查看: 2069|回复: 4
Arduino程序 把按键作为开关的方法 (不用delay)
ID:989772 发表于 2022-1-9 10:18 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
(原创)  不用delay, 不阻塞运行!
int    b2 = 0;       //button state,  default  HIGH
bool b2on = false;
int  wait = 0;      //counter when key is hold
void setup() {
  // initialize the LED pin as an output:
  pinMode(ledPin1, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin1, INPUT);
void loop() {
  // read the state of the pushbutton value:
  b2 = digitalRead(buttonPin1);
  if( b2 == LOW )   // pressed,  from HIGH->LOW
    wait++;             // wait for release
  if( b2 && wait > 39)              // button return back to HIGH, and  LOW for 39 times
    b2on = !b2on;                  // one CLICK  finished!
    wait = 0;                           // reset
  if (b2on) {
    // turn LED on:
    digitalWrite(ledPin1, HIGH);
  } else {
    // turn LED off:
    digitalWrite(ledPin1, LOW);
ID:989772 发表于 2022-9-12 08:10 | 显示全部楼层
"wait > 39"   这里的 39 根据你的芯片调节到合适的值
