查看: 1942|回复: 0
OKdo E1开发板之按键控制LED灯
OKdo E1开发板上配置了LEDKEY,通过它们可以学习和掌握I/O口的使用方法,其原理图见图1所示。
1  LEDKEY原理图
由此我们可以获知它们与MCU的连接关系如下:
LEDR   ---PIO1_4
LEDB   ---PIO1_6
LEDG   ---PIO1_7
WAKEUP--- PIO1_18
USER   --- PIO1_9
ISP     --- PIO0_5
为此LEDKEY的初始定义如下:
LED的引脚定义:
#defineLEDR_PORT            1u
#defineLEDR_PIN              4u
#defineLEDR_FUNC            (IOCON_FUNC0 | IOCON_MODE_PULLUP |IOCON_DIGITAL_EN)
#defineLEDG_PORT            1u
#defineLEDG_PIN              7u
#defineLEDG_FUNC            (IOCON_FUNC0 | IOCON_MODE_PULLUP | IOCON_DIGITAL_EN)
#defineLEDB_PORT             1u
#defineLEDB_PIN               6u
#defineLEDB_FUNC              (IOCON_FUNC0 | IOCON_MODE_PULLUP |IOCON_DIGITAL_EN)
#defineLEDR_NUM              1u
#defineLEDG_NUM              2u
#defineLEDB_NUM              3u
KEY的引脚定义:
#defineKEY_S2_PORT    0u
#defineKEY_S2_PIN      5u
#defineKEY_S2_FUNC    (IOCON_FUNC0 |IOCON_MODE_PULLUP | IOCON_DIGITAL_EN)
#defineKEY_S3_PORT    1u
#defineKEY_S3_PIN      18u
#defineKEY_S3_FUNC    (IOCON_FUNC0 | IOCON_MODE_PULLUP| IOCON_DIGITAL_EN)
#defineKEY_S1_PORT    1u
#defineKEY_S1_PIN      9u
#defineKEY_S1_FUNC    (IOCON_FUNC0 |IOCON_MODE_PULLUP | IOCON_DIGITAL_EN)
#defineKEY2_NUM       0x02
#defineKEY3_NUM       0x01
#define KEY1_NUM       0x04
LED的初始化函数:
  1. void led_init(void)
  2. {
  3. gpio_pin_config_t   gpioPinConfig;
  4. gpioPinConfig.pinDirection = kGPIO_DigitalOutput;
  5. gpioPinConfig.outputLogic  = 1u; /* output high as default. */
  6. GPIO_PinInit (GPIO, LEDR_PORT, LEDR_PIN, &gpioPinConfig);
  7. GPIO_PinInit (GPIO, LEDG_PORT, LEDG_PIN, &gpioPinConfig);
  8. GPIO_PinInit (GPIO, LEDB_PORT, LEDB_PIN, &gpioPinConfig);
  9. }
KEY的初始化函数:
  1. void key_init(void)
  2. {
  3. static uint32_t i = 0;
  4. gpio_pin_config_t   gpioPinConfig;
  5. gpioPinConfig.pinDirection = kGPIO_DigitalInput;
  6. gpioPinConfig.outputLogic  = 1u;
  7. CLOCK_EnableClock(kCLOCK_Iocon);
  8. IOCON->PIO[KEY_S2_PORT][KEY_S2_PIN] = KEY_S2_FUNC;
  9. IOCON->PIO[KEY_S3_PORT][KEY_S3_PIN] = KEY_S3_FUNC;
  10. IOCON->PIO[KEY_S1_PORT][KEY_S1_PIN] = KEY_S1_FUNC;
  11. CLOCK_DisableClock(kCLOCK_Iocon);
  12. GPIO_PinInit (GPIO, KEY_S2_PORT, KEY_S2_PIN, &gpioPinConfig);
  13. GPIO_PinInit (GPIO, KEY_S3_PORT, KEY_S3_PIN, &gpioPinConfig);
  14. GPIO_PinInit (GPIO, KEY_S1_PORT, KEY_S1_PIN, &gpioPinConfig);
  15. }
KEY控制LED的主程序:
  1. int main(void)
  2. {
  3. volatile uint8_t s_KeyValue = 0;
  4. POWER_SetBodVbatLevel(kPOWER_BodVbatLevel1650mv, kPOWER_BodHystLevel50mv, false);
  5. CLOCK_EnableClock(kCLOCK_Gpio0);
  6. CLOCK_EnableClock(kCLOCK_Gpio1);
  7. BOARD_BootClockFROHF96M();
  8. led_init();
  9. key_init();
  10. while (1)
  11. {
  12. s_KeyValue = key_read();
  13. if( (s_KeyValue&KEY2_NUM) == KEY2_NUM)   // ISP
  14. {
  15. led_set(LEDR_NUM, 0);
  16. }
  17. else
  18. {
  19. led_set(LEDR_NUM, 1);
  20. }
  21. if( (s_KeyValue&KEY3_NUM) == KEY3_NUM)   // WAKE
  22. {
  23. led_set(LEDG_NUM, 0);
  24. }
  25. else
  26. {
  27. led_set(LEDG_NUM, 1);
  28. }
  29. if( (s_KeyValue&KEY1_NUM) == KEY1_NUM)  // USER
  30. {
  31. led_set(LEDB_NUM, 0);
  32. }
  33. else
  34. {
  35. led_set(LEDB_NUM, 1);
  36. }
  37. }
  38. }
经编译下载,其运行效果如图2~4所示。
