查看: 2226|回复: 4
PIC16F877程序问题
ID:216579 发表于 2022-2-6 20:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<pic.h>
#define uint  unsigned int
__CONFIG(0x3B31);
void init();
uint intnum;
        init();
                if(intnum==5)
                        intnum=0;
                        RD0=!RD0;
void init()
        TRISD=0;
        PORTD=0;
        OPTION=0x07;
        INTCON=0xa0;
        TMR0=61;
void interrupt time0()
        T0IF=0;
        TMR0=61;
        intnum++;
这是什么原因,程序写的没有问题啊
ID:216579 发表于 2022-2-7 09:51 | 只看该作者
清除已成功 (总时间: 6ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'C:/Users/50331/Desktop/pic10f200/16F877_TMR0.X'
make  -f nbproject/Makefile-default.mk dist/default/production/16F877_TMR0.X.production.hex
make[2]: Entering directory 'C:/Users/50331/Desktop/pic10f200/16F877_TMR0.X'
"C:\Program Files\Microchip\xc8\v2.32\bin\xc8-cc.exe"  -mcpu=16F877A -c   -mdfp="C:/Program Files/Microchip/MPLABX/v5.50/packs/Microchip/PIC16Fxxx_DFP/1.2.33/xc8"  -fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-3 -Wa,-a -DXPRJ_default=default  -msummary=-psect,-class,+mem,-hex,-file  -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall   -std=c99 -gdwarf-3 -mstack=compiled:auto:auto     -o build/default/production/main.p1 main.c
::: advisory: (2049) C99 compliant libraries are currently not available for baseline or mid-range devices, or for enhanced mid-range devices using a reentrant stack; using C90 libraries
main.c:74:2: error: use of undeclared identifier 'OPTION'
        OPTION=0x07;
main.c:79:6: error: variable has incomplete type 'void'
main.c:79:15: error: expected ';' after top level declarator
3 errors generated.
(908) exit status = 1
nbproject/Makefile-default.mk:107: recipe for target 'build/default/production/main.p1' failed
make[2]: Leaving directory 'C:/Users/50331/Desktop/pic10f200/16F877_TMR0.X'
nbproject/Makefile-default.mk:91: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/50331/Desktop/pic10f200/16F877_TMR0.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[2]: *** [build/default/production/main.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
编译已失败 (退出值2, 总时间: 3s)
ID:1004618 发表于 2022-2-10 12:03 | 只看该作者
你试一下OPTION_REG呢
ID:216579 发表于 2022-2-14 15:38 | 只看该作者
帅气男孩 发表于 2022-2-10 12:03
你试一下OPTION_REG呢
OPTION_REG可以,但中断函数还是报错什么问题
ID:1019848 发表于 2022-12-27 13:53 | 只看该作者
XC8编译器得用void __interrupt() ISR(void)
