag_year==0)
          Display_Char(0,16,Digits+ Time_Buffer [6]/10*16);//显示年的十位数,占8列
          Display_Char(0,24,Digits+ Time_Buffer [6]%10*16); //显示年的个位数,占8列
          if(t0_num<=5)
          if(t0_num>5&&t0_num<=10)
                if(t0_num==10)t0_num=0;
                Display_Char(0,16,Digits+ Digits[11]/10*16);//显示年的十位数,占8列
            Display_Char(0,24,Digits+ Digits[11]%10*16); //显示年的个位数,占8列
        Display_Char(0,48,Digits+ Time_Buffer [4]/10*16); //显示月的十位数,占8列
        Display_Char(0,56,Digits+ Time_Buffer [4]%10*16); //显示月的个位数,占8列
        right();//显示右半屏
        Display_Char(0,80,Digits+ Time_Buffer [3]/10*16); //显示日的十位数,占8列
        Display_Char(0,88,Digits+ Time_Buffer [3]%10*16); //显示日的个位数,占8列
        left();//显示左半屏
        Display_Char(2,16,Digits+ Time_Buffer [2]/10*16); //显示时的十位数,占8列
        Display_Char(2,24,Digits+ Time_Buffer [2]%10*16); //显示时的个位数,占8列
        left();//显示左半屏
        Display_Char(2,48,Digits+ Time_Buffer [1]/10*16); //显示分的十位数,占8列
        Display_Char(2,56,Digits+ Time_Buffer [1]%10*16); //显示分的个位数,占8列
        right();//显示右半屏,秒显示在右半屏部分
        Display_Char(2,80,Digits+ Time_Buffer [0]/10*16); //显示秒的十位数,占8列
        Display_Char(2,88,Digits+ Time_Buffer [0]%10*16); //显示秒的个位数,占8列
        right();//显示右半屏
        Display_Word(4,64,Weekday_Words+( Time_Buffer [5]-1)*32);//显示周日,占16列
        left();//显示左半屏,温度
        Display_Char(6,48,Digits+ Temp1/100*16); //显示温度十位数,占8列
        Display_Char(6,56,Digits+ Temp1%100/10*16); //显示温度个位数,占8列
    right();//显示右半屏
        Display_Char(6,64,Digits+ 10*16); //显示温度小数点,占8列
        Display_Char(6,72,Digits+ Temp%10*16); //显示温度十分位数,占8列
/*--定时器0初始化程序--*/
void Time0_initialize()
        EA=1;//开总中断
        ET0=1;//开定时/计数器0中断
        TMOD=0x01;//设置工作方式1
        TH0=(65536-50000)/256;//放入计数初值
        TL0=(65536-50000)%256;//放入计数初值
        TR0=1;//开定时/计数器0
/*--显示固定汉字:年月日 ,星期,时分秒*/
void Display()
        left();//左半屏显示
        Display_Char(0,0,Digits+2*16);//显示2
        Display_Char(0,8,Digits);//显示0
        Display_Word(0,32,Date_Time_Words+0*32);        //"年"字的显示
        right();//右半屏显示
        Display_Word(0,64,Date_Time_Words+1*32);        //"月"字的显示
        Display_Word(0,96,Date_Time_Words+2*32);        //"日"字的显示
    left();//左半屏显示
    Display_Word(2,32,Date_Time_Words+5*32);    //"时"字的显示
        right();//右半屏显示
        Display_Word(2,64,Date_Time_Words+6*32);    //"分"字的显示
        Display_Word(2,96,Date_Time_Words+7*32);    //"秒"字的显示,秒显示在右半屏
        left();//左半屏显示
        Display_Word(4,32,Date_Time_Words+3*32);     //"星"字的显示
        Display_Word(4,48,Date_Time_Words+4*32);    //"期"字的显示
        left();//左半屏显示
    Display_Word(6,0,Templt+0*32);    //"温"字的显示
        Display_Word(6,16,Templt+1*32);    //"度"字的显示
        Display_Word(6,32,Templt+2*32);    //":"字的显示
        right();//右半屏显示
        Display_Word(6,80,Templt+3*32);     //"℃"字的显示
  uint y;
  while(xms--)for(y=110;y>0;y--);
//us级延时函数
void Delayus(uchar xus)//晶振为12MHz,延时时间为2i+5 us
        while(--xus);
//初始化DS18B20函数
bit Init_DS18B20(void)
        bit x;
        DQ=1;
        DQ=0;
        Delayus(250);
        DQ=1;
        Delayus(20);
        if(!DQ) x=0;
        else x=1;
        Delayus(250);
        DQ=1;
        return x;
//读DS18B20函数
uchar Read_DS18B20(void)
        uchar i=0,Dat=0;
        for(i=0;i<8;i++)
                DQ=1;
                DQ=0;
                Dat>>=1;
                DQ=1;
                if(DQ) Dat |= 0x80;
                DQ=1;
                Delayus(30);
        return Dat;
//写DS18B20函数
void Write_DS18B20(uchar Dat)
        uchar i=0;
        for(i=0;i<8;i++)//循环8次,写入一个字节
                DQ=1;//未发送前的状态
                Dat >>= 1;//将要传送的最低位放入CY
                DQ=0;//将总线拉低,产生写时序
                DQ=CY;//将要传送的位状态送到总线上
                Delayus(30);//延时50us,即保持总线状态,待DS18B20采样
                DQ=1;//恢复期,总线置1
//取温度函数
void GetTemp(void)//获取温度函数
        uchar a=0,b=0;
        TR0=0;//关闭定时器,防止定时器中断干扰DS18B20
        Init_DS18B20();
        Write_DS18B20(0xcc);//跳过ROM
        Write_DS18B20(0x44);//开启温度转换
        Init_DS18B20();
        Write_DS18B20(0xbe);//读暂存器
        a=Read_DS18B20();//读取高速暂存字节0,温度低8位
        b=Read_DS18B20();//读取高速暂存字节1,温度高8位
        TR0=1;//完成DS18B20读取后打开定时器
        Temp=b;
        Temp<<=8;
        Temp=Temp|a;//将高、低位温度编码合在一起
        if(b>=8)//判断温度值是否为负,如果温度高字节大于等于8说明温度值为负
                Temp=~Temp+1;//将补码转换成原码
                Temp_Flag=1;//温度标志为1,表示温度为负
                Temp_Flag=0;//温度标志为0,表示温度为正
        Temp1=Temp*0.0625*10;//将温度编码转换成温度值  放大10倍  加0.5是为了四舍五入
        TR0=1;
void keyscan()        //键盘扫描函数
   if(s1==0)
             delayms(5);
                 if(s1==0)
                     while(!s1);
                         s1num++;
                         if(s1num==1)
                              flag_year=1;
                                 //write_1602com(er+0x09); //设置按键按动一次,秒位置显示光标
                 //write_1602com(0x0f);    //设置光标为闪烁
                 tempa=(Time_Buffer[6])/10*16+(Time_Buffer[6])%10;//年数据写入DS1302
                                 Write_1302(0x8e,0x00);
                                 Write_1302(0x8c,tempa);//改写年
                                 Write_1302(0x8e,0x80);
                         if(s1num==2)
                                  flag_moon=1;
                  tempa=(Time_Buffer[4])/10*16+(Time_Buffer[4])%10;//秒数据写入DS1302
                                  Write_1302(0x88,tempa);//改写月
                         if(s1num==3)
                                  flag_day=1;
                  tempa=(Time_Buffer[3])/10*16+(Time_Buffer[3])%10;//秒数据写入DS1302
                                  Write_1302(0x86,tempa);//改写日
                         if(s1num==4)
                              flag_hour=1;
                  tempa=(Time_Buffer[2])/10*16+(Time_Buffer[2])%10;//秒数据写入DS1302
                                  Write_1302(0x84,tempa);//改写时
                         if(s1num==5)
                              flag_min=1;
                  tempa=(Time_Buffer[1])/10*16+(Time_Buffer[1])%10;//秒数据写入DS1302
                                  Write_1302(0x82,tempa);//改写分
                        if(s1num==6)
                              flag_sec=1;
                  tempa=(Time_Buffer[0])/10*16+(Time_Buffer[0])%10;//秒数据写入DS1302
                                  Write_1302(0x80,0x80|tempa);//改写秒
                        if(s1num==7)
                              flag_week=1;
                  tempa=(Time_Buffer[5])/10*16+(Time_Buffer[5])%10;//秒数据写入DS1302
                                  Write_1302(0x8a,tempa);//改写星期
                        if(s1num==8)
                             s1num=0;
                                 flag_year=0;
                                 flag_moon=0;
                                 flag_day=0;
                                 flag_hour=0;
                                 flag_min=0;
                                 flag_sec=0;
                                 flag_week=0;
                                 Write_1302(0x80,0x7f&tempa);//改写秒
void time_adj()               //走时时间调整函数
   if(s1num!=0)
           if(s2==0)
                   delayms(5);
                   if(s2==0)
                           while(!s2);
                           switch(s1num)
                                   case 1:
                                          Time_Buffer[6]++;
                                                  if(Time_Buffer[6]==100)
                                                    Time_Buffer[6]=0;
                                                  break;
                                   case 2:
                                          Time_Buffer[4]++;
                                                  if(Time_Buffer[4]==13)
                                                    Time_Buffer[4]=0;
                                                  break;
                                   case 3:
                                          Time_Buffer[3]++;
                                                  if(Time_Buffer[3]==30)
                                                    Time_Buffer[3]=0;
                                                  break;
                                   case 4:
                                          Time_Buffer[2]++;
                                                  if(Time_Buffer[2]==24)
                                                    Time_Buffer[2]=0;
                                                  break;
                                   case 5:
                                          Time_Buffer[1]++;
                                                  if(Time_Buffer[1]==60)
                                                    Time_Buffer[1]=0;
                                                  break;
                                   case 6:
                                          Time_Buffer[0]++;
                                                  if(Time_Buffer[0]==60)
                                                    Time_Buffer[0]=0;
                                                  break;
                                   case 7:
                                          Time_Buffer[5]++;
                                                  if(Time_Buffer[5]==8)
                                                    Time_Buffer[5]=1;
                                                  break;
           if(s3==0)
                   delayms(5);
                   if(s3==0)
                           while(!s3);
                           switch(s1num)
                                   case 1:
                                          Time_Buffer[6]--;
                                                  if(Time_Buffer[6]==0)
                                                    Time_Buffer[6]=99;
                                                  break;
                                   case 2:
                                          Time_Buffer[4]--;
                                                  if(Time_Buffer[4]==0)
                                                    Time_Buffer[4]=12;
                                                  break;
                                   case 3:
                                          Time_Buffer[3]++;
                                                  if(Time_Buffer[3]==0)
                                                    Time_Buffer[3]=30;
                                                  break;
                                   case 4:
                                          Time_Buffer[2]--;
                                                  if(Time_Buffer[2]==0)
                                                    Time_Buffer[2]=23;
                                                  break;
                                   case 5:
                                          Time_Buffer[1]--;
                                                  if(Time_Buffer[1]==0)
                                                    Time_Buffer[1]=59;
                                                  break;
                                   case 6:
                                          Time_Buffer[0]--;
                                                  if(Time_Buffer[0]==0)
                                                    Time_Buffer[0]=59;
                                                  break;
                                   case 7:
                                          Time_Buffer[5]--;
                                                  if(Time_Buffer[5]==0)
                                                    Time_Buffer[5]=7;
                                                  break;
/*--主程序--*/
        LCD_initialize();    //LCD初始化
        Display();           //固定显示的汉字
    Time0_initialize();  //中断初始化,在中断中显示刷新的时间
                  Get_Time();    //读取并刷新时间
                  GetTemp();
                  keyscan();
              time_adj();
                  delayms(300);
ID:654028 发表于 2020-8-12 09:25 | 显示全部楼层
读取数据和定时的时间对比,相同则打开蜂鸣器,过一定时间自动关闭或者按键关闭。我只能想到这个办法。毕竟我也是菜鸟
ID:810978 发表于 2020-8-12 10:34 | 显示全部楼层
设一个变量作为定时的时间,当时钟时间与它相同时启动蜂鸣器,最基础的方法了吧
