查看: 2344|回复: 0
ULN2003驱动步进电机程序
ID:501297 发表于 2021-4-27 17:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include <reg52.h>
  2. #include <absacc.h>
  3. sbit p10=P1^0;
  4. sbit p11=P1^1;
  5. sbit p12=P1^2;
  6. #define  UP   20
  7. #define  DOWN  30
  8. #define  STOP  40
  9. void delay()
  10. {
  11.         unsigned i,j,k;
  12.         for(i=0;i<0x02;i++)
  13.                 for(j=0;j<0x02;j++)
  14.                         for(k=0;k<0xff;k++);
  15. }
  16. main()
  17. {
  18.         unsigned char temp;
  19.         while(1)
  20.         {
  21.                 if(p10==0)
  22.                 {
  23.                         temp=UP;
  24.                         P2=0X00;
  25.                         delay();
  26.                 }
  27.                 if(p11==0)
  28.                 {
  29.                         temp=DOWN;
  30.                         P2=0X00;
  31.                         delay();
  32.                 }
  33.                 if(p12==0)
  34.                 {
  35.                         temp=STOP;
  36.                 }
  37.                 switch(temp)
  38.                 {
  39.                 case DOWN : P2=0X01;
  40.                                         delay();
  41.                                         delay();
  42.                                         P2=0X02;
  43.                                         delay();
  44.                                         delay();
  45.                                         P2=0X04;
  46.                                         delay();
  47.                                         delay();
  48.                                         P2=0X08;
  49.                                         delay();
  50.                                         delay();
  51.                                         break;
  52.                 case UP :        P2=0X08;
  53.                                         delay();
  54.                                         delay();
  55.                                         P2=0X04;
  56.                                         delay();
  57.                                         delay();
  58.                                         P2=0X02;
  59.                                         delay();
  60.                                         delay();
  61.                                         P2=0X01;
  62.                                         delay();
  63.                                         delay();
  64.                                         break;
  65.                 case  STOP :
  66.                                         P2=0X00;
  67.                                         delay();
  68.                                         delay();
  69.                                         break;
  70.                 }
  71.    }
  72. }
