查看: 2714|回复: 0
Arduino实现电视盒子的红外遥控
ID:162514 发表于 2020-12-25 14:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <Keypad.h>
#include<IRremote.h>
IRsend irsend;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {11,10, 9, 8}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {7, 6, 5,4}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad keypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
  Serial.begin(9600);
void loop(){
  char key = keypad.getKey();
  if(key){
    Serial.println(key);
  keypad.getState();//键盘字符串实现
    if( key==  '#'){
          irsend.sendNEC(0x807F3BC4,32);}
   if(key==  '1') {
          irsend.sendNEC(0x807F53AC,32);  }
   if(key==  'A'){
          irsend.sendNEC(0x807F738C ,32);  }
    if(key==  '2'){
          irsend.sendNEC(0x807F4BB4,32);  }
    if(key==  '3'){
          irsend.sendNEC(0x807F9966,32);}
    if(key=='4'){
          irsend.sendNEC(0x807F837C,32); }
     if(key=='D'){
          irsend.sendNEC(0x807F11EE,32); }
     if(key=='B'){
          irsend.sendNEC(0x807FA956,32); }
     if(key=='C'){
          irsend.sendNEC(0x807FA35C,32); }
      if(key=='5'){
          irsend.sendNEC(0x807F49B6,32); }
//发射管带330欧接3
