查看: 1609|回复: 3
有关GH1621的MCU驱动程序问题
ID:438796 发表于 2021-3-31 11:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
20黑币
我现在用GN1621驱动液晶屏,不能单独操作SEG口,我想给SEG9一个0xf0,液晶屏全亮了。有有大佬知道问题吗?
#define  unchar     unsigned char #define  unint      unsigned int
#define  unlong     unsigned long
#define CS                RC0                                        //片选端
//#define        RD                RC1                                        //读数据时钟
#define WR                RC1                                        //写数据时钟
#define DATA        RC4                                        //串行数据端
void DelayUs(unsigned char Time)
        unsigned char a;
        for(a=0;a<Time;a++)
                CLRWDT();
void delay(void)
        unchar i;
        for(i=0;i<200;i++);
void delay_ms(unsigned char Time)
        unsigned char a,b;
        for(a=0;a<Time;a++)
                for(b=0;b<5;b++)
                         DelayUs(197);                   //快1%
void write_byte(unchar byte,unchar length)
        unchar i;
        for(i=0;i<length;i++)
                WR = 0;
                delay();
                if(byte & 0X80)
                        DATA = 1;                        //高位先传
                        DATA = 0;
                byte <<= 1;
                WR = 1;        //WR上升沿锁存
                delay();
void Write_dat(unchar dat)                //写数据
        unchar i;
        CS = 1;
        delay();
        CS = 0;        //片选低电平使能
        write_byte(0XA0,3);                                //传3位命令码101
        write_byte(0X09,6);                                //传6位地址码,起始地址00H
        for(i=0;i<32;i++)
                write_byte(dat,4);                //传4位数据。高位先传
void Write_dat1(unchar Addr,unchar dat)                //写数据
        unchar i;
        CS = 1;
        delay();
        CS = 0;        //片选低电平使能
        write_byte(Addr,6);                                //传6位地址码,起始地址00H
        for(i=0;i<8;i++)
void Write_cmd(unchar cmd)                //写指令
        CS = 1;
        delay();
        CS = 0;
        write_byte(0X80,3);                                //传3位命令码100
        write_byte(cmd,9);                                //传9位指令
void lcd_init(void)
        delay_ms(100);
        Write_cmd(0x01);                                        //开启系统时钟
        Write_cmd(0X18);                                        //内部RC震荡
//  Write_cmd(0X14);                                        //晶体振荡
////        Write_cmd(0X07);          //允许WDT暂停标志输出
////        Write_cmd(0X88);          //允许IRQ输出
////        Write_cmd(0X60);          //蜂鸣频率:2KHz
        Write_cmd(0x29);                                        //1/3偏置,4COM
        Write_dat(0x00);                                        //RAM清零
        Write_cmd(0x03);                                        //开显示
*  函数名:POWER_INITIAL
*        功能:  上电系统初始化
*  输入:  无
*  输出:  无
void POWER_INITIAL (void)
        OSCCON = 0B01110001;        //WDT 32KHZ IRCF=111=16MHZ/2=8MHZ,0.125US/T
                                                         //Bit0=1,系统时钟为内部振荡器
                                                         //Bit0=0,时钟源由FOSC<2:0>决定即编译选项时选择
        INTCON = 0;                          //暂禁止所有中断
        PORTA = 0B00000000;
        TRISA = 0B00000000;                //PA输入输出 0-输出 1-输入
                                                        //PA3->输出
        PORTC = 0B00000000;
        TRISC = 0B00000000;                //PC输入输出 0-输出 1-输入
        WPUA = 0B00000000;             //PA端口上拉控制 1-开上拉 0-关上拉
        WPUC = 0B00000000;             //PC端口上拉控制 1-开上拉 0-关上拉
        OPTION = 0B00001000;        //Bit3=1 WDT MODE,PS=000=1:1 WDT RATE
                                                         //Bit7(PAPU)=0 ENABLED PULL UP PA
        MSCKCON = 0B00000000;        //Bit6->0,禁止PA4,PC5稳压输出
                                                          //Bit5->0,TIMER2时钟为Fosc
                                                          //Bit4->0,禁止LVR
        CMCON0 = 0B00000111;         //关闭比较器,CxIN为数字IO口
*  函数名: main
*        功能:  主函数
*  输入:  无
*  输出:  无
        POWER_INITIAL();                        //系统初始化
    lcd_init();
//Write_dat1(0x16,0x00);
//Write_dat1(0x15,0x00);
//Write_dat1(0x14,0x00);
//Write_dat1(0x13,0x00);
//Write_dat1(0x12,0x00);
//Write_dat1(0x11,0x00);
//Write_dat1(0x10,0x00);
//Write_dat1(0x0F,0x00);
//Write_dat1(0x0E,0x00);
//Write_dat1(0x0D,0x00);
//Write_dat1(0x0C,0x00);
//Write_dat1(0x0B,0x00);
//Write_dat1(0x0A,0x00);
Write_dat1(0x09,0xf0);
ID:584814 发表于 2021-3-31 20:26 | 只看该作者
1621驱动液晶屏可以任意点亮任意字段的
ID:438796 发表于 2021-4-30 13:49 | 只看该作者
//        unchar i;
        CS = 1;
        delay();
        CS = 0;        //片选低电平使能
        write_byte(Addr<<2,6);                                //传6位地址码,起始地址00H
}这样就可以了
ID:357396 发表于 2022-3-27 15:17 | 只看该作者
如下
  1. void Write_dat1(unchar Addr,unchar dat)                //写数据
  2. {
  3. //        unchar i;
  4.         CS = 1;
  5.         delay();
  6.         CS = 0;        //片选低电平使能
  7.         write_byte(0XA0,3);                                //传3位命令码101
  8.         write_byte(Addr<<2,6);                                //传6位地址码,起始地址00H
  9.         write_byte(dat,4);                //传4位数据。高位先传
  10. }这样就可以了
