查看: 2235|回复: 0
stm32智能小车制作 舵机超声波程序
制作出来的实物图如下:
STM32单片机源程序如下:
****************************超声波避障模*******************************************************
float disleft,disright;
void Wave_BZ(void)
            int i;
            Distance = Wave_Start();    //超声波测距存到Wave_Start() 函数中
            SG90_Front;                       //舵机转向正前方
            delay_ms(700);
           if(Distance>80)                 //若距离大于80cm
                  forward();                //车辆继续直行
            for(i = 0; i <= 300; i++)                   //速度不断上升
                        TIM_SetCompare2(TIM3, i);
                        TIM_SetCompare3(TIM3, i);
                else                                              //若距离小于80cm
                stop();                                        //车子停下来
                TIM_SetCompare2(TIM3,0);         //电机pwm为0
                TIM_SetCompare3(TIM3,0);
                SG90_Right_45;                       //舵机右转测距
                delay_ms(900);
                disright=Wave_Start();
                //printf("right:%f cm\r\n",disright);            //可打印串口
                SG90_Left_45;                                        //舵机左转测距
                delay_ms(900);
                disleft=Wave_Start();
               delay_ms(900);
                        if(disleft>=disright)                         //若左边距离大于右边距离,左转
                                do
                                         delay_ms(10);
                                        delay_ms(10);
                                        Turn_Left();
                                        TIM_SetCompare3(TIM3,450);
                                        while(Distance<50);                   //距离小于50cm,停下来超声波测距
                                else        if(disleft<disright)          //若右边距离大于左边距离,右转
                                do
                                        delay_ms(10);
                                        delay_ms(10);
                                        Turn_Right();
                                        TIM_SetCompare2(TIM3,450);
*************************************电机模块*****************************************************
#include "motor.h"
void Motor_Init(void)
        GPIO_InitTypeDef GPIO_InitStructure;
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);  //使能时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //速度50Mhz
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_ResetBits(GPIOA, GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
void forward(void)                          //前进
      M1=0;M2=1;  M3=0;M4=1;
      M5=0;M6=1;  M7=0;M8=1;
void back(void)                             //后退
      M1=1;M2=0;  M3=1;M4=0;
            M5=1;M6=0;  M7=1;M8=0;
void Turn_Right(void)                //右转
    M1=0;M2=1;  M3=1;M4=1;
          M5=0;M6=1;  M7=1;M8=1;
void Turn_Left(void)                //左转
    M1=1;M2=1;  M3=0;M4=1;
          M5=1;M6=1;  M7=0;M8=1;
void stop(void)                       //停止
    M1=1;M2=1;  M3=1;M4=1;
          M5=1;M6=1;  M7=1;M8=1;
***********************************主函数**********************************************************
#include "key.h"
#include "delay.h"
#include "led.h"
#include "ultrasonic.h"   //超声波
#include "motor.h"       //电机
#include "Engine.h"     //舵机
#include "pwm.h"        //电机pwm
int main()
         TIM3_PWM_Init(899,0);        //电机pwm初始化
         Motor_Init();                       //电机初始化
         Wave_IO_Init();                 //  超声波初始化
         sg90_Init();                       //舵机初始化
         delay_init();
                 Wave_BZ();           //超声波+舵机避障
全部代码51hei附件下载:
stm32f103智能小车超声波加舵机.7z (188.31 KB, 下载次数: 55)
收藏收藏3 分享淘帖 顶 踩
