- * 硬件连接:-----------------
- * | PB6-I2C1_SCL |
- * | PB7-I2C1_SDA |
- * 库版本 :ST3.5.0
- * 作者 : Orange
- #include "I2C_MPU6050.h"
- * 函数名:I2C_GPIO_Config
- * 描述 :I2C1 I/O配置
- * 输入 :无
- * 输出 :无
- * 调用 :内部调用
- static void I2C_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- /* 使能与 I2C1 有关的时钟 */
- RCC_APB2PeriphClockCmd (RCC_APB2Periph_GPIOB,ENABLE );
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
- /* PB6-I2C1_SCL、PB7-I2C1_SDA*/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- * 函数名:I2C_Mode_Config
- * 描述 :I2C 工作模式配置
- * 输入 :无
- * 输出 :无
- * 调用 :内部调用
- static void I2C_Mode_Config(void)
- /* Initialize the I2C1 according to the I2C_InitStructure members */
- I2C_InitTypeDef I2C_InitStructure;
- /* I2C 配置 */
- I2C_InitStructure.I2C_Mode = I2C_Mode_I2C ;
- //I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
- //I2C_InitStructure.I2C_OwnAddress1 = SlaveAddress;
- I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
- I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
- I2C_InitStructure.I2C_ClockSpeed = 50000;
- /* I2C1 初始化 */
- I2C_Init(I2C1, &I2C_InitStructure);
- /* 使能 I2C1 */
- I2C_Cmd (I2C1,ENABLE);
- /*允许应答模式*/
- I2C_AcknowledgeConfig(I2C1, ENABLE);
- * 函数名:I2C_MMA_Init
- * 描述 :I2C 外设(MMA7455)初始化
- * 输入 :无
- * 输出 :无
- * 调用 :外部调用
- void I2C_MPU6050_Init(void)
- I2C_GPIO_Config();
- I2C_Mode_Config();
- * 函数名:I2C_ByteWrite
- * 描述 :写一个字节到I2C设备寄存器中
- * 输入 :REG_Address 接收数据的IIC设备寄存器的地址
- * REG_data 待写入的数据
- * 输出 :无
- * 返回 :无
- * 调用 :内部调用
- void I2C_ByteWrite(uint8_t REG_Address,uint8_t REG_data)
- I2C_GenerateSTART(I2C1,ENABLE);
- while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT));
- I2C_Send7bitAddress(I2C1,SlaveAddress,I2C_Direction_Transmitter);
- while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
- I2C_SendData(I2C1,REG_Address);
- while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED));
- I2C_SendData(I2C1,REG_data);
- I2C_GenerateSTOP(I2C1,ENABLE);
- * 函数名:I2C_ByteRead
- * 描述 :从IIC设备寄存器中读取一个字节
- * 输入 :REG_Address 读取数据的寄存器的地址
- * 输出 :无
- * 返回 :无
- * 调用 :内部调用
- uint8_t I2C_ByteRead(uint8_t REG_Address)
- uint8_t REG_data;
- while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY));
- I2C_GenerateSTART(I2C1,ENABLE);//起始信号
- I2C_Send7bitAddress(I2C1,SlaveAddress,I2C_Direction_Transmitter);//发送设备地址+写信号
- while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));//
- I2C_Cmd(I2C1,ENABLE);
- I2C_SendData(I2C1,REG_Address);//发送存储单元地址,从0开始
- I2C_Send7bitAddress(I2C1,SlaveAddress,I2C_Direction_Receiver);//发送设备地址+读信号
- while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
- I2C_AcknowledgeConfig(I2C1,DISABLE);
- while(!(I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_RECEIVED)));
- REG_data=I2C_ReceiveData(I2C1);//读出寄存器数据
- return REG_data;
- * 函数名:void InitMPU6050(void)
- * 描述 :初始化Mpu6050
- * 输入 :无
- * 输出 :无
- * 调用 :外部调用
- void InitMPU6050(void)
- I2C_ByteWrite(PWR_MGMT_1,0x00);//解除休眠状态
- I2C_ByteWrite(SMPLRT_DIV,0x07);
- I2C_ByteWrite(CONFIG,0x06);
- I2C_ByteWrite(GYRO_CONFIG,0x18);
- I2C_ByteWrite(ACCEL_CONFIG,0x01);
- * 函数名:GetData
- * 描述 :获得16位数据
- * 输入 :REG_Address 寄存器地址
- * 输出 :返回寄存器数据
- * 调用 :外部调用
- unsigned int GetData(unsigned char REG_Address)
- char H,L;
- H=I2C_ByteRead(REG_Address);
- L=I2C_ByteRead(REG_Address+1);
- return (H<<8)+L; //合成数据
初学电子,如有错误,请大家多多指导,资料仅供参考:
MPU6050(硬件IIC).zip
(294.78 KB, 下载次数: 24)
