主函数
#include <reg52.h>
#include <intrins.h>
#include "LCD12864.h"
#include "timer1.h"
#include "ADC0832.h"
#include "DS18B20.h"
#include "eepom52.h"
#include "HC_SR04.h"
sbit beep = P2^0;
sbit setKey = P3^3;
sbit addKey = P3^4;
sbit subKey = P3^5;
int S;
float dataV[4]= {0};
unsigned char dataTH[8]={110,30, 99, 30, 8,2, 45, 15};
unsigned char lcd[8] = {0};
void alarm();
void delay(unsigned int i){
while(i--);
float pre_ph_v, phv;
void setKeyDeal();
void addKeyDeal();
void subKeyDeal();
//³õʼ»¯eeprom
void init_eeprom(){
unsigned char is_first_init = byte_read(0x2020);
if(is_first_init == 1){
dataTH[0] = byte_read(0x2000);
dataTH[1] = byte_read(0x2001);
dataTH[2] = byte_read(0x2002);
dataTH[3] = byte_read(0x2003);
dataTH[4] = byte_read(0x2004);
dataTH[5] = byte_read(0x2005);
dataTH[6] = byte_read(0x2006);
dataTH[7] = byte_read(0x2007);
}else{
SectorErase(0x2000);
byte_write(0x2000, dataTH[0]);
byte_write(0x2001, dataTH[1]);
byte_write(0x2002, dataTH[2]);
byte_write(0x2003, dataTH[3]);
byte_write(0x2004, dataTH[4]);
byte_write(0x2005, dataTH[5]);
byte_write(0x2006, dataTH[6]);
byte_write(0x2007, dataTH[7]);
byte_write(0x2020, 1);
//¸üÐÂeeprom´æ´¢µÄÊý¾Ý
void update_eeprom(){
void updateLCD(){
dataV[0] = get_0832_AD_data(0); //PH
dataV[1] = get_hc_sr04_distance(); //SW
dataV[2] = get_0832_AD_data(1); //ZD
dataV[3] = Get18B20Temp(); //WD
phv = -58.87*(dataV[0]*5.0/255.0) + 216.77;
if(phv > 141 || phv < 0 ) { phv = pre_ph_v; }
pre_ph_v = phv;
lcd[0] = ((int)phv)%1000/100+48;
lcd[1] = ((int)phv)%100/10 + 48;
lcd[2] = '.';
lcd[3] = ((int)phv)%10 + 48;
lcd[4] = '\0';
PutStr(0,1, lcd);
dataV[0] = phv;
dataV[2] = dataV[2] /2.55;
if(dataV[2] > 99) dataV[2] = 99;
lcd[0] = ((int)dataV[2])%100/10 + 48;
lcd[1] = ((int)dataV[2])%10 + 48;
lcd[2] = '\0';
PutStr(1,1, lcd);
//dataV[1] = 10 - (dataV[1]-40) /19;
//if(dataV[1] > 10) dataV[1] = 10;
//if(dataV[1] < 0) dataV[1] = 0;
lcd[0] = ((int)dataV[1])%100/10 + 48;
lcd[1] = ((int)dataV[1])%10 + 48;
lcd[2] = '\0';
PutStr(2,1, lcd);
lcd[0] = ((int)dataV[3])%100/10 + 48;
lcd[1] = ((int)dataV[3])%10 + 48;
lcd[2] = '\0';
PutStr(3,1, lcd);
void updateTH(){
lcd[0] = ((int)dataTH[0])%1000/100+48;
lcd[1] = ((int)dataTH[0])%100/10 + 48;
lcd[2] = '\0';
PutStr(0,4, lcd);
lcd[0] = ((int)dataTH[1])%1000/100+48;
lcd[1] = ((int)dataTH[1])%100/10 + 48;
lcd[2] = '\0';
PutStr(0,7, lcd);
lcd[0] = ((int)dataTH[2])%100/10+48;
lcd[1] = ((int)dataTH[2])%10 + 48;
lcd[2] = '\0';
PutStr(1,4, lcd);
lcd[0] = ((int)dataTH[3])%100/10+48;
lcd[1] = ((int)dataTH[3])%10 + 48;
lcd[2] = '\0';
PutStr(1,7, lcd);
lcd[0] = ((int)dataTH[4])%100/10+48;
lcd[1] = ((int)dataTH[4])%10 + 48;
lcd[2] = '\0';
PutStr(2,4, lcd);
lcd[0] = ((int)dataTH[5])%100/10+48;
lcd[1] = ((int)dataTH[5])%10 + 48;
lcd[2] = '\0';
PutStr(2,7, lcd);
lcd[0] = ((int)dataTH[6])%100/10+48;
lcd[1] = ((int)dataTH[6])%10 + 48;
lcd[2] = '\0';
PutStr(3,4, lcd);
lcd[0] = ((int)dataTH[7])%100/10+48;
lcd[1] = ((int)dataTH[7])%10 + 48;
lcd[2] = '\0';
PutStr(3,7, lcd);
void timer1(){
updateLCD();
updateTH();
alarm();
void main(){
init_hc_sr04();
DS18B20Init();
LcmInit(); //LCD12864³õʼ»¯
LcmClearTXT(); //LCD12864ÇåÆÁ
init_eeprom();
timer1_start(1000, timer1);
PutStr(0,0, "PH H L ");
PutStr(1,0, "ZD H L ");
PutStr(2,0, "SW H L ");
PutStr(3,0, "WD H L ");
while(1){
setKeyDeal();
addKeyDeal();
subKeyDeal();
void alarm(){//±¨¾¯
if( (int)dataV[0] > dataTH[0] || (int)dataV[0] < dataTH[1] || \
(int)dataV[2] > dataTH[2] || (int)dataV[2] < dataTH[3] || \
(int)dataV[1] > dataTH[4] || (int)dataV[1] < dataTH[5] || \
(int)dataV[3] > dataTH[6] || (int)dataV[3] < dataTH[7] \
//beep=0;
}else{
beep=1;
char flagSet = 0;
void setDeal(){
switch(flagSet){
case 0: PutStr(3,6, " "); break;
case 1: PutStr(0,3, "*"); break;
case 2: PutStr(0,6, "*"); PutStr(0,3, " "); break;
case 3: PutStr(1,3, "*"); PutStr(0,6, " "); break;
case 4: PutStr(1,6, "*"); PutStr(1,3, " "); break;
case 5: PutStr(2,3, "*"); PutStr(1,6, " "); break;
case 6: PutStr(2,6, "*"); PutStr(2,3, " "); break;
case 7: PutStr(3,3, "*"); PutStr(2,6, " "); break;
case 8: PutStr(3,6, "*"); PutStr(3,3, " "); break;
void setKeyDeal(){
setKey = 1;
if(setKey == 0){
delay(1000);
if(setKey == 0){
flagSet++;
if(flagSet > 8){ flagSet = 0; }
setDeal();
while(setKey == 0);
void addKeyDeal(){
addKey = 1;
if(addKey == 0 && flagSet > 0){
delay(1000);
if(addKey == 0){
switch(flagSet){
case 1: if(dataTH[0] < 141) dataTH[0]+=10; break;
case 2: if(dataTH[1] < dataTH[0]) dataTH[1]+=10; break;
case 3: if(dataTH[2] < 99) dataTH[2]++; break;
case 4: if(dataTH[3] < dataTH[2]) dataTH[3]++; break;
case 5: if(dataTH[4] < 10) dataTH[4]++; break;
case 6: if(dataTH[5] < dataTH[4]) dataTH[5]++; break;
case 7: if(dataTH[6] < 99) dataTH[6]++; break;
case 8: if(dataTH[7] < dataTH[6]) dataTH[7]++; break;
updateTH();
update_eeprom();
while(addKey == 0);
void subKeyDeal(){
subKey = 1;
if(subKey == 0 && flagSet > 0){
delay(1000);
if(subKey == 0){
switch(flagSet){
case 1: if(dataTH[0] > dataTH[1]+10) dataTH[0]-=10; break;
case 2: if(dataTH[1] > 10) dataTH[1]-=10; break;
case 3: if(dataTH[2] > dataTH[3]) dataTH[2]--; break;
case 4: if(dataTH[3] > 0) dataTH[3]--; break;
case 5: if(dataTH[4] > dataTH[5]) dataTH[4]--; break;
case 6: if(dataTH[5] > 0) dataTH[5]--; break;
case 7: if(dataTH[6] > dataTH[7]) dataTH[6]--; break;
case 8: if(dataTH[7] > 0) dataTH[7]--; break;
updateTH();
update_eeprom();
while(subKey == 0);
超声波函数
unsigned char FLAG_OVERFLOW = 0; //³¬Éù²¨Ê±¼ä¹ý³¤Òç³ö±êÖ¾
//10us
void delay10us(unsigned int i)
while(i--);
void init_hc_sr04()
TRIG = 0;
TMOD &= 0xf0;
TMOD |= 0x01;
TH0 = 0x3c;
TL0 = 0xb0;
TF0 = 0;
ET0 = 1;
PT0 = 1;
EA = 1;
void timer0() interrupt 1
FLAG_OVERFLOW=1;
int get_hc_sr04_distance(void){
unsigned int distance;
TH0 = 0x3c;
TL0 = 0xb0;
TR0 = 0;
FLAG_OVERFLOW = 0;
TRIG = 1;
delay10us(2);
TRIG = 0;
TR0 = 1;
while(!ECHO && FLAG_OVERFLOW == 0);
TH0 = 0x3c;
TL0 = 0xb0;
TR0 = 1;
while(ECHO && FLAG_OVERFLOW == 0);
TR0 = 0;
distance = TH0 << 8 | TL0;
distance = (distance-15536)/58;
if(FLAG_OVERFLOW == 1){
FLAG_OVERFLOW = 0;
distance = 999;
return (distance);
