查看: 1584|回复: 4
单片机想同时检测显示八路的实时电压,我该怎么弄啊,好难啊,这个还是抄别人的
ID:852655 发表于 2020-12-12 20:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
100黑币
#include<reg52.h>
#include<intrins.h>
#define uint unsigned int
sfr        P1ASF=0X9D;
sfr        ADC_CONTR=0XBC;      //ADC控制寄存器
sfr        ADC_RES=0XBD;        //AD转换结果存放
sfr        ADC_RESL=0XBE;       //AD转换结果存放
sfr        AUXR1=0XA2;
sbit SCL=P0^0;
sbit SDA=P0^1;
uchar a,b,c,d;
uint j,k,m;
uint g;
unsigned char code Hzk[][32]={
{0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00},/*"0",0*/
{0x00,0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00},/*"1",1*/
{0x00,0x70,0x08,0x08,0x08,0x08,0xF0,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00},/*"2",2*/
{0x00,0x30,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x18,0x20,0x21,0x21,0x22,0x1C,0x00},/*"3",3*/
{0x00,0x00,0x80,0x40,0x30,0xF8,0x00,0x00,0x00,0x06,0x05,0x24,0x24,0x3F,0x24,0x24},/*"4",4*/
{0x00,0xF8,0x88,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x20,0x20,0x20,0x11,0x0E,0x00},/*"5",5*/
{0x00,0xE0,0x10,0x88,0x88,0x90,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x20,0x1F,0x00},/*"6",6*/
{0x00,0x18,0x08,0x08,0x88,0x68,0x18,0x00,0x00,0x00,0x00,0x3E,0x01,0x00,0x00,0x00},/*"7",7*/
{0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00},/*"8",8*/
{0x00,0xF0,0x08,0x08,0x08,0x10,0xE0,0x00,0x00,0x01,0x12,0x22,0x22,0x11,0x0F,0x00},/*"9",9*/
{0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20},/*"A",10*/
{0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00},/*"B",11*/
{0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00},/*"C",12*/
{0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00},/*"D",13*/
{0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00},/*"E",14*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"空白",15*/
{0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x20,0x10,0x08,0x04,0x02,0x01,0x00},/*">",16*/
{0x00,0x00,0x80,0x40,0x20,0x10,0x08,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x00},/*"<",17*/
{0x00,0x40,0xC0,0x78,0x40,0xC0,0x78,0x00,0x00,0x04,0x3F,0x04,0x04,0x3F,0x04,0x00},/*"#",18*/
{0x40,0x40,0x80,0xF0,0x80,0x40,0x40,0x00,0x02,0x02,0x01,0x0F,0x01,0x02,0x02,0x00},/*"*",19*/
{0xF0,0x08,0xF0,0x80,0x60,0x18,0x00,0x00,0x00,0x31,0x0C,0x03,0x1E,0x21,0x1E,0x00},/*"%",20*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00},/*".",21*/
//IIC Start
void IIC_Start()        //开始信号
   SCL = 1;
   SDA = 1;
   SDA = 0;
   SCL = 0;
//IIC Stop
void IIC_Stop()        //停止信号
   SCL = 0;
   SDA = 0;
   SCL = 1;
   //Delay_us(1);
   SDA = 1;
   //Delay_us(1);
// IIC Write byte
void Write_IIC_Byte(unsigned char IIC_Byte)                        //写1个字节
        unsigned char i;
        for(i=0;i<8;i++)
                if(IIC_Byte & 0x80)                //1?0?
                SDA=1;
                SDA=0;
                //Delay_us(1);
                SCL=1;
                //Delay_us(1);
                SCL=0;
                //Delay_us(1);
                IIC_Byte<<=1;                        //loop
        SDA=1;
        //Delay_us(1);
        SCL=1;
        //Delay_us(1);
        SCL=0;
        //Delay_us(1);
// IIC Write Command
void Write_IIC_Command(unsigned char IIC_Command)
   IIC_Start();
   Write_IIC_Byte(0x78);            //Slave address,SA0=0
   Write_IIC_Byte(0x00);                        //write command
   Write_IIC_Byte(IIC_Command);
   IIC_Stop();
// IIC Write Data
void Write_IIC_Data(unsigned char IIC_Data)
   IIC_Start();
   Write_IIC_Byte(0x40);                        //write data
   Write_IIC_Byte(IIC_Data);
   IIC_Stop();
void picture_1(uint y)
  unsigned char x;
      Write_IIC_Command(0xb4);
      Write_IIC_Command(0x00);
      Write_IIC_Command(0x10);
      for(x=0;x<8;x++)
          Write_IIC_Data(Hzk[y][x]);
          Write_IIC_Command(0xb5);
      for(x=8;x<16;x++)
void picture_2(uint y)
  unsigned char x;
      Write_IIC_Command(0x08);
      for(x=0;x<8;x++)
      for(x=8;x<16;x++)
void picture_3(uint y)
  unsigned char x;
      Write_IIC_Command(0x11);
      for(x=0;x<8;x++)
      for(x=8;x<16;x++)
void picture_4(uint y)
  unsigned char x;
      for(x=0;x<8;x++)
      for(x=8;x<16;x++)
void fill_picture(unsigned char fill_Data)          //清屏
        unsigned char m,n;
        for(m=0;m<8;m++)
                Write_IIC_Command(0xb0+m);
                for(n=0;n<128;n++)
                         Write_IIC_Data(fill_Data);
void Initial_LY096BG30()
        Write_IIC_Command(0xAE);   //display off
        Write_IIC_Command(0x20);        //Set Memory Addressing Mode
        Write_IIC_Command(0x10);        //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
        Write_IIC_Command(0xb0);        //Set Page Start Address for Page Addressing Mode,0-7
        Write_IIC_Command(0xc8);        //Set COM Output Scan Direction
        Write_IIC_Command(0x00);//---set low column address
        Write_IIC_Command(0x10);//---set high column address
        Write_IIC_Command(0x40);//--set start line address
        Write_IIC_Command(0x81);//--set contrast control register
        Write_IIC_Command(0x7f);
        Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
        Write_IIC_Command(0xa6);//--set normal display
        Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
        Write_IIC_Command(0x3F);//
        Write_IIC_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
        Write_IIC_Command(0xd3);//-set display offset
        Write_IIC_Command(0x00);//-not offset
        Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
        Write_IIC_Command(0xf0);//--set divide ratio
        Write_IIC_Command(0xd9);//--set pre-charge period
        Write_IIC_Command(0x22); //
        Write_IIC_Command(0xda);//--set com pins hardware configuration
        Write_IIC_Command(0x12);
        Write_IIC_Command(0xdb);//--set vcomh
        Write_IIC_Command(0x20);//0x20,0.77xVcc
        Write_IIC_Command(0x8d);//--set DC-DC enable
        Write_IIC_Command(0x14);//
        Write_IIC_Command(0xaf);//--turn on oled panel
/***********************Delay****************************************/
void Delay_50ms(unsigned int Del_50ms)                //   延时
        unsigned int m;
        for(;Del_50ms>0;Del_50ms--)
        for(m=6245;m>0;m--);
void delay1ms(uint z)   //误差 0us
    unsigned char a,b,c;
    for(c=z;c>0;c--)
        for(b=142;b>0;b--)
            for(a=2;a>0;a--);
void ADinit()
   P1ASF=0x01;        //P1^0口作为AD输入口
   ADC_CONTR=0x20;    //P1^0口作为AD输入口,360个时钟周期转换一次
   AUXR1=0x00;        //高八位存放于ADC_RES,低二位存放于ADC_RESL
   IE=0XA0;           //开总中断允许AD中断
void ADser() interrupt 5
         _nop_();
         _nop_();
         _nop_();
         _nop_();              //延时4个时钟周期,使其趋于稳定
     ADC_CONTR=0xC0;           //转换完成,将ADC_FLAG清零
     j=ADC_RES;                    //AD高位数据
         k=ADC_RESL;                   //AD低位数据
         m=(j<<2)+k;
        ADinit();
                Initial_LY096BG30();
                delay1ms(1);
                fill_picture(0x00);
                Delay_50ms(50);
           ADC_CONTR=0XA8;//开始AD转换
           delay1ms(1);
           ADC_CONTR=0X20;//关闭AD转换
最佳答案
查看完整内容
做一个8进制计数器000-111加至0809地址端
ID:837951 发表于 2020-12-12 20:01 | 只看该作者
ID:420836 发表于 2020-12-13 03:35 | 只看该作者
可以先完成一个电压测量和一个显示的控制吗? 第一步之后,再添加一个。
ID:213173 发表于 2020-12-13 06:20 | 只看该作者
给你一个16路电压表及仿真参考
16路电压表ADC0832 74HC4051 仿真.zip (124.87 KB, 下载次数: 14)
ID:781556 发表于 2020-12-13 08:08 | 只看该作者
這裡就是兩部分功能1是讀取ADC,2是輸出顯示,通過i++顯示80個也沒問題,這兩點您都不想研究,那就一抄到底吧
