查看: 2133|回复: 0
基于单片机CC1101的433M无线通信系统
ID:600744 发表于 2021-7-14 17:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1、 完成硬件电路的设计,其中包括单片机和CC1101模块的设计;
2、完成无线通信模块的程序设计与实现;
部分关键代码:
#include "main.h"    //main.h 中含有TX/RX选择配置选项
const char *g_Ashining = "433Mtest";
uint8_t g_TxMode = 0, g_UartRxFlag = 0;
uint8_t g_UartRxBuffer[100] = { 0 };
uint8_t g_RF24L01RxBuffer[32] = { 0 };
  * @brief :主函数
  * @param :无
  * @note  :无
  * @retval:无
int main(void)
    uint8_t i = 0;
    //串口初始化
    drv_uart_init();
    //LED初始化
    drv_led_init();
    //SPI初始化
    drv_spi_init();
    //CC1101初始化
    CC1101_Init();
    for (i = 0; i < 6; i++)
        led_red_flashing();
        led_green_flashing();
        drv_delay_ms(500);
#ifdef    __CC1101_TX_TEST__
        //按键初始化
    drv_button_init();
    while (1)
        //模式切换
        if (BUTOTN_PRESS_DOWN == drv_button_check())
            g_TxMode = 1 - g_TxMode;        //模式会在 TX_MODE_1( 0 ),TX_MODE_2( 1 )之间切换
            //状态显示清零
            led_green_off();
            led_red_off();
            if (TX_MODE_1 == g_TxMode)
                    led_red_flashing();    //固定发送模式,红灯闪烁3次
                    drv_delay_ms(500);
                    led_green_flashing();    //串口发送模式,绿灯闪烁3次
                    drv_delay_ms(500);
        //模式切换
        //发送
            CC1101_Tx_Packet((uint8_t *)g_Ashining, 8, ADDRESS_CHECK);    //模式1发送固定字符,1S一包
            drv_delay_ms(1000);
            led_red_flashing();
            //查询串口数据
            i = drv_uart_rx_bytes(g_UartRxBuffer);
            if (0 != i)
                CC1101_Tx_Packet(g_UartRxBuffer, i, ADDRESS_CHECK);
                led_red_flashing();
#else
接收
    while (1)
        CC1101_Clear_RxBuffer();
        CC1101_Set_Mode(RX_MODE);
        while (0 != CC1101_GET_GDO0_STATUS());
        while (0 == CC1101_GET_GDO0_STATUS());
        i = CC1101_Rx_Packet(g_RF24L01RxBuffer);        //接收字节
        if (0 != i)
            drv_uart_tx_bytes(g_RF24L01RxBuffer, i);    //输出接收到的字节
#endif
