查看: 10733|回复: 7
proteus仿真温湿度传感器dht11,dht22程序
使用1602显示DHT22的温湿度,精确到小数点的后一位
//           DHT21使用范例
//单片机 AT89S52 或 STC89C52RC
//功能   串口发送温湿度数据 晶振 11.0592M 波特率 9600
//硬件   P2.0口为通讯口连接DHT22,DHT22的电源和地连接单片机的电源和地,单片机串口加MAX232连接电脑
#include <reg51.h>
#include <intrins.h>
typedef unsigned char  U8;       /* defined for unsigned 8-bits integer variable           无符号8位整型变量  */
typedef signed   char  S8;       /* defined for signed 8-bits integer variable                  有符号8位整型变量  */
typedef unsigned int   U16;      /* defined for unsigned 16-bits integer variable           无符号16位整型变量 */
typedef signed   int   S16;      /* defined for signed 16-bits integer variable           有符号16位整型变量 */
typedef unsigned long  U32;      /* defined for unsigned 32-bits integer variable           无符号32位整型变量 */
typedef signed   long  S32;      /* defined for signed 32-bits integer variable           有符号32位整型变量 */
typedef float          F32;      /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double         F64;      /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
#define uint unsigned int
#define   Data_0_time    4
#define LCD1602_DB  P0
sbit LCD1602_RS = P2^0;
sbit LCD1602_RW = P2^1;
sbit LCD1602_E  = P2^2;
/* 等待液晶准备好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        sta = LCD1602_DB; //读取状态字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重复检测直到其等于0为止
/* 向LCD1602液晶写入一字节命令,cmd-待写入命令值 */
void LcdWriteCmd(unsigned char cmd)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 向LCD1602液晶写入一字节数据,dat-待写入数据值 */
void LcdWriteDat(unsigned char dat)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 设置显示RAM起始地址,亦即光标位置,(x,y)-对应屏幕上的字符坐标 */
void LcdSetCursor(unsigned char x, unsigned char y)
    unsigned char addr;
    if (y == 0)  //由输入的屏幕坐标计算显示RAM的地址
        addr = 0x00 + x;  //第一行字符地址从0x00起始
        addr = 0x40 + x;  //第二行字符地址从0x40起始
    LcdWriteCmd(addr | 0x80);  //设置RAM地址
/* 在液晶上显示字符串,(x,y)-对应屏幕上的起始坐标,str-字符串指针 */
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
    LcdSetCursor(x, y);   //设置起始地址
    while (*str != '\0')  //连续写入字符串数据,直到检测到结束符
        LcdWriteDat(*str++);
/* 打开光标的闪烁效果 */
void LcdOpenCursor()
        LcdWriteCmd(0x0F);
/* 关闭光标显示 */
void LcdCloseCursor()
        LcdWriteCmd(0x0C);
/* 初始化1602液晶 */
void InitLcd1602()
    LcdWriteCmd(0x38);  //16*2显示,5*7点阵,8位数据接口
    LcdWriteCmd(0x0C);  //显示器开,光标关闭
    LcdWriteCmd(0x06);  //文字不动,地址自动+1
    LcdWriteCmd(0x01);  //清屏
//----------------IO口定义区--------------------//
sbit  P2_0  = P2^3 ;
//----------------定义区--------------------//
U8  U8FLAG,k;
U8  U8count,U8temp;
U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8  U8comdata;
U8  outdata[5];  //定义发送的字节数
U8  indata[5];
U8  count, count_r=0;
U8 str[4];
U16 U16temp1,U16temp2;
SendData(U8 *a)
        outdata[0] = a[0];
        outdata[1] = a[1];
        outdata[2] = a[2];
        outdata[3] = a[3];
        outdata[4] = a[4];
        count = 1;
        SBUF=outdata[0];
       void Delay(U16 j)
    {      U8 i;
            for(;j>0;j--)
                for(i=0;i<27;i++);
      void  Delay_10us(void)
        U8 i;
        i--;
        i--;
        i--;
        i--;
        i--;
        i--;
        void  COM(void)
                U8 i;
       for(i=0;i<8;i++)
                       U8FLAG=2;
                   while((!P2_0)&&U8FLAG++);
                        Delay_10us();
            Delay_10us();
            Delay_10us();
                          U8temp=0;
             if(P2_0)U8temp=1;
                    U8FLAG=2;
                 while((P2_0)&&U8FLAG++);
                   //超时则跳出for循环
                    if(U8FLAG==1)break;
                   //判断数据位是0还是1
                // 如果高电平高过预定0高电平值则数据位为 1
                   U8comdata<<=1;
                      U8comdata|=U8temp;        //0
             }//rof
        //-----湿度读取子程序 ------------
        //----以下变量均为全局变量--------
        //----温度高8位== U8T_data_H------
        //----温度低8位== U8T_data_L------
        //----湿度高8位== U8RH_data_H-----
        //----湿度低8位== U8RH_data_L-----
        //----校验 8位 == U8checkdata-----
        //----调用相关子程序如下----------
        //---- Delay();, Delay_10us();,COM();
        void RH(void)
          //主机拉低18ms
       P2_0=0;
           Delay(180);
           P2_0=1;
         //总线由上拉电阻拉高 主机延时20us
           Delay_10us();
           Delay_10us();
       Delay_10us();
           Delay_10us();
         //主机设为输入 判断从机响应信号
           P2_0=1;
         //判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运行
           if(!P2_0)                 //T !
           U8FLAG=2;
         //判断从机是否发出 80us 的低电平响应信号是否结束
           U8FLAG=2;
         //判断从机是否发出 80us 的高电平,如发出则进入数据接收状态
         //数据接收状态
           COM();
           U8RH_data_H_temp=U8comdata;
           COM();
           U8RH_data_L_temp=U8comdata;
           COM();
           U8T_data_H_temp=U8comdata;
           COM();
           U8T_data_L_temp=U8comdata;
           COM();
           U8checkdata_temp=U8comdata;
           P2_0=1;
         //数据校验
           U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
           if(U8temp==U8checkdata_temp)
                     U8RH_data_H=U8RH_data_H_temp;
                     U8RH_data_L=U8RH_data_L_temp;
                  U8T_data_H=U8T_data_H_temp;
                     U8T_data_L=U8T_data_L_temp;
                     U8checkdata=U8checkdata_temp;
           }//fi
           }//fi
//main()功能描述:  AT89C51  11.0592MHz         串口发
//送温湿度数据,波特率 9600
U16 wendu = 0;
U16 shidu = 0;
U8 wendu_zu[4];
U8 shidu_zu[4];
        //uchar str[6]={"RS232"};
        /* 系统初始化 */
        TMOD = 0x20;          //定时器T1使用工作方式2
        TH1 = 253;        // 设置初值
        TL1 = 253;
        TR1 = 1;          // 开始计时
        SCON = 0x50;          //工作方式1,波特率9600bps,允许接收
        ES = 1;
        EA = 1;           // 打开所以中断
        TI = 0;
        RI = 0;
        SendData(str) ;   //发送到串口
        Delay(10);         //延时100US(12M晶振)
        InitLcd1602();
           //调用温湿度读取子程序
           RH();
           //串口显示程序
     wendu = (((U16)U8RH_data_H<<8)|(U16)U8RH_data_L);
                 shidu = (((U16)U8T_data_H<<8)|(U16)U8T_data_L);
           wendu_zu[3]=wendu%10 + '0';
                 wendu_zu[2]='.';
           wendu_zu[1]=(wendu/10)%10+ '0';
           wendu_zu[0]=wendu/100+ '0';
                 shidu_zu[3] = shidu%10 + '0';
                 shidu_zu[2] = '.';
           shidu_zu[1] = (shidu/10)%10+ '0';
           shidu_zu[0] = shidu/100 + '0';
     LcdShowStr(0,0,wendu_zu);
     LcdShowStr(0,1,shidu_zu);
           //读取模块数据周期不宜小于 2S
           Delay(2000);
        }//elihw
}// main
//void RSINTR() interrupt 4 using 2
//        U8 InPut3;
//        if(TI==1) //发送中断
//                TI=0;
//                if(count!=5) //发送完5位数据
//                        SBUF= outdata[count];
//                        count++;
//        if(RI==1)         //接收中断
//                InPut3=SBUF;
//                indata[count_r]=InPut3;
//                count_r++;
//                RI=0;
//                if (count_r==5)//接收完4位数据
//                //数据接收完毕处理。
//                        count_r=0;
//                str[0]=indata[0];
//                 str[1]=indata[1];
//                   str[2]=indata[2];
//                         str[3]=indata[3];
//                                 str[4]=indata[4];
//                                 P0=0;
全部资料51hei下载地址:
DHT22 .zip (62.48 KB, 下载次数: 342)
收藏收藏6 分享淘帖 顶 踩
ID:336823 发表于 2021-4-7 17:14 | 只看该作者
仿真了一下,LCD不显示
ID:925265 发表于 2021-8-20 08:04 | 只看该作者
能显示
ID:984835 发表于 2021-11-26 10:54 | 只看该作者
为什么我的lcd显示不了啊
ID:262 发表于 2021-11-27 03:30 | 只看该作者
幻夜行 发表于 2021-4-7 17:14
仿真了一下,LCD不显示
我用Proteus8.8版本测试ok  你换个版本看看
ID:996196 发表于 2021-12-23 16:53 | 只看该作者
不错,程序没问题
ID:1071099 发表于 2023-4-17 17:14 | 只看该作者
下载了咋没程序
ID:262 发表于 2023-4-17 19:06 | 只看该作者
瑾璧 发表于 2023-4-17 17:14
下载了咋没程序
main.c这个文件就是程序,如果懒得在文件包里面找 就直接从网页上复制粘贴吧,网页上也有完整的程序
