该设计可实现步进电机的速度及角度控制,
并在LCD1602上显示速度和角度
还可以利用PCF8591采集到的的信号实现角度控制
相关单片机代码如下:- #include "MAIN.H"
- #include "LCD1602.h"
- #include "PCF8591.h"
- * 设计名称: 两相步进电机
- unsigned char code FFW_X[8]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09}; //X反转顺序
- unsigned char code FFZ_X[8]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01}; //X正转顺序
- unsigned char code FFW_Y[8]={0x10,0x30,0x20,0x60,0x40,0xc0,0x80,0x90}; //Y反转顺序
- unsigned char code FFZ_Y[8]={0x90,0x80,0xc0,0x40,0x60,0x20,0x30,0x10}; //Y正转顺序
- unsigned char Speed = 30,Direction = 1,X_Y = 0,stop = 1,mode = 0;
- unsigned int k, temp;
- int Angle = 0;
- * 函 数 名 : main
- * 函数功能 : 主函数
- * 输 入 : 无
- * 输 出 : 无
- void main(void)
- System_Init();
- while(1)
- temp = Read_PCF(); // 读取AD转换后的数字量
- PCF_Output(temp); // DA转换,模拟量输出
- //将数字量转换为十进制,*100 + 0.5将小数转换为整数,便于显示和存储
- k = (float)temp * 5 / 256 * 100 + 0.5; // 将得到的结果存入数组
- Key_Scan();
- if(mode == 0)Motor();
- if(mode == 1)
- Angle = k/61*45;
- if(Angle >= 0)
- LCD1602_Location(2,7);
- LCD1602_Write_Num(Angle);
- if(X_Y==0)
- GPIO_MOTOR = FFW_Y[k/62];
- else
- GPIO_MOTOR = FFW_X[k/62];
- Delay(20);
- void System_Init(void)
- Init_PCF();
- Init_LCD1602();
- LCD1602_Location(1,1);
- LCD1602_write_word("Welcome To Use!");
- Delay(1000);
- LCD1602_Clear();
- LCD1602_write_word("Speed:");
- LCD1602_Write_Num(Speed);
- LCD1602_Location(2,1);
- LCD1602_write_word("Angle:");
- LCD1602_write_word("Null");
- LCD1602_Location(1,11);
- LCD1602_write_word("Stop");
- LCD1602_Location(2,12);
- LCD1602_write_word("X+");
- LCD1602_Location(2,15);
- LCD1602_write_word("O");
- * 函 数 名: Motor
- * 函数功能: 电机旋转函数
- * 输 入: 无
- * 输 出: 无
- void Motor()
- unsigned char i;
- if(Speed>0)
- for(i=0;i<8;i++)
- if(Direction==1&&X_Y==0&&stop==0) //正转&Y电机&电机没按下停止
- GPIO_MOTOR = FFW_Y[i];
- if(Direction==2&&X_Y==0&&stop==0) //反转&Y电机&电机没按下停止
- GPIO_MOTOR = FFZ_Y[i];
- if(Direction==1&&X_Y!=0&&stop==0) //正转&X电机&电机没按下停止
- GPIO_MOTOR = FFW_X[i];
- if(Direction==2&&X_Y!=0&&stop==0) //反转&X电机&电机没按下停止
- GPIO_MOTOR = FFZ_X[i];
- Delay(1000/Speed); //调节转速
- * 函 数 名 : Delay
- * 函数功能 : 延时
- * 输 入 : t
- * 输 出 : 无
- void Delay(unsigned int t)
- unsigned int k;
- while(t--)
- for(k=0; k<80; k++);
- * 函 数 名 : Key_Scan
- * 函数功能 : 按键
- * 输 入 : 无
- * 输 出 : 无
- void Key_Scan(void)
- unsigned int i,j;
- if(K1==0) //检测按键K1是否按下
- Delay(1); //消除抖动
- if(K1==0)
- if(stop == 1)
- stop=0;
- LCD1602_write_word("Move");
- else
- stop=1; //stop为控制电机停止的标志位,但它为1时,电机停止
- while((i<300)&&(K1==0))//检测按键是否松开
- Delay(1);
- i++;
- i=0;
- if(K2==0) //检测按键K1是否按下
- Delay(1); //消除抖动
- if(K2==0)
- Direction=1; //Direction 转向标志位,为2时为正转
- LCD1602_Location(2,13);
- LCD1602_write_word("+");
- while((i<200)&&(K2==0))//检测按键是否松开
- Delay(1);
- i++;
- i=0;
- /********************检测按键K2是否按下***********************/
- if(K3==0) //检测按键K2是否按下
- Delay(1); //消除抖动
- if(K3==0)
- Direction=2; //Direction 转向标志位,为2时为反转
- LCD1602_write_word("-");
- while((i<200)&&(K3==0))//检测按键是否松开
- Delay(1);
- i++;
- i=0;
- /********************检测按键K3是否按下***********************/
- if(K4==0)//检测按键K3是否按下
- Delay(1);//消除抖动
- if(K4==0)
- if(Speed < 100)
- Speed += 5;
- LCD1602_Location(1,7);
- while((i<200)&&(K4==0))//检测按键是否松开
- Delay(1);
- i++;
- i=0;
- if(K5==0) //检测按键K4是否按下
- Delay(1); //消除抖动
- if(K5==0)
- if(Speed > 0)
- Speed -= 5;
- while((i<200)&&(K5==0))//检测按键是否松开
- Delay(1);
- i++;
- i=0;
- if(K6==0)//检测按键K1是否按下
- Delay(1);//消除抖动
- if(K6==0)
- // Direction=0; //X_Y 电机的参数 X_Y=0为Y电机 X_Y=1为X电机
- if(X_Y==0) //当切换电机时,对Direction=0;对标志位清零,防止上个电机的转向影响本次所控电机
- X_Y=1;
- LCD1602_write_word("Y");
- else
- X_Y=0;
- LCD1602_write_word("X");
- while((i<400)&&(K6==0))//检测按键是否松开
- Delay(1);
- i++;
- i=0;
- if(K7==0)//检测按键K1是否按下
- Delay(1);//消除抖动
- if(K7==0)
- if(Angle >= 0)
- if(Direction==1&&stop==1) //正转&Y电机&电机没按下停止
- if(j >= 8)j -= 8;
- Angle += 45;
- if(Angle >= 360)Angle -= 360;
- j++;
- if(X_Y==0)
- GPIO_MOTOR = FFW_Y[j];
- else
- GPIO_MOTOR = FFW_X[j];
- if(Direction==2&&stop==1) //反转&Y电机&电机没按下停止
- if(j > 0)
- Angle -= 45;
- if(Angle <= 0)Angle = 0;
- j--;
- if(X_Y==0)
- else
- else
- j = 0;
- Delay(20);
- while((i<2000)&&(K7==0))//检测按键是否松开
- Delay(1);
- i++;
- i=0;
- if(K8==0)//检测按键K1是否按下
- Delay(1);//消除抖动
- if(K8==0)
- mode = 1;
- LCD1602_write_word("C");
- while((i<500)&&(K8==0))//检测按键是否松开
- Delay(1);
- i++;
- i=0;
- if(K9==0)//检测按键K1是否按下
- Delay(1);//消除抖动
- if(K9==0)
- mode = 0;
- while((i<500)&&(K9==0))//检测按键是否松开
- Delay(1);
- i++;
- i=0;
全部资料51hei下载地址:
两相步进电机.zip
(220.49 KB, 下载次数: 114)
