查看: 3988|回复: 3
Ardiuno制作2019年电赛电磁炮
花了几天时间做出来的电磁炮。三种模式:模式一,调距离射靶。模式二,调角度,距离射靶。模式三,全自动射靶(利用激光测距来瞄靶)
#################################程序###########################
//遥控
#include <IRremote.h>
//LCD1602
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);//0x27   0x3F
//舵机
#include <Servo.h>
Servo myservo;
Servo myservo2;
const int irReceiverPin =7;//遥控引脚
const int relayPin =3;//继电器引脚
int tu=0;//模式
int JL=0;//距离
int JL2=0;//模式2距离
unsigned int JL3;//模式3距离
int jiaodu=0;//角度
int jiaodu2=0;//模式2角度
int jiaodu3=0;//模式三角度
int zh=0;//模式2切换
int pin =4;//激光
int jishi;
int jiaodu4=0;
int JL4=0;
int jiaodu5=0;
unsigned long duration;//模式三激光探测距离
IRrecv irrecv(irReceiverPin); //Creates a variable of type IRrecv
decode_results results;
void setup() {
  // put your setup code here, to run once:
    pinMode(relayPin, OUTPUT);//使能继电器
    Serial.begin(9600);//波特率
    myservo2.attach(8);    myservo.attach(9);//舵机使能
    irrecv.enableIRIn(); //遥控
    lcd.init(); //LCD1602
    lcd.backlight();
     pinMode(pin, INPUT);
void loop() {
          myservo.write(60);
          while(1){
            //遥控串口
            if (irrecv.decode(&results)) //if the ir receiver module receiver data
                       Serial.print("irCode: "); //print"irCode: "
                       Serial.print(results.value, HEX); //print the value in hexdecimal
                       Serial.print(", bits: "); //print" , bits: "
                       Serial.print(JL);
                       Serial.print("   ");
                       Serial.print(tu);
                       Serial.print("   ");
                       Serial.println(results.bits); //print the bits
                        irrecv.resume(); // Receive the next value
//  delay(20);
   if(tu==0){
              myservo.write(0);myservo2.write(90);
              lcd.setCursor(0, 0);
              lcd.print("Electromagnetic");
              lcd.setCursor(0, 1);
              lcd.print("Gun             ");
        }else if(tu==1){
              lcd.print("Model: 1 ");
              lcd.print(" Distance");
              lcd.setCursor(9, 1);
              lcd.print(JL);
              lcd.setCursor(12, 1);
              lcd.print("cm");
          }else if(tu==2){
              lcd.print("Model: 2 ");
              lcd.print("JL:");
              lcd.setCursor(4, 1);
              lcd.print(JL2);
              lcd.setCursor(8, 1);
              lcd.print("JD:");
              lcd.print(jiaodu2);
          switch(results.value){
            case 0xFFA25D://CH-
                      tu=1;
              results.value=0xFFFFFF;
                      break;
            case 0xFF629D://CH
            if(tu==1){
              jiaodu=(JL/10)-5;
                      myservo.write(jiaodu);
                      delay(50);
                      digitalWrite(relayPin,HIGH);
                      delay(500);
                      digitalWrite(relayPin,LOW);
                      JL=0;tu=0;jiaodu=0;
            }else if((tu==2)&&(zh==1)&&(JL2>199)){
                      jiaodu2=jiaodu2+60;
                      myservo2.write(jiaodu2);
                      jiaodu=(JL2/10)-5;
                      delay(100);
                      delay(500);
                      JL=0;tu=0;jiaodu2=0;jiaodu=0;zh=0;JL2=0;
            }else results.value=0xFFFFFF;
                      break;
            case 0xFFE21D://CH+
                      tu=2;
                      break;
            case 0xFF22DD://|<<
                  if((tu==2)&&(zh==1)){
                        zh=0;
                      break;
            case 0xFF02FD://>>|
             if((tu==2)&&(zh==0)){
                        zh=1;
                    }else results.value=0xFFFFFFF;
                      break;
            case 0xFFC23D://>||
                        tu=3;jiaodu3=60;
                         myservo2.write(60);
                      break;
            case 0xFFE01F://-
             if((tu==1)&&(JL>199)){
                      JL--;
                      lcd.print(JL);
            }else if((tu==2)&&(zh==0)&&(JL2>199)){
                      JL2--;
                      lcd.print(JL2);
            }else if((tu==2)&&(zh==1)&&(jiaodu2>0)){
                      jiaodu2--;
                       lcd.print(jiaodu2);
                      break;
            case 0xFFA857://+
             if((tu==1)&&(JL<301)){
                      JL++;
            }else if((tu==2)&&(zh==0)&&(JL2<301)){
                      JL2++;
            }else if((tu==2)&&(zh==1)&&(jiaodu2<61)){
                      jiaodu++;
                      break;
            case 0xFF906F://EQ
                      break;
            case 0xFF6897://0
                       if(tu==1){
                            JL=0;
                             lcd.print("   ");
                       }else if((tu==2)&&(zh==0)){
                         lcd.print("   ");
                            JL2=0;
                        }else if((tu==2)&&(zh==1)){
                          lcd.print("  ");
                              jiaodu2=0;
                      break;
            case 0xFF9867://100+
                           JL=JL+100;
                            JL2=JL2+100;
                      break;
            case 0xFFB04F://200+
                           JL=JL+200;
                            JL2=JL2+200;
                      break;
            case 0xFF30CF://1
                            JL=JL+1;
                       }else if((tu==2)&&(zh==0)&&(JL<301)){
                            JL2=JL2+1;
                            jiaodu2=jiaodu2+1;
                      break;
            case 0xFF18E7://2
                            JL=JL+2;
                            JL2=JL2+2;
                            jiaodu2=jiaodu2+2;
                      break;
            case 0xFF7A85://3
                            JL=JL+3;
                            JL2=JL2+3;
                            jiaodu2=jiaodu2+3;
                      break;
            case 0xFF10EF://4
                            JL=JL+4;
                            JL2=JL2+4;
                            jiaodu2=jiaodu2+4;
                      break;
            case 0xFF38C7://5
                            JL=JL+5;
                            JL2=JL2+5;
                            jiaodu2=jiaodu2+5;
                      break;
            case 0xFF5AA5://6
                            JL=JL+6;
                            JL2=JL2+6;
                            jiaodu2=jiaodu2+6;
                      break;
            case 0xFF42BD://7
                            JL=JL+7;
                            JL2=JL2+7;
                            jiaodu2=jiaodu2+7;
                      break;
            case 0xFF4AB5://8
                            JL=JL+8;
                       }else if((tu==2)&&(zh==0)&&(jiaodu2<61)){
                            jiaodu2=jiaodu2+8;
                        }else if((tu==2)&&(zh==1)&&(JL<301)){
                              JL2=JL2+8;
                      break;
            case 0xFF52AD://9
                            JL=JL+9;
                            JL2=JL2+9;
                            jiaodu2=jiaodu2+9;
                      break;
              if(tu==3){
              myservo.write(0);
              lcd.print("Model: 3 ");
               Serial.print(" JL3: ");
               Serial.print(JL3);
               Serial.println("us");
              //扫描
                  JL3= pulseIn(pin, HIGH);
              while((JL3>30001)||(JL3<19999)){
                if((zh==0)&&(jiaodu3<121)){
                      jiaodu3++;
                      myservo2.write(jiaodu3);
                      if(jiaodu3==120)zh=1;
                      delay(30);
                  }else if((zh==1)&&(jiaodu3>58)){
                      jiaodu3--;
                      if(jiaodu3==60)zh=0;
                      delay(30);
                  /*    Serial.print(" JL3: ");
                     Serial.print(JL3);
                      Serial.println("cm");
                   JL4=JL3/100;jiaodu4=(JL4/10)-5;
                   jiaodu5=jiaodu3-60;
                   if((JL3>0)&&(JL3<40000)){
                       lcd.print("JL:");
                      lcd.setCursor(3, 1);
                       lcd.print(JL4);
                       lcd.setCursor(7, 1);
                       lcd.print("cm");
                       lcd.print("JD:");
                       lcd.print(jiaodu5);
                       lcd.print(".c");
                for(jishi=0;jishi<5;jishi++){
                      delay(300);
                   }if(jishi==5){
                      jiaodu4=(JL4/10)-5;
                       Serial.print(" jiaodu4: ");
                       Serial.print(jiaodu4);
                      myservo.write(jiaodu4);
                      delay(50);
                      delay(500);
                      tu=0;jiaodu4=0;JL3=0;JL4=0;
收藏收藏1 分享淘帖 顶1 踩
ID:954677 发表于 2021-7-28 11:21 | 只看该作者
楼主,能不能发一下原理图呢
ID:444191 发表于 2021-7-28 20:43 | 只看该作者
公司的 发表于 2021-7-28 11:21
楼主,能不能发一下原理图呢
很多都是用模块的,只有升压的是自己做的。里面有1602,红外遥控,继电器模块,舵机云台,激光传感器。最主要的就是线圈问题,捆的话超80圈吧。升压这边建议用可控硅对电容放电来控制
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:444191 发表于 2021-7-28 20:48 | 只看该作者
发射台下面的那白色的一坨是充电宝,充电宝是给Arduino供给的。靠近电容两层最上面那层是可控硅控制电容放电给电磁炮的。黑的接地,红的接12伏。
蓝色的继电器模块因为是5伏控制的,所以用了稳压芯片到5伏再控制的。
admin + 50 回帖助人的奖励!
