以下是程序用的串口代码,检查了好久,是查看了很多代码,真的真不出问题所在。用串口助手发送数据后就没有数据回来过。
#define S1_S0 0x40 //P_SW1.6
#define S1_S1 0x80 //P_SW1.7
bit busy;
char temp,rec_flag = 0;
** Function name: void InitUart1(void)
** Descriptions: uart初始化
** input parameters:
** output parameters:
** Returned value:
void InitUart1(void) //9600
EA = 0;
ACC = P_SW1;
ACC &= ~(S1_S0 | S1_S1); //S1_S0=0 S1_S1=1
ACC |= S1_S1; //(P1.6/RxD_3, P1.7/TxD_3)
P_SW1 = ACC;
SCON = 0x50; //8位数据,可变波特率
AUXR |= 0x01; //串口1选择定时器2为波特率发生器
AUXR |= 0x04; //定时器2时钟为Fosc,即1T
T2L = 0xE0; //设定定时初值
T2H = 0xFE; //设定定时初值
AUXR |= 0x10; //启动定时器2
ES = 1; //中断允许
EA = 1;
** Function name: void SendData(BYTE dat)
** Descriptions: 发送字节
** Returned value:
while(busy);
busy = 1;
SBUF = dat;
** Function name: void SendString(char *s)
** Descriptions: 发送字符串
** Returned value:
while (*s) //检测字符串结束标志
SendData(*s++); //发送当前字符
** Function name: void Uart() interrupt 4
** Returned value:
if (RI)
RI = 0; //清除RI位
temp = SBUF; //数据
uart_receive_input(temp);
if (TI)
TI = 0; //清除TI位
busy = 0; //清忙标志
