查看: 8168|回复: 25
51单片机开发板的LCD9648菜单程序无法正常显示
回帖奖励 40 黑币 回复本帖可获得 5 黑币奖励! 每人限 2 次(中奖概率 90%)
普中51单片机,配的LCD9648的屏。直接下载的例程,但无法正常显示。
请那位高手帮忙看下代码有什么问题。
main.c
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. sbit CS0  = P0^0;                //????
  4. sbit RST  = P0^1;                //?′??
  5. sbit RS   = P2^7;                 //êy?Y?üá???????
  6. sbit SCL  = P2^6;                //SPIê±?ó??
  7. sbit SDA  = P2^5;                //SPIêy?Y??
  8. sbit KEY_ADD=P3^3; //按键
  9. sbit KEY_DEC=P3^4;
  10. unsigned char curr,currold;//全局变量,当前箭头位置
  11. unsigned char code user16x16[]={
  12. 0x00,0x00,0x20,0x00,0x30,0x00,0x38,0x00,0x3C,0x00,0x3E,0x00,0x3F,0x00,0x3F,0x80,
  13. 0x3F,0xC0,0x3F,0x80,0x3F,0x00,0x3E,0x00,0x3C,0x00,0x38,0x00,0x30,0x00,0x20,0x00,
  14. };
  15. unsigned char code *MainMenu[]=
  16. {
  17. {"  1.设置1"},
  18. {"  2.设置2"},
  19. {"  3.设置3"},
  20. {"  4.设置4"},
  21. {"  5.设置5"},
  22. {"  6.设置6"},
  23. {"  7.设置7"},
  24. {"  8.设置8"},
  25. {"  9.设置9"},
  26. {"  0.设置0"},
  27. };
  28. void Delay10ms(unsigned int c)   //?ó2? 0us
  29. {
  30.     unsigned char a,b;
  31.     for(;c>0;c--)
  32.         for(b=38;b>0;b--)
  33.             for(a=130;a>0;a--);
  34. }
  35. void  SendDataSPI(unsigned char dat)
  36. {
  37.    unsigned char i;
  38.
  39.    for(i=0; i<8; i++)
  40.    {
  41.       if( (dat&0x80)!=0 ) SDA = 1;
  42.         else SDA = 0;
  43.       dat <<= 1;
  44.           SCL = 0;
  45.       SCL = 1;
  46.    }
  47. }
  48. void WriteComm(unsigned int i)
  49. {
  50.     CS0 = 0;
  51.         RS  = 0;
  52.         SendDataSPI(i);
  53.         CS0 = 1;
  54. }
  55. void WriteData(unsigned char i)
  56. {
  57.     CS0 = 0;
  58.         RS  = 1;
  59.         SendDataSPI(i);
  60.         CS0 = 1;
  61. }
  62. void LCD_Init(void)
  63. {
  64.         unsigned int i;
  65.         //CS0=0;
  66.
  67.         RST=1;
  68.         for(i = 0; i < 1000; i++);
  69.
  70.         RST=0;
  71.         for(i = 0; i < 1000; i++);
  72.         RST=1;
  73.         for(i = 0; i < 1000; i++);
  74.     WriteComm(0xe2);                  //èí?t?′??
  75.         WriteComm(0xc8);                  //0xC8??í¨·??ò????????·′?ò£?0xC0?a?y3£·??ò
  76.         WriteComm(0xa0);                  //0xA0??·??ò?????y3£·??ò£¨0xA1?a·′·??ò
  77.         WriteComm(0x2f);
  78.         WriteComm(0x26);
  79.         WriteComm(0x81);                  //±3?°1a??±è?è
  80.         WriteComm(0x10);
  81.         WriteComm(0xaf);                  //?a????ê?
  82. }
  83. void Clear()
  84. {
  85.         unsigned char i,j;
  86.
  87.         for(i=0; i < 9; i++)
  88.         {
  89.                 WriteComm(0x40);
  90.                 WriteComm(0xb0+i);
  91.                 WriteComm(0x10);
  92.                 WriteComm(0x00);
  93.
  94.                 for(j = 0; j < 96; j++)
  95.                 {
  96.                         WriteData(0x00);
  97.                 }
  98.         }
  99. }
  100. /***********************************************
  101.                 用户自定义字符
  102. ***********************************************/
  103. void CGRAM()
  104. {
  105.      int i;
  106. //     WriteComm(0x30);
  107.
  108.      WriteComm(0x40);
  109.      for(i=0;i<16;i++)
  110.        {
  111.         WriteData(user16x16[i*2]);
  112.         WriteData(user16x16[i*2+1]);
  113.       }
  114. }
  115. /***********************************************
  116.                显示用户自定义字符
  117. ***********************************************/
  118. void DisplayCGRAM(unsigned char x,unsigned char y)
  119. {
  120. switch(y)
  121.      {
  122.    case 1: WriteComm(0xb0+x);break;
  123.    case 2: WriteComm(0xb1+x);break;
  124.    case 3: WriteComm(0xb2+x);break;
  125. //   case 4: WriteComm(0x98+x);break;
  126.       default:break;
  127.   }
  128.     WriteData(00);
  129.     WriteData(00);
  130. }
  131. /***********************************************
  132.                   显示字符串
  133.             x:横坐标值,范围0~8
  134.             y:纵坐标值,范围1~4
  135. ***********************************************/
  136. void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
  137. {
  138. switch(y)
  139.      {
  140.    case 1: WriteComm(0xb0+x);break;
  141.    case 2: WriteComm(0xb1+x);break;
  142.    case 3: WriteComm(0xb2+x);break;
  143. //            case 4: WriteComm(0x98+x);break;
  144.       default:break;
  145.   }
  146. while(*s>0)
  147.    {
  148.       WriteData(*s);
  149.       s++;
  150.       Delay10ms(50);
  151.    }
  152. }
  153. /***********************************************
  154.                      清屏
  155. ***********************************************/
  156. void ClrScreen()
  157. {
  158.    WriteComm(0x01);
  159.    Delay10ms(15);
  160. }
  161.
  162. /***********************************************
  163.                调用显示更新
  164. ***********************************************/
  165. void DisplayUpdata(void)
  166. {
  167.     unsigned char num;
  168.   ClrScreen();
  169. num=sizeof(MainMenu)/sizeof(MainMenu[0]);//判断数组中数值个数
  170. if((0+(curr/4)*4)<num)
  171.       LCD_PutString(0,1,MainMenu[0+(curr/4)*4]);
  172. else //如果超出数组最大元素,则写空信息,不判断此信息可能会出现乱码
  173.    LCD_PutString(0,1,"");
  174. if((1+(curr/4)*4)<num)
  175.    LCD_PutString(0,2,MainMenu[1+(curr/4)*4]);
  176. else
  177.    LCD_PutString(0,2,"");
  178. if((2+(curr/4)*4)<num)
  179.    LCD_PutString(0,3,MainMenu[2+(curr/4)*4]);
  180. else
  181.    LCD_PutString(0,3,"");
  182. if((3+(curr/4)*4)<num)
  183.    LCD_PutString(0,4,MainMenu[3+(curr/4)*4]);
  184. else
  185.    LCD_PutString(0,4,"");
  186. DisplayCGRAM(0,curr%4+1);
  187. }
  188. /***********************************************
  189.                  MAIN
  190. ***********************************************/
  191. void main()
  192. {
  193.    LCD_Init();
  194.    CGRAM(); //写入自定义字符
  195.    DisplayUpdata();
  196.    while(1)
  197.    {
  198.      if(curr!=currold) //光标位置变化,则更新显示
  199.       {
  200.        DisplayUpdata();
  201.        currold=curr;
  202.       }
  203.    if(!KEY_ADD)
  204.     {
  205.      Delay10ms(10);
  206.      if(!KEY_ADD)
  207.     {
  208.         while(!KEY_ADD);
  209.       {
  210.     if(curr<sizeof(MainMenu)/sizeof(MainMenu[0])-1)
  211.      //判断数组中数值个数
  212.      { curr++; }
  213.       }
  214.     }
  215. }
  216.   if(!KEY_DEC)
  217.     {
  218.      Delay10ms(10);
  219.      if(!KEY_DEC)
  220.     {
  221.         while(!KEY_DEC);
  222.       {
  223.        if(curr>0)
  224.      { curr--; }
  225.     }
  226.     }
  227. }
  228.   }
  229. }
ID:96682 发表于 2021-1-17 08:16 来自手机 | 只看该作者
看屏幕出现那么多黑点,可能已经挂了
ID:462723 发表于 2021-1-17 09:59 | 只看该作者
我写入显示图片或者文字的程序,都可以正常显示。
ID:235954 发表于 2021-1-19 08:16 | 只看该作者
屏幕初始化卡住
ID:462723 发表于 2021-1-19 12:57 | 只看该作者
请问能帮忙指出一下屏幕初始化的问题吗?
ID:748788 发表于 2021-1-20 08:34 | 只看该作者
在我的普中a5上试了一下,结果也是花屏,与你那个差不多。看来是程序的问题
ID:748788 发表于 2021-1-20 11:00 | 只看该作者
又用排除法将main里的“CGRAM(); //写入自定义字符”一句注掉,就不会花屏,怀疑该函数将数据写到了不该写入的地方。
ID:462723 发表于 2021-1-20 14:08 | 只看该作者
我将main里的“CGRAM(); ”注掉了。但仍旧出现花屏。
ID:879166 发表于 2021-1-20 14:14 | 只看该作者
图象是静态的还是动态的
ID:748788 发表于 2021-1-20 14:46 | 只看该作者
你在初始化后面插入一段延时,看看延时结束之前会不会花屏
ID:748788 发表于 2021-1-20 14:56 | 只看该作者
另外先确认你的9648屏有没有插错接口
ID:462723 发表于 2021-1-20 17:25 | 只看该作者
屏的接口连接是正确的。因为我写入文字和图片显示程序时,都能正常显示。我试了在初始后面加了不同的延时时间,但仍旧是花屏。
ID:462723 发表于 2021-1-20 17:50 | 只看该作者
接口没有插错。因为文字和图片程序,都能正常显示。试了在初始化后面加不同的延时时间,但仍旧是花屏。
ID:748788 发表于 2021-1-21 08:34 | 只看该作者
你再看看
ID:462723 发表于 2021-1-21 11:59 | 只看该作者
我这个连接口没有错,是连到你发的一个图片的位置。我又下载了文字显示程序试了,可以正常显示。
ID:748788 发表于 2021-1-21 21:33 | 只看该作者
能正常显示说明两个接口有部分线路相通,不等于另一个接口是多余的。为什么厂家要提供一个12864接口,算计精明的厂家不会随便堆料吧
ID:722618 发表于 2021-1-25 12:16 | 只看该作者
将main里的“CGRAM();修改成其他的。另外可能是接触问题,由于显示屏管脚比较多,某一个接触不好也有可能。
ID:462723 发表于 2021-1-25 18:47 | 只看该作者
接触应该没问题,因为我试了显示文字和图片,都能正常显示。能具体说一下怎么将main里的“CGRAM();修改成其他的吗?
ID:811405 发表于 2021-1-27 11:30 | 只看该作者
屏幕本身如果没有问题,那就是程序问题,我的是屏幕根本没有任何显示
ID:462723 发表于 2021-1-28 21:08 | 只看该作者
是的,应该是程序的问题。有那位高手能帮忙看下是什么问题吗?
ID:860433 发表于 2021-3-19 02:52 来自手机 | 只看该作者
遇到了同样的问题,错误出在头文件里的字模是写成"字",点阵。而字模提取的软件里生成的直接就是点阵。我刚开始也没注意直接复制粘贴了,找了好久
ID:860433 发表于 2021-3-19 03:41 来自手机 | 只看该作者
除此之外,代码还有bug,用lcd9648的话显示不了文字“三”,包括判断和点阵那里都改用“③”,屏幕里会显示“三”。我已经气个半死了。
ID:462723 发表于 2021-3-21 22:42 | 只看该作者
hvdvsjd 发表于 2021-3-19 03:41
除此之外,代码还有bug,用lcd9648的话显示不了文字“三”,包括判断和点阵那里都改用“③”,屏幕里会显示 ...
能帮忙发送一下你修改了的给我吗?
ID:884042 发表于 2021-4-11 11:26 | 只看该作者
大哥,LCD9648是插在12864上的,你咋整到1602上了呢?
ID:884042 发表于 2021-4-11 11:29 | 只看该作者
zhanghu29 发表于 2021-3-21 22:42
能帮忙发送一下你修改了的给我吗?
这是由于KELL软件的BUG,不能显示“三”,要在前面加上'"/",如:/三
ID:1019630 发表于 2022-4-19 08:45 | 只看该作者
楼主的lcd9648显示屏还在吗
