- //EEPROM多字节多扇区读写应用示例
- #include <reg52.h> //52系列单片机头文件
- #include <intrins.h>
- #include <stdlib.h> //包含产生随机数用到的rand()函数。
- #define uchar unsigned char
- #define uint unsigned int
- //定义ISP的操作命令
- #define RdCommand 0x01 //读命令
- #define PrgCommand 0x02 //写命令
- #define EraseCommand 0x03 //擦除命令
- #define WaitTime 0x01 //定义CPU的等待时间,写入硬件延时
- /*STC89系列EEPROM寄存器声明*/
- sfr ISP_DATA=0xe2; //0000,0000 EEPROM数据寄存器
- sfr ISP_ADDRH=0xe3; //0000,0000 EEPROM地址高字节
- sfr ISP_ADDRL=0xe4; //0000,0000 EEPROM地址第字节
- sfr ISP_CMD=0xe5; //xxxx,xx00 EEPROM命令寄存器
- sfr ISP_TRIG=0xe6; //0000,0000 EEPRPM命令触发寄存器
- sfr ISP_CONTR=0xe7; //0000,x000 EEPROM控制寄存器
- sbit LED1=P1^0;
- sbit LED2=P1^7;
- /* 测试常量数组 */
- uchar code table[512] =
- 0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,
- 0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1a,0x1b,0x1c,0x1d,0x1e,0x1f,
- 0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2a,0x2b,0x2c,0x2d,0x2e,0x2f,
- 0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x3b,0x3c,0x3d,0x3e,0x3f,
- 0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x4b,0x4c,0x4d,0x4e,0x4f,
- 0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5a,0x5b,0x5c,0x5d,0x5e,0x5f,
- 0x60,0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x6b,0x6c,0x6d,0x6e,0x6f,
- 0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f,
- 0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f,
- 0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f,
- 0xa0,0xa1,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa8,0xa9,0xaa,0xab,0xac,0xad,0xae,0xaf,
- 0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xbb,0xbc,0xbd,0xbe,0xbf,
- 0xc0,0xc1,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9,0xca,0xcb,0xcc,0xcd,0xce,0xcf,
- 0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xdb,0xdc,0xdd,0xde,0xdf,
- 0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xeb,0xec,0xed,0xee,0xef,
- 0xf0,0xf1,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfe,0xff,
- 0xff,0xfe,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf3,0xf2,0xf1,0xf0,
- 0xef,0xee,0xed,0xec,0xeb,0xea,0xe9,0xe8,0xe7,0xe6,0xe5,0xe4,0xe3,0xe2,0xe1,0xe0,
- 0xdf,0xde,0xdd,0xdc,0xdb,0xda,0xd9,0xd8,0xd7,0xd6,0xd5,0xd4,0xd3,0xd2,0xd1,0xd0,
- 0xcf,0xce,0xcd,0xcc,0xcb,0xca,0xc9,0xc8,0xc7,0xc6,0xc5,0xc4,0xc3,0xc2,0xc1,0xc0,
- 0xbf,0xbe,0xbd,0xbc,0xbb,0xba,0xb9,0xb8,0xb7,0xb6,0xb5,0xb4,0xb3,0xb2,0xb1,0xb0,
- 0xaf,0xae,0xad,0xac,0xab,0xaa,0xa9,0xa8,0xa7,0xa6,0xa5,0xa4,0xa3,0xa2,0xa1,0xa0,
- 0x9f,0x9e,0x9d,0x9c,0x9b,0x9a,0x99,0x98,0x97,0x96,0x95,0x94,0x93,0x92,0x91,0x90,
- 0x8f,0x8e,0x8d,0x8c,0x8b,0x8a,0x89,0x88,0x87,0x86,0x85,0x84,0x83,0x82,0x81,0x80,
- 0x7f,0x7e,0x7d,0x7c,0x7b,0x7a,0x79,0x78,0x77,0x76,0x75,0x74,0x73,0x72,0x71,0x70,
- 0x6f,0x6e,0x6d,0x6c,0x6b,0x6a,0x69,0x68,0x67,0x66,0x65,0x64,0x63,0x62,0x61,0x60,
- 0x5f,0x5e,0x5d,0x5c,0x5b,0x5a,0x59,0x58,0x57,0x56,0x55,0x54,0x53,0x52,0x51,0x50,
- 0x4f,0x4e,0x4d,0x4c,0x4b,0x4a,0x49,0x48,0x47,0x46,0x45,0x44,0x43,0x42,0x41,0x40,
- 0x3f,0x3e,0x3d,0x3c,0x3b,0x3a,0x39,0x38,0x33,0x36,0x35,0x34,0x33,0x32,0x31,0x30,
- 0x2f,0x2e,0x2d,0x2c,0x2b,0x2a,0x29,0x28,0x27,0x26,0x25,0x24,0x23,0x22,0x21,0x20,
- 0x1f,0x1e,0x1d,0x1c,0x1b,0x1a,0x19,0x18,0x17,0x16,0x15,0x14,0x13,0x12,0x11,0x10,
- 0x0f,0x0e,0x0d,0x0c,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01,0x00
- uint code table1[]={0x2000,0x2200,0x2400,0x2600,0x2800,0x2a00};//STC89C52RC EEPROM 扇区地址
- //uint code table1[]={0x4000,0x4200,0x4400,0x4600,0x4800,0x4a00};//STC89C54 EEPROM 扇区地址
- uint Random;//随机数变量
- /* ================ 打开 ISP,IAP 功能 ================= */
- void ISP_IAP_enable(void)
- EA = 0; /* 关中断 */
- ISP_CONTR = ISP_CONTR & 0x18; /* 0001,1000 */
- ISP_CONTR = ISP_CONTR | WaitTime; /* 写入硬件延时 */
- ISP_CONTR = ISP_CONTR | 0x80; /* ISPEN=1 */
- /* =============== 关闭 ISP,IAP 功能 ================== */
- void ISP_IAP_disable(void)
- ISP_CONTR = ISP_CONTR & 0x7f; /* ISPEN = 0 */
- ISP_TRIG = 0x00;
- EA = 1; /* 开中断 */
- /* ================ 公用的触发代码 ==================== */
- void ISPgoon(void)
- ISP_IAP_enable(); /* 打开 ISP,IAP 功能 */
- ISP_TRIG = 0x46; /* 触发ISP_IAP命令字节1 */
- ISP_TRIG = 0xb9; /* 触发ISP_IAP命令字节2 */
- _nop_();
- /* ==================== 字节读 ======================== */
- uchar byte_read(uint byte_addr)
- ISP_ADDRH = (uchar)(byte_addr >> 8);/* 地址赋值 */
- ISP_ADDRL = (uchar)(byte_addr & 0x00ff);
- ISP_CMD = ISP_CMD & 0xf8; /* 清除低3位 */
- ISP_CMD = ISP_CMD | RdCommand; /* 写入读命令 */
- ISPgoon(); /* 触发执行 */
- ISP_IAP_disable(); /* 关闭ISP,IAP功能 */
- return (ISP_DATA); /* 返回读到的数据 */
- /* ================== 扇区擦除 ======================== */
- void SectorErase(uint sector_addr)
- uint iSectorAddr;
- iSectorAddr = (sector_addr & 0xfe00); /* 取扇区地址 */
- ISP_ADDRH = (uchar)(iSectorAddr >> 8);
- ISP_ADDRL = 0x00;
- ISP_CMD = ISP_CMD & 0xf8; /* 清空低3位 */
- ISP_CMD = ISP_CMD | EraseCommand; /* 擦除命令3 */
- /* ==================== 字节写 ======================== */
- void byte_write(uint byte_addr, uchar original_data)
- ISP_ADDRH = (uchar)(byte_addr >> 8); /* 取地址 */
- ISP_CMD = ISP_CMD & 0xf8; /* 清低3位 */
- ISP_CMD = ISP_CMD | PrgCommand; /* 写命令2 */
- ISP_DATA = original_data; /* 写入数据准备 */
- ISP_IAP_disable(); /* 关闭IAP功能 */
- void main()
- uchar i;
- uint j,k;
- LED2=0;//LED2亮
- k=50000;
- while(k--);//延时等待系统稳定
- LED2=1;//LED2灭
- for(i=0;i<6;i++)//循环写6个扇区
- SectorErase(table1[i]);//擦除扇区
- for(j=0;j<512;j++)//循环写512个字节
- byte_write(table1[i]+j,table[j]);//写入数据
- if(byte_read(table1[i]+j)!= table[j])//比较对错
- LED1=0;//错误LED1亮
- k=50000;
- while(k--);//延时便于观察
- LED1=1;//LED1灭
- Random=rand()/64;//生成0~511随机数
- if(byte_read(table1[Random%6]+Random)==table[Random])//随机在6个扇区的随机地址抽样比对
- LED2=0;//正确LED2亮
- else LED1=0;//错误LED1亮
- while(1);
复制代码 |
