原理图
- #include<AT89X52.h>
- #include <intrins.h>
- #define Delaynop(){_nop_();_nop_();_nop_();_nop_();}
- sbit RS=P2^0;
- sbit RW=P2^1;
- sbit EN=P2^2;
- void Delayms(unsigned int ms);
- bit LCD_Busy();
- void LCD_Pos(unsigned char);
- void LCD_Wcmd(unsigned char);
- void LCD_Wdat(unsigned char);
- char code Title_Text[]={"--Phone Code-- "};
- unsigned char code Key_Table[]={'1','2','3','4','5','6','7','8','9','*','0','#'};
- unsigned char Dial_Code_Str[]={" "};
- unsigned char KeyNo=0xff;
- int tCount=0;
- //毫秒级延时函数
- void Delayms(unsigned int x)
- unsigned char i;
- while(x--)
- for(i=0;i<120;i++);
- //显示字符串
- void Display_String(unsigned char *str,unsigned char LineNo)
- unsigned char k;
- LCD_Pos(LineNo);
- for(k=0;k<16;k++)
- LCD_Wdat(str[k]);
- //检查1602是否处于忙装填
- bit LCD_Busy_Check()
- bit Result;
- RS=0;
- RW=1;
- EN=1;
- Delaynop();
- Result=(bit)(P0 & 0x80);
- EN=0;
- return Result;
- //向1602写入指令的函数
- void LCD_Write_Command(unsigned char cmd)
- while(LCD_Busy_Check()); //检查是否处于忙状态
- RS=0;
- RW=0;
- EN=0;
- _nop_();
- _nop_();
- P0=cmd; //写入指令
- Delaynop();
- EN=1;
- Delaynop();
- EN=0;
- //向1602写数据
- void LCD_Wdat(unsigned char dat)
- RS=1;
- RW=0;
- EN=0;
- P0=dat; //写入数据
- Delaynop();
- EN=1;
- Delaynop();
- EN=0;
- //初始化1602
- void Init_LCD()
- LCD_Write_Command(0x38);Delayms(5);
- LCD_Write_Command(0x01);Delayms(5);
- LCD_Write_Command(0x06);Delayms(5);
- LCD_Write_Command(0x0c);Delayms(5);
- //设置显示位置
- void LCD_Pos(unsigned char pos)
- LCD_Write_Command(pos|0x80);
- //T0的中断服务子函数
- void T0Deal()interrupt 1
- TH0=-600/256;
- TL0=-600%256;
- if(++tCount==200)
- tCount=0;
- TR0=0;
- //按键扫描函数,返回值为对应的按键编码
- unsigned char GetKey()
- unsigned char i,j,k=0;
- unsigned char KeyScanCode[]={0xef,0xdf,0xbf,0x7f}; //行列扫描的行列码
- unsigned char KeyCodeTable[]={0xee,0xed,0xeb,0xde,0xdd,0xdb,0xbe,0xbd,0xbb,0x7e,0x7d,0x7b};
- P3=0x0f;
- if(P3!=0x0f) //如果有按键被按下
- for(i=0;i<4;i++) //依次进行扫描
- P3=KeyScanCode[i];
- for(j=0;j<3;j++)
- k=i*3+j; //计算对应的按键编码
- if(P3==KeyCodeTable[k])
- return k; //返回按键编码
- else
- return 0xff; //或者返回0xff
- //主函数
- void main()
- unsigned char i=0,j;
- P0=0xFF;
- P2=0xFF;
- P1=0xFF; //初始化端口
- IE=0x82; //设置中断
- TMOD=0x01; //启动T0定时器
- Init_LCD(); //初始化1602
- Display_String(Title_Text,0x00); //显示 --Phone Code--
- while(1)
- KeyNo=GetKey(); //获得按键状态
- if(KeyNo==0xff)
- continue; //如果没有按键,则进入下一个循环
- if(++i==12) //如果已经超过11个数字,清除显示屏幕
- for(j=0;j<16;j++)
- Dial_Code_Str[j]=' ';
- i=0;
- if(KeyNo==11)
- for(a=0;a<16;a++)
- Dial_Code_Str[a]=' ';i=-1;
- }// 按键" #"键
- Dial_Code_Str[i]=Key_Table[KeyNo]; //显示拨号数据
- Display_String(Dial_Code_Str,0x40);
- TR0=1;
- while(GetKey()!=0xff);
手机拨号模块.rar
(113.53 KB, 下载次数: 23)
