查看: 3897|回复: 3
error C141: syntax error near‘’单片机代码186行报错 求指导
ID:844692 发表于 2020-11-22 16:01 | 显示全部楼层 |阅读模式
大佬们,看一下我的程序为什么会出错
shee.c(186): error C141: syntax error near ‘’
  1. #include<reg52.h>
  2. #include<string.h>
  3. #include<stdlib.h>
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. sbit SHANG = P3^4;
  7. sbit XIA =P3^5;
  8. sbit ZUO =P3^6;
  9. sbit YOU =P3^7;
  10. uchar ii,key1;
  11. uint z,y,z1,y1;
  12. uint s[8][8];
  13. uchar code nx[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  14. uchar code ny[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
  15. void ling()
  16. {
  17.         uchar i,j;
  18.         for(i=0;i<=7;i++)
  19.         {
  20.                 for(j=0;j<=7;j++)
  21.                 {
  22.                         s[i][j]=0;
  23.                 }
  24.         }
  25. }
  26. void print()
  27. {
  28.                 uchar a,b;
  29.                 P2=0xff;
  30.                 P0=0x00;
  31.                 for(a=0;a<=7;a++)
  32.                 {
  33.                         for(b=0;b<=7;b++)
  34.                         {
  35.                                         if(s[a][b]>0)
  36.                                         {
  37.                                                 P0=ny[a],P2=nx[b];
  38.                                         }
  39.                         }
  40.
  41.                 }
  42. }
  43. void hd(uchar x,uchar y)
  44. {
  45.         s[x][y]=1;
  46.         return;
  47. }
  48. uchar min ()
  49. {        uint i,b,c,d,a=0;
  50.         for(i=0;i<=7;i++)
  51.         {
  52.                 for(b=0;b<=7;b++)
  53.         {
  54.                 if(s[i][b]>0&a<0)
  55.                 {
  56.                         c=s[i][b];d=s[i][b];a++;
  57.                 }
  58.                 if(s[i][b]>0%s[i][b]<=c)
  59.                 {
  60.                         c=s[i][b];
  61.                         z=i;
  62.                         y=b;
  63.                 }
  64.                 if(s[i][b]>0&s[i][b]>=d)
  65.                 {
  66.                         d=s[i][b];
  67.                         z1=i;
  68.                         y1=b;
  69.                 }
  70.         }
  71.         }
  72.         return c;
  73. }
  74. void main()
  75. {
  76.         char n=0,i=0,b=2,ff,gg;
  77.         uint t,aa=1;
  78.
  79.         ling();
  80.         key1='y';
  81.         ff=0+rand()%7;//Ëæ»úoˉêy
  82.         gg=0+rand()%7;
  83.         while(1)
  84.         {
  85.                 t=0;
  86.                 switch(key1)
  87.                 {
  88.                 case 's':
  89.                 if(i>=0)
  90.                 {
  91.                         if(i==-1)
  92.                         {
  93.                                 i=i+1;
  94.                                 s[i--][n]=-aa++;
  95.                                 }
  96.                                 }
  97.                 break;
  98.                 case 'x':
  99.                 if(i<8)
  100.                 {
  101.                         if(n==8)
  102.                         {
  103.                                 n=n-1;s[i++][n]=aa++;
  104.                                 }
  105.
  106.                         }
  107.                 else
  108.                 {
  109.                         s[i++][n]=aa++;
  110.                         }
  111.
  112.                 break;
  113.                 case 'y':
  114.                 if(n<8)
  115.                 {
  116.                         if(i==8)
  117.                         {
  118.                                 i=i-1;s[i][n++]=aa++;
  119.                                 }
  120.                         }
  121.                 else
  122.                 {
  123.                         s[i][n++]=aa++;
  124.                         }
  125.                 break;
  126.                 case 'z':
  127.                 if(n>=0)
  128.                 {
  129.                         s[i][n--]=aa++;
  130.                         }
  131.                 break;
  132.                 }
  133.         min();
  134.         if(z1==i&y1==n)
  135.         {
  136.                 ff=1+rand()%7;gg=1+rand()%7;
  137.                 }
  138.         else
  139.         {
  140.                 if(aa>2)
  141.                 {
  142.                         s[z][y]=0;
  143.                         }
  144.                 }
  145.         s[ff][gg]=0;
  146.         if(s[i][n]<aa&s[i][n]>0)
  147.         {
  148.                 P0=0xff;
  149.                 P2=0x00;
  150.                 }
  151.         if(i<0|i>7|n<0|n>7)
  152.         {
  153.         P0=0xff;
  154.         P2=0x00;
  155.         }
  156.         while(t<1000)
  157.         {
  158.
  159.                 if(SHANG==0&key1!='x')
  160.                 {
  161.                         key1='s';
  162.                         }
  163.
  164.                 if(XIA==0&key1!='s')
  165.                 {
  166.                         key1='x';
  167.                         }
  168.                 if(YOU==0&key1!='z')
  169.                 {
  170.                         key1='y';
  171.                         }
  172.                 if(ZUO==0&key1!='y')
  173.                 {
  174.                         key1='z';
  175.                         }
  176.                 print();
  177.                 t++;
  178.                 }
  179.                 }
ID:844692 发表于 2020-11-22 16:02 | 显示全部楼层
出现了这样子的错误shee.c(186): error C141: syntax error near ‘’
ID:57657 发表于 2020-11-22 17:48 | 显示全部楼层
括号不对称
ID:844692 发表于 2020-11-22 22:06 | 显示全部楼层
好的,谢谢。
