用STC15F104 红外遥控 功能正常 需要修改 按键长按一直输出低电平 放开恢复高电平 2路这个功能 其它不变有时间的老大帮忙修改
由于本论坛禁止直接求程序,禁止伸手党,所以向大家请教一下大致的实现方法与思路,理清头绪后我自己来写程序去实现
#include <STC15F104E.H>
#define CPU_Fosc 12//STC15F104E
#define M 1//???1T??
#define Tc 250 //250us??
#define Th (65536-CPU_Fosc*Tc/M)/256
#define Tl (65536-CPU_Fosc*Tc/M)%256
#define uint unsigned int
#define ulong unsigned long
#define ma1 0xbf01 //???/???
sbit K1=P3^0;//K1
sbit K2=P3^1;//K2
sbit K3=P3^2;//K3
sbit K4=P3^3;//K4
sbit KZ=P3^4;//继电器1
sbit IR=P3^5; //红外接收
bit IR_ok,state;
ulong longcode;
uint OKCode;
uint Tick,step;
uchar Count;
bit IRsync;
bit IRb,IRa,IR_ok;
void Delay(uint t);
uchar reverse8( uchar c );
void InitTimer();
P3=0xff;
InitTimer();
if(IR_ok)
if(OKCode==0xff5c) //
KZ=~KZ;
if(OKCode==0xff18) //K1
K1=0;
Delay(50);
K1=1;
if(OKCode==0xff1a) //K2
K2=0;
Delay(50);
K2=1;
if(OKCode==0xff1b) //K3
K3=0;
Delay(50);
K3=1;
if(OKCode==0xff17) //K4
K4=0;
Delay(50);
K4=1;
IR_ok=0;
void InitTimer()
AUXR=0xc0;
TMOD = 0x00;
TH0=Th;
TL0=Tl;
EA=ET0=TR0=1;
void timer0() interrupt 1
if(IR_ok)
return;
IRb = IRa; //??????
IRa = IR; //??????
++step;
if(IRb && !IRa) //?????(???,???)
Tick = step;
step=0;
if(Tick>(14000/Tc))
IRsync=0;
else if(IRsync)
if(Tick>(3000/Tc))
IRsync=0;
longcode<<=1;
if(Tick>(1500/Tc))
longcode|=1;
if (--Count==0)
uchar x,y;
x= longcode;
y= longcode>>8;
if(x=~y)
OKCode =longcode>>8;
OKCode=reverse8(OKCode/256)*256|reverse8(OKCode);
IRsync=0;
IR_ok=1;
else if(Tick>(13500/Tc-2)&&Tick<(13500/Tc+2))
IRsync=1;
Count=32;
c = ( c & 0x55 ) << 1 | ( c & 0xAA )>> 1;
c = ( c & 0x33 ) << 2 | ( c & 0xCC )>> 2;
c = ( c & 0x0F ) << 4 | ( c & 0xF0 )>> 4;
return c;
void Delay(uint t)
uchar a,b;
for(; t>0; t--)
for(b=222; b>0; b--)
for(a=12; a>0; a--)
