晶振11.0592M,波特率9600,用了虚拟终端,打算加上 虚拟串口,嘿嘿
- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- ///共阳数码管 0-9 P 灭
- uchar code smdm[]=
- {0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90, 0xFF}; //
- #define sm_dm P0
- sbit Led=P3^7;
- sbit Key_set=P3^2;
- uchar code hello_world[]="Hello World ";
- uchar Dat_rxd;
- uchar work_mode=0;
- void DelayUs(unsigned char us)//delay us
- unsigned char uscnt;
- uscnt=us>>1; /*12MHz频率*/
- while(--uscnt);
- /* 毫秒函数声明 */
- void DelayMs(unsigned int ms)
- while(--ms)
- DelayUs(250);
- DelayUs(250);
- DelayUs(250);
- DelayUs(250);
- //******************串口初始化函数****************************//
- void Com0_Init(void)
- EA=1; //开总中断
- ES=1; //允许串口中断
- TMOD=0x20; //定时器T1,在方式3中断产生波特率
- SCON=0x50;
- TH1=0xfd; //波特率设置为9600(晶振12M)
- TL1=0xfd;
- TR1=1; //开定时器T1运行控制位
- void Com0(void) interrupt 4 using 1
- if(RI)
- Led=~Led;
- Dat_rxd=SBUF; //串口接收
- Dat_rxd=Dat_rxd-0x30;
- sm_dm=smdm[Dat_rxd];
- RI=0;
- void send_string(uchar *p)
- while(*p!= '\0')
- SBUF=*p;
- p++;
- while(TI==0);
- TI=0;
- void main(void)
- Com0_Init();
- while(1)
- if(~Key_set)
- DelayMs(3);
- if(~Key_set)
- work_mode=1;
- while(~Key_set);
- switch(work_mode)
- case 0: break;
- case 1: Led=~Led;
- send_string(hello_world);
- work_mode=0;
- break;
仿真代码51hei附件下载:
仿真代码.7z
(308.84 KB, 下载次数: 123)
