查看: 1261|回复: 3
下面这个单片机程序应该如何理解?
ID:840202 发表于 2020-11-9 20:29 | 显示全部楼层 |阅读模式
#include<reg51.h>
unsigned char code image[]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
        0xC3,0xE7,0xE7,0xE7,0xE7,0xE7,0xC3,0xFF,
        0x99,0x00,0x00,0x00,0x81,0xC3,0xE7,0xFF,
  0x99,0x99,0x99,0x99,0x99,0x81,0xC3,0xFF,
  0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};   //24个
unsigned char code TAB[8]  = {0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
void main(){
  EA=1;
        TMOD=0x01;
        TH0=0xfc;
        TL0=0x67;
        ET0=1;
        TR0=1;
        while(1);
void int0() interrupt 1{
        static unsigned char i=0;
        static unsigned char tmr=0;
        static unsigned char index=0;
        TH0=0xfc;
        TL0=0x67;
        P0=0xff;
        switch(i){
                case 0: P1=TAB[7];i++;P0=image[index+0]; break;
                case 1: P1=TAB[6];i++;P0=image[index+1]; break;
                case 2: P1=TAB[5];i++;P0=image[index+2]; break;
                case 3: P1=TAB[4];i++;P0=image[index+3]; break;
                case 4: P1=TAB[3];i++;P0=image[index+4]; break;
                case 5: P1=TAB[2];i++;P0=image[index+5]; break;
                case 6: P1=TAB[1];i++;P0=image[index+6]; break;
                case 7: P1=TAB[0];i=0;P0=image[index+7]; break;
          default: break;
tmr++;
        if(tmr>=250){
                  tmr=0;
                  index++;
                  if(index>=32){
                        index=0;
ID:654028 发表于 2020-11-10 09:28 | 显示全部楼层
这是书上的教程吧
ID:414556 发表于 2020-11-10 09:35 | 显示全部楼层
循环输出显示
ID:451718 发表于 2020-11-10 10:57 | 显示全部楼层
从定时器的初值上分析,你这个程序用在11.0592MHz,12T模式,1毫秒定时器中断的环境中。 1毫秒切换一次段码(P1端口),然后250毫秒更换一次输出内容(P0端口)。TAB[8]是段码的选择值,image[]是P0端口实际的输出内容。
