查看: 2279|回复: 3
ERROR L104: MULTIPLE PUBLIC DEFINITIONS
ID:816115 发表于 2020-9-1 21:05 | 显示全部楼层 |阅读模式
编译的时候出现的问题,请问怎么解决?
Build target 'Target 1'
linking...
*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
    SYMBOL:  A
    MODULE:  .\Objects\main.obj (MAIN)
    SYMBOL:  A
    MODULE:  .\Objects\lcd1602.obj (LCD1602)
    SYMBOL:  A
    MODULE:  .\Objects\key.obj (KEY)
Program Size: data=100.1 xdata=0 code=2184
Target not created.
ID:816115 发表于 2020-9-1 21:06 | 显示全部楼层
#include "reg52.h"
#include "main.h"
#include "lcd1602.h"
#include "key.h"
//#include "UART.h"
#define M 5.12
//#define N 360
//u8 A=0;
u8 G;
u8 Fre=0;
u8 n;
u8 n1;
u8 Pha;
u8 k=0;
u8 i;
u8 j;
unsigned int a[16]={0};
unsigned int b[16]={0};
u8 Frequency1[2] = "F:";
u8 Frequency[]="";
u8 Phase1[2] = "P:";
u8 Phase[] = "";
u8 line = 0;        // μ±Ç°ËùÔúDD 0->μúò»DD 1->μú¶tDD
u8 freNum = 2, phaNum=2;
// Ñóê± x oáÃë
void delay_ms(u16 xms)
        u16 x, y;
        for (x=0; x<xms; x++)
                for(y=0; y<123; y++);
void addNum(u8 num)
        if (line == 0)
                write_com(0x80+freNum);        // μúò»DD
                Frequency[freNum++] = num;
                Frequency[freNum] = 0;
                write_com(0x80+0x40+phaNum);        // μú¶tDD
                Phase[phaNum++] = num;
                Phase[phaNum] = 0;
        write_data(num);
//void jinzhi()
//         u8 i=0;
//                n=sizeof(Frequency);
//        for(i=1;i<n;i++)
//                Fre=Fre+Frequency[i]*10^(n-i);
//        n1=sizeof(Phase);
//        for(i=1;i<n;i++)
//                Pha=Pha+Phase[i]*10^(n-i);
//        A=(1000000/(Fre*M))-1;
//        //A=(int)A;
//        G=Pha/360*256;
//        //G=(int)G;
//void shiliu(Fre)
//        unsigned int a[16]={0};
//        unsigned int b[16]={0};
//                unsigned int j=0;
//                while(Fre!=0)
//                        a[j]=Fre%2;
//                        Fre/=2;
//                        j++;
//                for(j=15;j>=0;j--)
//                        b[15-j]=a[j];
//                return b[16];
//          u8 a[];
//    u8 i = 0;
//        //int j=0;
//        //int k=0;
//         while (Fre != 0)
//        a[i] = Fre % 2;
//        Fre /= 2;
//        i++;
//    for(i = 15; i >= 0; i--)
//       a[i];
unsigned int A;
int main()
        u8 key = 0;
        Init_LCD();        // 3õê¼»ˉLCD1602
        //InitUART();        // 3õê¼»ˉ′®¿ú
        write_com(0x80+0x40);        // μú¶tDD
        Puts_to_LCD1602(Phase1);
        write_com(0x80);        // μúò»DD
        Puts_to_LCD1602(Frequency1);
                //u8 i;
                key = KeyScan();
                switch(key)
                //μúò»DD¼üÖμÂë
                case 0x77:// 1
                        addNum('1');
                        break;
                case 0x7b:// 2
                        addNum('2');
                        break;
                case 0x7d:// 3
                        addNum('3');
                        break;
                case 0x7e:// è·¶¨
                        //n=sizeof(Frequency);
                  //Frequency=1000000/(Frequency*M)-1;
                  //Puts_to_SerialPort(Frequency);
                        //Putc_to_SerialPort(' ');
                        //Puts_to_SerialPort(Phase);
                        //Puts_to_SerialPort("\r\n");
                        //Fre=0;
                //for(i=3;i<n;i++)
                //Fre=Fre+Frequency[i]*10^(n-i);
                //A=(1000000/Fre/M)-1;
                //P0=(int)A;
                //G=Phase/N;
                //P0=(int)G;
                //P3=(int)A;
                //jinzhi();
                //shiliu();
                //u8 k=0;
                //unsigned int A=0;
                //u8 i;
        for(i=1;i<n;i++)
//        for(i=1;i<n;i++)
        A=((1000000/(Fre*M))-1);
        //A=(int)A;
        //G=Pha/360*256;
        //G=(int)G;
        //unsigned int a[16]={0};
        //unsigned int b[16]={0};
                while(A!=0)
                        a[j]=A%2;
                        A/=2;
                        j++;
                for(j=15;j>=0;j--)
                        b[15-j]=a[j];
                for(k=0;k<8;k++)
                        P3=b[k];
                key = KeyScan();
                while(key==0x7e)
                        for(k=8;k<16;k++)
                                P3=b[k];
                        break;
                //μú¶tDD¼üÖμÂë
                case 0xb7:// 4
                        addNum('4');
                        break;
                case 0xbb:// 5
                        addNum('5');
                        break;
                case 0xbd:// 6
                        addNum('6');
                        break;
                case 0xbe:// Çå3y
                        if (line == 0)
                                if (freNum > 2)
                                        freNum--;
                                        write_data(' ');
                                        write_com(0x10);        // 1a±ê×óòÆò»Î»
                                if (phaNum > 2)
                                        phaNum--;
                                        write_com(0x80+0x40+phaNum);        // μúò»DD
                                        write_data(' ');
                                        Phase[phaNum] = 0;
                        break;
                //μúèyDD¼üÖμÂë
                case 0xd7:// 7
                        addNum('7');
                        break;
                case 0xdb:// 8
                        addNum('8');
                        break;
                case 0xdd:// 9
                        addNum('9');
                        break;
                case 0xde:// éÏ
                        line = 1-line;
                        if (line == 0)
                                Puts_to_LCD1602(Frequency+freNum);
                                Puts_to_LCD1602(Phase+phaNum);
                        break;
                //μúËÄDD¼üÖμÂë
                case 0xe7:// .
                        n1=sizeof(Phase);
        for(i=1;i<n;i++)
             G=Pha*256/360;
                        P3=(int)G;
                        break;
                case 0xeb:// 0
                        addNum('0');
                        break;
                case 0xed://
                        break;
                case 0xee:// ÏÂ
                        line = 1-line;
                        if (line == 0)
                        break;
                case 0:
                        break;
main.c代码是这个
#ifndef __main_h__
#define __main_h__
#include <reg52.h>
#include <intrins.h>
typedef unsigned char u8;
typedef unsigned int  u16;
extern  unsigned int A=0;
void delay_ms(u16 xms);        // Ñóê± x oáÃë
#endif
main.h是这个
ID:739545 发表于 2020-9-2 10:55 | 显示全部楼层
extern  unsigned int A=0;在1602,main,key里面重复定义了。自己查下这几个.h文件
