查看: 1690|回复: 0
串口四的配置(初始化+中断配置+中断接收函数)
ID:110875 发表于 2021-11-29 21:38 | 显示全部楼层 |阅读模式
今天发布STM32的串口3配置程序,话不多说。
1 /*===============================================================================  2 Copyright:  3 Version:  4 Author:      5 Date: 2017/11/3  6 Description:  7     函数功能是将接收固定长度的字符串,并将接收后的字符串通过串口发送出去  8     通过滴答定时器方式获取数据  9 revise Description: 10 ===============================================================================*/
11 #include "stm32f10x_usart.h"
12 #include "stm32f10x.h"
13
14 #define USART4_TIMEOUT_Setting 800  //(ms)
15
16 u8 USART4_RX_BUF[250];  17 u16 USART4_RX_CNT=0; 18 u16 USART2_RX_STA=0;       //接收状态标记
19
20 void Systick_delay_init(u8 SYSCLK); 21 u8 virtual_delay(u32 num,u8 unit); 22
23 //通用异步收发器UART4
24 void UART4_Init(u32 bound) 25 { 26     USART_InitTypeDef USART_InitStructure; 27     GPIO_InitTypeDef GPIO_InitStructure; 28
29     //used for USART3 full remap 30     //GPIO_PinRemapConfig(GPIO_FullRemap_USART3, ENABLE);
31     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE); 32     RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE);//for UART4 33
34     //Configure RS485_TX_EN PIN
35     GPIO_InitStructure.GPIO_Pin = RS485_TX_EN_PIN;                 //PC9端口配置
36     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;          //推挽输出
37     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; 38     GPIO_Init(RS485_TX_EN_PORT, &GPIO_InitStructure); 39
40     RS485_TX_EN=0;            //设置485默认为接收模式
41
42     /* Configure USART Tx as alternate function push-pull */
43     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; 44     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; 45     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; 46     GPIO_Init(GPIOC, &GPIO_InitStructure); 47
48     /* Configure USART Rx as input floating */
49     GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_11; 50     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; 51     GPIO_Init(GPIOC, &GPIO_InitStructure); 52
53
54     USART_InitStructure.USART_BaudRate = bound; 55     USART_InitStructure.USART_WordLength = USART_WordLength_8b; 56     USART_InitStructure.USART_StopBits = USART_StopBits_1; 57     USART_InitStructure.USART_Parity = USART_Parity_No ; 58     USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; 59     USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; 60
61     USART_Init(UART4, &USART_InitStructure); 62     //USART_Init(USART3, &USART_InitStructure);
63     /* Enable the USART */
64     USART_Cmd(UART4, ENABLE); 65     USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);//开启串口接受中断
66     USART_ClearFlag(UART4,USART_FLAG_TC);     67 } 68 //USART1查询接收到的数据 69 //buf:接收缓存首地址 70 //len:读到的数据长度
71 void UART4_Receive_Data(u8 *buf) 72 { 73     u8 rxlen=21; 74     u8 i=0; 75     delay_ms(10);        //等待10ms,连续超过10ms没有接收到一个数据,则认为接收结束
76
77     RS485_RX_FLAG = 0; 78     if((UART4_RX_BUF[0]==0x01)&&(UART4_RX_BUF[1]==0x03)) 79     { 80         for(i=0;i<rxlen;i++) 81         { 82             buf[ i]=UART4_RX_BUF[ i];    [ i] 83             UART4_RX_BUF[ i] = 0; 84         }     85         RS485_RX_FLAG = 1; 86     } 87         UART4_RX_CNT=0;        //清零
88 } 89
90
91 //USART1发送len个字节. 92 //buf:发送区首地址 93 //len:发送的字节数(为了和本代码的接收匹配,这里建议不要超过64个字节)
94 void UART4_Send_Data(u8 *buf,u16 len) 95 { 96     u16 t; 97     RS485_TX_EN=1;            //设置为发送模式
98     for(t=0;t<len;t++)        //循环发送数据
99     {           100         while(USART_GetFlagStatus(UART4,USART_FLAG_TC)==RESET); //循环发送,直到发送完毕
101         USART_SendData(UART4,buf[t]); 102     }     103     while(USART_GetFlagStatus(UART4, USART_FLAG_TC) == RESET);        104     RS485_TX_EN=0;                //设置为接收模式
105 }106
107 void main(void)108 {109     Systick_delay_init(72);110     Usart4_Init(9600);//串口1波特率设置为9600
111     while(1)112     {113         if(USART2_RX_STA)114         {115             if(virtual_delay(USART4_TIMEOUT_Setting,MS))//超过800ms空闲则可以读取数据
116             {117                 UART4_Send_Data(UART4_RX_BUF,UART4_RX_CNT);118                 USART2_RX_STA=0;119                 UART4_RX_CNT=0;                120             }121
122         }123
124     }    125 }126 void UART4_IRQHandler(void)                    //UART4 Receive Interrupt
127 {128     u8 Res;129
130     if(USART_GetITStatus(UART4, USART_IT_RXNE) != RESET)  //接收中断(接收到的数据必须是0x0d 0x0a结尾)
131     {    132         Res =USART_ReceiveData(UART4);//(USART1->DR);    //读取接收到的数据
133         UART4_RX_BUF[UART4_RX_CNT&0XFF]=Res;        //回传的数据存入数组,0X3F限制为64个数值
134             UART4_RX_CNT++;135         USART2_RX_STA=1;    136     }137
138     if( USART_GetITStatus(UART4, USART_IT_TC) == SET )139     {140         USART_ClearFlag(UART4, USART_FLAG_TC);141     }    142     //溢出-如果发生溢出需要先读SR,再读DR寄存器则可清除不断入中断的问题
143     if(USART_GetFlagStatus(UART4,USART_FLAG_ORE) == SET)144     {145         USART_ReceiveData(UART4);146         USART_ClearFlag(UART4,USART_FLAG_ORE);147     }148 //    USART_ITConfig(UART4, USART_IT_RXNE, DISABLE);//临时关闭接收中断
149     USART_ClearFlag(UART4,USART_IT_RXNE); //一定要清除接收中断
150
151 } 152
153 //初始化延迟函数154 //SYSTICK的时钟固定为HCLK时钟的1/8155 //SYSCLK:系统时钟
156 void Systick_delay_init(u8 SYSCLK)157 {158     SysTick->CTRL&=0xfffffffb;//bit2清空,选择外部时钟  HCLK/8159 //    SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);    //选择外部时钟  HCLK/8
160     fac_us=SYSCLK/8;            161     fac_ms=(u16)fac_us*1000;162 }163 /*===============================================================================164 Author:peter pan165 Date: 166 Description: 查询式分时或叫做轮询式(近似延时)。本函数是用于执行高效率场合的查询延时,但是一个for or while 循环中只能用一次。167 revise Description:  168 @ num :    //分时查询的周期计数值    169 @ unit :    //分时查询的周期单位 170     @@ParaValue : 171         MS    //周期单位为MS毫秒级172         US    //周期单位为US微秒级173 @ virtual_delay_status :    //静态变量174     @@ParaValue : 175         SET    //SYSTICK正在占用中,请勿用176         RESET  //SYSTICK空闲,可以使用177 @ReValue :178     with zero mean Time non-arrive ,one representative Time arrived ,you can do task;179 ##example             if(virtual_delay(1000,MS)) LedFlash();    //1000ms LED闪烁一下180 ===============================================================================*/
181 u8 virtual_delay(u32 num,u8 unit)182 {183     u32 temp;           184     if(virtual_delay_status==RESET)    //  SYSTICK空闲,可以使用
185       {186           if(unit==MS)187           {188                 SysTick->LOAD=(u32)num*Delay_SYSCLK*125;//时间加载(SysTick->LOAD为24bit)
189                 SysTick->VAL =0x00;           //清空计数器
190                 SysTick->CTRL=0x01 ;          //开始倒数
191           }else if(unit==US) 192           {193                 SysTick->LOAD=num*Delay_SYSCLK/8; //时间加载
194                 SysTick->VAL=0x00;        //清空计数器
195                 SysTick->CTRL=0x01 ;      //开始倒数
196           }197           virtual_delay_status=SET;198           return 0;199         }200     else
201         {        //virtual_delay_status==SET SYSTICK被占用
202
203             temp=SysTick->CTRL;204             if(!(temp&0x01&&!(temp&(1<<16))))//等待时间到达
205             {206                 SysTick->CTRL=0x00;       //关闭计数器
207                 SysTick->VAL =0X00;       //清空计数器
208                 virtual_delay_status=RESET;    209                 return 1;210             }else return 0;211         }212 }
