查看: 1380|回复: 1
问题已解决STM32F103单片机差那1234按键能用5678按键不能用
ID:63317 发表于 2020-11-27 08:21 | 显示全部楼层 |阅读模式
**文   件   名: Hal_Key.c
**描        述: 按键接口处理
#define HAL_KEY_GLOBAL
#include "include.h"
#include "wifi.h"
typedef void (* KEY_HANDLE)(void);
typedef struct
  uint8_t Status;
  uint32_t Press_Time;
  KEY_HANDLE Short_Press_Handle;
  KEY_HANDLE Long_Press_Handle;
} KEY_STATE_T;
static KEY_STATE_T Key_State[MAX_KEY];
extern TYPE_BUFFER_S FlashBuffer;
函数名称 : Key1_LongPress_Handle
功能描述 : Key1长按处理函数
输入参数 : 无
返回参数 : 无
使用说明 : 无
static void Key1_LongPress_Handle(void)//
                     kg_ON();
mcu_dp_bool_update(DPID_KG,FlashBuffer.kg);
static void Key2_LongPress_Handle(void)//L
                    kg1_ON();
mcu_dp_bool_update(DPID_KG1,FlashBuffer.kg1);
static void Key3_LongPress_Handle(void)//
               kg2_ON();
mcu_dp_bool_update(DPID_KG2,FlashBuffer.kg2);
static void Key4_LongPress_Handle(void)//O
             kg3_ON();
mcu_dp_bool_update(DPID_KG3,FlashBuffer.kg3);
static void Key5_LongPress_Handle(void)//
             wet_ON();
mcu_dp_bool_update(DPID_WET,FlashBuffer.wet);
        static void Key6_LongPress_Handle(void)//
               kg2_ON();
static void Key7_LongPress_Handle(void)//
             kg3_ON();
static void Key8_LongPress_Handle(void)//
             wet_ON();
函数名称 : KEY_Init
功能描述 : KEY初始化
输入参数 : 无
返回参数 : 无
使用说明 : 无
void KEY_Init(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  RCC_APB2PeriphClockCmd(GPIO_KEY1_CLK | GPIO_KEY2_CLK | GPIO_KEY3_CLK | GPIO_KEY4_CLK| GPIO_KEY5_CLK | GPIO_KEY6_CLK | GPIO_KEY7_CLK | GPIO_KEY8_CLK , (FunctionalState)ENABLE);
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_InitStructure.GPIO_Pin = GPIO_KEY1_PIN;
  GPIO_Init(GPIO_KEY1_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_KEY2_PIN;
  GPIO_Init(GPIO_KEY2_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_KEY3_PIN;
  GPIO_Init(GPIO_KEY3_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_KEY4_PIN;
  GPIO_Init(GPIO_KEY4_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_KEY5_PIN;
  GPIO_Init(GPIO_KEY5_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_KEY6_PIN;
  GPIO_Init(GPIO_KEY6_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_KEY7_PIN;
  GPIO_Init(GPIO_KEY7_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_KEY8_PIN;
  GPIO_Init(GPIO_KEY8_PORT, &GPIO_InitStructure);
  memset(Key_State,0,sizeof(Key_State));
  Key_State[0].Long_Press_Handle = Key1_LongPress_Handle;   //Long_Press_Handle按钮长按
  Key_State[1].Long_Press_Handle = Key2_LongPress_Handle;
        Key_State[2].Long_Press_Handle = Key3_LongPress_Handle;
        Key_State[3].Long_Press_Handle = Key4_LongPress_Handle;
  Key_State[4].Long_Press_Handle = Key5_LongPress_Handle;   //Long_Press_Handle按钮长按
  Key_State[5].Long_Press_Handle = Key6_LongPress_Handle;
        Key_State[6].Long_Press_Handle = Key7_LongPress_Handle;
        Key_State[7].Long_Press_Handle = Key8_LongPress_Handle;
函数名称 : Get_Key
功能描述 : 读取按键
输入参数 : 无
返回参数 : ReadKey:按键值
使用说明 : 无
static uint8_t Get_Key(void)
   uint8_t ReadKey = 0;
  if(!GPIO_ReadInputDataBit(GPIO_KEY1_PORT,GPIO_KEY1_PIN))
    ReadKey |= PRESS_KEY1;
  if(!GPIO_ReadInputDataBit(GPIO_KEY2_PORT,GPIO_KEY2_PIN))
    ReadKey |= PRESS_KEY2;
  if(!GPIO_ReadInputDataBit(GPIO_KEY3_PORT,GPIO_KEY3_PIN))
    ReadKey |= PRESS_KEY3;
  if(!GPIO_ReadInputDataBit(GPIO_KEY4_PORT,GPIO_KEY4_PIN))
    ReadKey |= PRESS_KEY4;
           if(!GPIO_ReadInputDataBit(GPIO_KEY1_PORT,GPIO_KEY5_PIN))
    ReadKey |= PRESS_KEY5;
  if(!GPIO_ReadInputDataBit(GPIO_KEY2_PORT,GPIO_KEY6_PIN))
    ReadKey |= PRESS_KEY6;
  if(!GPIO_ReadInputDataBit(GPIO_KEY3_PORT,GPIO_KEY7_PIN))
    ReadKey |= PRESS_KEY7;
  if(!GPIO_ReadInputDataBit(GPIO_KEY4_PORT,GPIO_KEY8_PIN))
    ReadKey |= PRESS_KEY8;
  return ReadKey;
函数名称 : Get_Key_Press_Time
功能描述 : 获取按键按下时间
输入参数 : last_time:上次按下时间
返回参数 : 2次按键之间差值
使用说明 : 无
static uint32_t Get_Key_Press_Time(uint32_t last_time)
  uint32_t time;
  time = Get_Count_Value();
  if(time >= last_time)
    time -= last_time;
    //Time2溢出
    time += ~last_time;
  return time;
函数名称 : Key_Scan
功能描述 : 扫描按键
输入参数 : 无
返回参数 : 无
使用说明 : 无
void Key_Scan(void)
  uint8_t i;
  uint32_t time;
  uint8_t key;
  key = Get_Key();
  for(i = 0; i < MAX_KEY; i ++)
    switch(Key_State[ i].Status)[ i]
      case KEY_NO:
        //有按键按下
        if((key >> i) & 0x01)
          Key_State[ i].Status = KEY_DOWN;[ i]
          Key_State[ i].Press_Time = Get_Count_Value();[ i]
        break;
      case KEY_DOWN:
        if(((key >> i) & 0x01) == 0)
          Key_State[ i].Status = KEY_UP;[ i]
        break;
      case KEY_LONG:
          Key_State[ i].Press_Time = 0;[ i]
          Key_State[ i].Status = KEY_NO;[ i]
        break;
    if((Key_State[ i].Status == KEY_DOWN) || (Key_State[ i].Status == KEY_LONG))[ i][ i]
      time = Get_Key_Press_Time(Key_State[ i].Press_Time);[ i]
      if(time >= TIME_PRESS_LONG)
        //一直长按Long_Press_Handle
        Key_State[ i].Status = KEY_LONG;[ i]
        if(Key_State[ i].Long_Press_Handle)[ i]
          Key_State[ i].Long_Press_Handle();[ i]
    else if(Key_State[ i].Status == KEY_UP)[ i]
      //松开
      if((time >= TIME_PRESS_SHORT) && (time < TIME_PRESS_LONG))
        //短按Short_Press_Handle
        if(Key_State[ i].Short_Press_Handle)[ i]
          Key_State[ i].Short_Press_Handle();[ i]
      else if(time >= TIME_PRESS_LONG)
        //长按Long_Press_Handle
#ifndef __HAL_KEY_H__
#define __HAL_KEY_H__
#define GPIO_KEY1_CLK    RCC_APB2Periph_GPIOA
#define GPIO_KEY1_PORT   GPIOA
#define GPIO_KEY1_PIN    GPIO_Pin_11
#define GPIO_KEY2_CLK    RCC_APB2Periph_GPIOA
#define GPIO_KEY2_PORT   GPIOA
#define GPIO_KEY2_PIN    GPIO_Pin_12
#define GPIO_KEY3_CLK    RCC_APB2Periph_GPIOA
#define GPIO_KEY3_PORT   GPIOA
#define GPIO_KEY3_PIN    GPIO_Pin_0
#define GPIO_KEY4_CLK    RCC_APB2Periph_GPIOA
#define GPIO_KEY4_PORT   GPIOA
#define GPIO_KEY4_PIN    GPIO_Pin_1
#define GPIO_KEY5_CLK    RCC_APB2Periph_GPIOA
#define GPIO_KEY5_PORT   GPIOA
#define GPIO_KEY5_PIN    GPIO_Pin_11
#define GPIO_KEY6_CLK    RCC_APB2Periph_GPIOA
#define GPIO_KEY6_PORT   GPIOA
#define GPIO_KEY6_PIN    GPIO_Pin_12
#define GPIO_KEY7_CLK    RCC_APB2Periph_GPIOA
#define GPIO_KEY7_PORT   GPIOA
#define GPIO_KEY7_PIN    GPIO_Pin_0
#define GPIO_KEY8_CLK    RCC_APB2Periph_GPIOA
#define GPIO_KEY8_PORT   GPIOA
#define GPIO_KEY8_PIN    GPIO_Pin_1
#define MAX_KEY          8
#define PRESS_KEY1      0x01
#define PRESS_KEY2      0x02
#define PRESS_KEY3      0x04
#define PRESS_KEY4      0x08
#define PRESS_KEY5      0x11
#define PRESS_KEY6      0x22
#define PRESS_KEY7      0x44
#define PRESS_KEY8      0x88
#define KEY_NO          0x00
#define KEY_DOWN        0x10
#define KEY_UP          0x20
#define KEY_LONG        0x40
#define TIME_PRESS_LONG         (3 * 1000)
#define TIME_PRESS_SHORT        50
函数名称 : Get_RGB2_State
功能描述 : RGB2状态
输入参数 : 无
返回参数 : RGB2开关状态
使用说明 : 无
uint8_t Get_RGB2_State(void);
函数名称 : KEY_Init
功能描述 : KEY初始化
输入参数 : 无
返回参数 : 无
使用说明 : 无
void KEY_Init(void);
