查看: 1978|回复: 2
stc89c52 lcd1602 秒表
ID:812531 发表于 2021-1-21 15:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
#define uint unsigned int
#define LCD_data P0
sbit LCD_RS=P1^0;
sbit LCD_RW=P1^1;
sbit LCD_EN=P2^5;
sbit LCD_PSB=P1^3;
sbit dula=P2^0;
sbit wela=P2^1;
sbit cs88=P2^2;
sbit key=P3^4;
void delayms(unsigned int xms)
  unsigned i,j;
         for(i=xms;i>0;i--)
            for(j=110;j>0;j--);
void cmg88()
dula=0;
        P0=0x00;
        dula=0;
        cs88=0x00;
        P0=0x00;
#define delayNOP();{_nop_();_nop_();_nop_();_nop_();};
uchar IRDIS[2] ;
uchar IRCOM[4] ;
void delay0 (uchar x); //x*0.14MS
void beep();
void dataconv() ;
void lcd_pos(uchar X,uchar Y);
void delay(int ms)
while (ms--)
uchar i;
for (i=0;i<250;i++)
_nop_();
_nop_();
_nop_();
_nop_();
bit lcd_busy()
bit result ;
LCD_RS=0;
LCD_RW=1;
LCD_EN=1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN=0;
return (result) ;
void lcd_wcmd(uchar cmd)
while(lcd_busy()) ;
LCD_RS=0;
LCD_RW=0;
LCD_EN=0;
_nop_();
_nop_();
P0=cmd;
delayNOP ()
LCD_EN=1;
delayNOP ()
LCD_EN=0;
void lcd_wdat(uchar dat)
while(lcd_busy()) ;
LCD_RS=1;
LCD_RW = 0;
LCD_EN=0;
P0=dat;
delayNOP () ;
LCD_EN=1;
delayNOP ();
LCD_EN=0;
void charter(unsigned char y,unsigned char x,unsigned char dat)
        if(y==1)
                lcd_wcmd(0x80|x);
        if(y==2)
        lcd_wcmd(0x90|x);
        if(y==3)
                lcd_wcmd((0x80|x)+8);
        if(y==4)
      lcd_wcmd((0x90|x)+8);
lcd_wdat(dat);
void gotoxy(unsigned char y, unsigned char x,uchar *str)
        if(y==1)
                lcd_wcmd(0x80|x);
        if(y==2)
        lcd_wcmd(0x90|x);
        if(y==3)
        if(y==4)
                                  while(*str!='\0')
                lcd_wdat(*str);
                str++;
void print(uchar *str)
        while(*str!='\0')
                lcd_wdat(*str);
                str++;
void lcd_init()
LCD_PSB=1;
lcd_wcmd(0x34) ;
delay(5) ;
lcd_wcmd(0x30) ;
delay(5) ;
lcd_wcmd(0x0c) ;
delay(5) ;
lcd_wcmd(0x01) ;
delay(5) ;
main()
        unsigned char i;
lcd_init();
                charter(1,0,'0'+3);
        //lcd_wcmd(0x80+7);
        //lcd_wdat('0'+i);
        //delayms(5);
        //if(key==0)
                //delayms(5);
        //        if(key==0)
//        i=3;
        //        while(!key);
        gotoxy(3,0,"考研路上不孤单");
void Read_Busy()
        uchar busy;
        P0 = 0xff;
        RS = 0;
        RW = 1;
        do
                EN = 1;
                busy = P0;
                EN = 0;
        }while(busy & 0x80);
//?LCD1602??????
void Write_Cmd(uchar cmd)
        Read_Busy();//???
        RS = 0;
        RW = 0;
        P0 = cmd;
        EN = 1;
        EN = 0;
void Write_Dat(uchar dat)
        Read_Busy();
        RS = 1;
        RW = 0;
        P0 = dat;
        EN = 1;
        EN = 0;
void charter(unsigned char x,unsigned char y,unsigned char dat)
if(y==0)
Write_Cmd(0x80+x);
Write_Cmd(0xc0+x);
Write_Dat( dat);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
Write_Cmd(0x80 + x);
Write_Cmd(0xC0 + x);
while (*s)
Write_Dat( *s);
s ++;
void lcdinit()
   Write_Cmd(0x38);
   Write_Cmd(0x08);    /*????*/
   Write_Cmd(0x01);    /*????*/
   Write_Cmd(0x06);    /*????????*/
   Write_Cmd(0x0C);    /*????????*/
void Timer0Init(void)                //50??@11.0592MHz
        TMOD = 0x01;                //???????
       TH0=0xdc;               //10ms??
   TL0=0x00;
                ET0=1;
        EA=1;
        TR0 = 0;                //???0????
void beep()
    unsigned char y;
    for (y=0;y<180;y++)
      BEEP=!BEEP;                //BEEP??
          delayms(70);
    BEEP=1;                      //?????
unsigned char num,num1,u;
lcdinit();
Timer0Init();
        LCD_Write_String(0,1,"time:");
        LCD_Write_String(5,0,"welcome");
        LCD_Write_String(5,1,"00:00:00:00");
if(key==0)
        delayms(50);
if(key==0)
num=num+1;
while(!key);
switch(num)
        case 1:TR0=1;
        LCD_Write_String(0,0,"begin count 1");
                delayms(5);
        break;
        case 2:TR0=0;
                LCD_Write_String(0,0,"pause count 2");
        delayms(5);
        break;
        case 3:TR0=1;
                LCD_Write_String(0,0,"begin count 3");
        delayms(5);
        break;
        case 4:TR0=0;
                LCD_Write_String(0,0,"pause count 4");
        delayms(5);
        break;
if(key1==0)
void timer() interrupt 1
TH0=0xdc;
   TL0=0x00;
  a++;
        charter(15,1,'0'+a);
if(a==10)
        a=0;
        b++;
        x=b%10;
                charter(14,1,'0'+x);
if(b==10)
        b=0;
c++;
        y=c%10;
        charter(12,1,'0'+y);
if(c==10)
c=0;
        d++;
        z=d%10;
        charter(11,1,'0'+z);
if(d==6)
d=0;
                charter(11,1,'0'+0);
        e++;
        m=e%10;
        charter(9,1,'0'+m);
if(e==10)
e=0;
        f++;
        n=f%10;
                charter(8,1,'0'+n);
ID:876099 发表于 2021-2-1 02:08 | 只看该作者
没有原理图吗
ID:812531 发表于 2021-2-2 10:37 | 只看该作者
没有  因为是在自己的板子上写的   不需要仿真  所以没有
