查看: 2163|回复: 1
Proteus8.10 VSM Studio python编译器仿真Raspberry_系列_48_Remote_Light
一,打开文件(可以随文下载放置在文档中打开)。(如下图1所示)
图1
二,调整原理图大小,适合可视,另存工程文件。(如下图2,3,4所示)
图2
图3
图4
三,点击Source Code标签。(如下图5所示)
图5
四,编辑main.py Proteus8.10 VSM Studio python编译器仿真Raspberry_系列_48_Remote_Light (如下图6所示)
五,Main.py 代码:
# !/usr/bin/env python3
# Generated by Proteus Visual Designer for Raspberry Pi
# Modules
from goto import with_goto
from stddef import *
import var
import pio
import resource
from datetime import datetime
# Peripheral Configuration Code (Do Not Edit)
#---CONFIG_BEGIN---
import cpu
import FileStore
import VFP
import Ports
import Generic
import Controls
def peripheral_setup () :
# Peripheral Constructors
pio.cpu=cpu.CPU ()
pio.storage=FileStore.FileStore ()
pio.server=VFP.VfpServer ()
pio.uart=Ports.UART ()
pio.LED1=Generic.LED (pio.GPIO20)
pio.IotBtn1=Controls.PushButton ("IotBtn1", )
pio.IotLED1=Controls.Indicator ("IotLED1", )
pio.IotBtn2=Controls.PushButton ("IotBtn2", )
pio.storage.begin ()
pio.server.begin (0)
# Install interrupt handlers
pio.IotBtn1.attachEventHandler(chart_OnIotBtn1)
pio.IotBtn2.attachEventHandler(chart_OnIotBtn2)
def peripheral_loop () :
pass
#---CONFIG_END---
def variables_setup () :
# Flowchart Variables
pass
# Flowchart Routines
@with_goto
def chart_SETUP () :
pio.uart.setup (9600)
pio.uart.println ("Remote Light: \r\n")
return
@with_goto
def chart_LOOP () :
return
@with_goto
def chart_OnIotBtn1 () :
pio.IotLED1.setState (True)
pio.IotBtn1.setLamp (True)
pio.LED1.on ()
pio.uart.println ("Light on.")
return
@with_goto
def chart_OnIotBtn2 () :
pio.IotBtn1.setLamp (False)
pio.IotBtn2.setLamp (False)
pio.IotLED1.setState (False)
pio.uart.println ("Light off.")
return
# Main function
def main () :
# Setup
variables_setup ()
peripheral_setup ()
chart_SETUP ()
# Infinite loop
while True :
  peripheral_loop ()
  chart_LOOP ()
# Command line execution
if __name__ == '__main__' :
   main()
六,点击构建工程按钮,编译工程。(如下图6所示)
图6
七,点击窗口左下方仿真按钮,可见虚拟LED Light显示。 (如下图7,8,9所示)
图7
图8
图9
八,选择release,点击构建工程按钮,编译工程生成Hex文件。(如下图10所示)
图10
附件Proteus8.10 VSM Studio python编译器仿真Raspberry_系列_48_Remote_Light在已安装Proteus8.10的计算机文件夹中打开即可
需要进一步了解,请加入QQ群:976235464
Raspberry_48_Remote_Light01.rar
192.46 KB, 下载次数: 6, 下载积分: 黑币 -5
ID:288629 发表于 2021-2-1 13:23 | 只看该作者
谢谢楼主,下载好好学习下
