查看: 920|回复: 3
STM32F1单片机我用单次AD采样和AD+DMA连接采样的结果有偏差
ID:858418 发表于 2022-1-17 11:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
         请教大家一个问题, 硬件是一样的,采样电阻接地。         负载不工作:
         AD单次采样时,可以采样到0x 00;
        AD+DMA连续采样,采样到 0x 0F到0x 12
        抬高了采样值,
        负载开起时:
        AD单次采样时,可以采样到0x 67 左右波动;
        AD+DMA连续采样,采样到 0x89  左右波动;
        抬高了采样值,是我那里没有设置好吗,我就在例程上修改一个脚,从PC1改到PA1.
#include "adc.h"
#define ADC1_DR_Address    ((u32)0x40012400+0x4c)
__IO uint16_t ADC_ConvertedValue;
//__IO u16 ADC_ConvertedValueLocal;
static void ADC1_GPIO_Config(void)
        GPIO_InitTypeDef GPIO_InitStructure;
        /* Enable DMA clock */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        /* Enable ADC1 and GPIOC clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA, ENABLE);
        /* Configure PC.01  as analog input */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
/* oˉêyÃû£oADC1_Mode_Config
* Ãèêö  £oÅäÖÃADC1μÄ1¤×÷Ä£ê½ÎaMDAÄ£ê½
* êäèë  : ÎT
* êä3ö  £oÎT
* μ÷óà £oÄú2¿μ÷óÃ
static void ADC1_Mode_Config(void)
        DMA_InitTypeDef DMA_InitStructure;
        ADC_InitTypeDef ADC_InitStructure;
        /* DMA channel1 configuration */
        DMA_DeInit(DMA1_Channel1);
        DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
        DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStructure.DMA_BufferSize = 1;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(DMA1_Channel1, &DMA_InitStructure);
        /* Enable DMA channel1 */
        DMA_Cmd(DMA1_Channel1, ENABLE);
        /* ADC1 configuration */
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
        ADC_InitStructure.ADC_ScanConvMode = DISABLE ;
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
        ADC_InitStructure.ADC_NbrOfChannel = 1;
        ADC_Init(ADC1, &ADC_InitStructure);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_55Cycles5);
        /* Enable ADC1 DMA */
        ADC_DMACmd(ADC1, ENABLE);
        /* Enable ADC1 */
        ADC_Cmd(ADC1, ENABLE);
        ADC_ResetCalibration(ADC1);
        while(ADC_GetResetCalibrationStatus(ADC1));
        ADC_StartCalibration(ADC1);
        while(ADC_GetCalibrationStatus(ADC1));
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
void ADC1_Init(void)
        ADC1_GPIO_Config();
        ADC1_Mode_Config();
ID:301191 发表于 2022-1-18 03:06 | 只看该作者
顶一下
ID:858418 发表于 2022-1-19 14:05 | 只看该作者
在没有开启负载时,已降低到0x 04H 不管了,只能这样了
ID:169891 发表于 2022-1-27 15:52 | 只看该作者
你是怎么降低到0x04H的
