查看: 2743|回复: 0
使用STC15W4K系列单片机的PWM实现渐变灯实例程序
ID:878906 发表于 2021-1-20 15:47 | 显示全部楼层 |阅读模式
#include "reg51.h"
#define CYCLE   0x1000L     //定义PWM周期
#define PWMC        (*(unsigned int  volatile xdata *)0xfff0)
#define PWMCH       (*(unsigned char volatile xdata *)0xfff0)
#define PWMCL       (*(unsigned char volatile xdata *)0xfff1)
#define PWMCKS      (*(unsigned char volatile xdata *)0xfff2)
#define PWM2T1      (*(unsigned int  volatile xdata *)0xff00)
#define PWM2T1H     (*(unsigned char volatile xdata *)0xff00)
#define PWM2T1L     (*(unsigned char volatile xdata *)0xff01)
#define PWM2T2      (*(unsigned int  volatile xdata *)0xff02)
#define PWM2T2H     (*(unsigned char volatile xdata *)0xff02)
#define PWM2T2L     (*(unsigned char volatile xdata *)0xff03)
#define PWM2CR      (*(unsigned char volatile xdata *)0xff04)
#define PWM3T1      (*(unsigned int  volatile xdata *)0xff10)
#define PWM3T1H     (*(unsigned char volatile xdata *)0xff10)
#define PWM3T1L     (*(unsigned char volatile xdata *)0xff11)
#define PWM3T2      (*(unsigned int  volatile xdata *)0xff12)
#define PWM3T2H     (*(unsigned char volatile xdata *)0xff12)
#define PWM3T2L     (*(unsigned char volatile xdata *)0xff13)
#define PWM3CR      (*(unsigned char volatile xdata *)0xff14)
#define PWM4T1      (*(unsigned int  volatile xdata *)0xff20)
#define PWM4T1H     (*(unsigned char volatile xdata *)0xff20)
#define PWM4T1L     (*(unsigned char volatile xdata *)0xff21)
#define PWM4T2      (*(unsigned int  volatile xdata *)0xff22)
#define PWM4T2H     (*(unsigned char volatile xdata *)0xff22)
#define PWM4T2L     (*(unsigned char volatile xdata *)0xff23)
#define PWM4CR      (*(unsigned char volatile xdata *)0xff24)
#define PWM5T1      (*(unsigned int  volatile xdata *)0xff30)
#define PWM5T1H     (*(unsigned char volatile xdata *)0xff30)
#define PWM5T1L     (*(unsigned char volatile xdata *)0xff31)
#define PWM5T2      (*(unsigned int  volatile xdata *)0xff32)
#define PWM5T2H     (*(unsigned char volatile xdata *)0xff32)
#define PWM5T2L     (*(unsigned char volatile xdata *)0xff33)
#define PWM5CR      (*(unsigned char volatile xdata *)0xff34)
#define PWM6T1      (*(unsigned int  volatile xdata *)0xff40)
#define PWM6T1H     (*(unsigned char volatile xdata *)0xff40)
#define PWM6T1L     (*(unsigned char volatile xdata *)0xff41)
#define PWM6T2      (*(unsigned int  volatile xdata *)0xff42)
#define PWM6T2H     (*(unsigned char volatile xdata *)0xff42)
#define PWM6T2L     (*(unsigned char volatile xdata *)0xff43)
#define PWM6CR      (*(unsigned char volatile xdata *)0xff44)
#define PWM7T1      (*(unsigned int  volatile xdata *)0xff50)
#define PWM7T1H     (*(unsigned char volatile xdata *)0xff50)
#define PWM7T1L     (*(unsigned char volatile xdata *)0xff51)
#define PWM7T2      (*(unsigned int  volatile xdata *)0xff52)
#define PWM7T2H     (*(unsigned char volatile xdata *)0xff52)
#define PWM7T2L     (*(unsigned char volatile xdata *)0xff53)
#define PWM7CR      (*(unsigned char volatile xdata *)0xff54)
sfr PIN_SW2 =   0xba;
sfr P0M1    =   0x93;
sfr P0M0    =   0x94;
sfr P1M1    =   0x91;
sfr P1M0    =   0x92;
sfr P2M1    =   0x95;
sfr P2M0    =   0x96;
sfr P3M1    =   0xb1;
sfr P3M0    =   0xb2;
sfr P4M1    =   0xb3;
sfr P4M0    =   0xb4;
sfr P5M1    =   0xC9;
sfr P5M0    =   0xCA;
sfr P6M1    =   0xCB;
sfr P6M0    =   0xCC;
sfr P7M1    =   0xE1;
sfr P7M0    =   0xE2;
sfr PWMCFG  =   0xf1;
sfr PWMCR   =   0xf5;
sfr PWMIF   =   0xf6;
sfr PWMFDCR =   0xf7;
void pwm_isr() interrupt 22 using 1
    static bit dir = 1;
    static int val = 0;
    if (PWMIF & 0x40)
        PWMIF &= ~0x40;
        if (dir)
            val++;
            if (val >= CYCLE) dir = 0;
            val--;
            if (val <= 1) dir = 1;
        PIN_SW2 |= 0x80;
        PWM2T2 = val;
        PIN_SW2 &= ~0x80;
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    P6M0 = 0x00;
    P6M1 = 0x00;
    P7M0 = 0x00;
    P7M1 = 0x00;
    PIN_SW2 |= 0x80;                //使能访问XSFR
    PWMCFG = 0x00;                  //配置PWM的输出初始电平为低电平
    PWMCKS = 0x00;                  //选择PWM的时钟为Fosc/1
    PWMC = CYCLE;                   //设置PWM周期
    PWM2T1 = 0x0000;                //设置PWM2第1次反转的PWM计数
    PWM2T2 = 0x0001;                //设置PWM2第2次反转的PWM计数
                                    //占空比为(PWM2T2-PWM2T1)/PWMC
    PWM2CR = 0x00;                  //选择PWM2输出到P3.7,不使能PWM2中断
    PWMCR = 0x01;                   //使能PWM信号输出
    PWMCR |= 0x40;                  //使能PWM归零中断
    PWMCR |= 0x80;                  //使能PWM模块
    PIN_SW2 &= ~0x80;
    EA = 1;
    while (1);
