- /*此函数为按键发送 ,同时在数码管上显示
- /*功能:单片机向PC发送按键字符,0-9 英文
- // 上下左右对错,U,D,L,R,Y,N
- // 按一下,发送一个,不按不发送,
- // 长按一直发送
- // 数码管上显示0-9 ABCDEF
- //日期:2022-4-14AM
- #include <reg52.h>
- #include "key16-2.h"
- typedef unsigned int u16;
- sbit led=P2^2;
- u8 temp,n;
- void delay(u16 n)
- while(n--);
- void UART_init(void)
- SCON = 0x50;
- TMOD = 0x20;
- TH1 = 0xFD;
- TL1 = 0xFD;
- TR1 = 1;
- //ES = 1;
- //EA = 1;
- void Uart_send(u8 dat)
- SBUF = dat;
- while(!TI);
- main()
- UART_init();
- led=0;
- while(1)
- temp=key_scan();
- if(temp!=0xff)
- Uart_send(temp);
- switch (temp)
- case 'Y': temp=11;break;
- case 'N': temp=10;break;
- case 'L': temp=12;break;
- case 'D': temp=13;break;
- case 'U': temp=14;break;
- case 'R': temp=15;break;
- P0=~num[temp]; //加“~”是因为我的代码表是共阴数码的,而板
- delay(30000); //子上是共阳的
- #ifndef _KEY16_H_
- #define _KEY16_H_
- typedef unsigned char u8;
- sbit hang1=P1^7;
- sbit hang2=P1^6;
- sbit hang3=P1^5;
- sbit hang4=P1^4;
- sbit lie1=P1^3;
- sbit lie2=P1^2;
- sbit lie3=P1^1;
- sbit lie4=P1^0;
- u8 code num[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71
- u8 key_val=0xff;
- void key_delay()
- u8 x,y;
- for(x=200;x>0;x--)
- for(y=220;y>0;y--);
- u8 key_scan()
- hang1=0;
- hang2=1;
- hang3=1;
- hang4=1;
- if(lie1==0) //right 15
- key_delay();
- if(lie1==0)
- return 'R'+'\0';
- while(lie1==0);
- if(lie2==0) //up 14
- key_delay();
- if(lie2==0)
- return 'U'+'\0';
- while(lie2==0);
- if(lie3==0) //down 13
- key_delay();
- if(lie3==0)
- return 'D'+'\0';
- while(lie3==0);
- if(lie4==0) //left 12
- key_delay();
- if(lie4==0)
- return 'L'+'\0';
- while(lie4==0);
- hang1=1;
- hang2=0;
- hang3=1;
- hang4=1;
- if(lie1==0) //ok
- key_delay();
- if(lie1==0)
- return 'Y'+'\0';
- while(lie1==0);
- if(lie2==0) //9
- key_delay();
- if(lie2==0)
- return 9;
- while(lie2==0);
- if(lie3==0) //3
- key_delay();
- if(lie3==0)
- return 3;
- while(lie3==0);
- if(lie4==0) //6
- key_delay();
- if(lie4==0)
- return 6;
- while(lie4==0);
- hang1=1;
- hang2=1;
- hang3=0;
- hang4=1;
- if(lie1==0) //0
- key_delay();
- if(lie1==0)
- return 0;
- while(lie1==0);
- if(lie2==0) //8
- key_delay();
- if(lie2==0)
- return 8;
- while(lie2==0);
- if(lie3==0) //2
- key_delay();
- if(lie3==0)
- return 2;
- while(lie3==0);
- if(lie4==0) //5
- key_delay();
- if(lie4==0)
- return 5;
- while(lie4==0);
- hang1=1;
- hang2=1;
- hang3=1;
- hang4=0;
- if(lie1==0) //ESC
- key_delay();
- if(lie1==0)
- return 'N'+'\0';
- while(lie1==0);
- if(lie2==0) //7
- key_delay();
- if(lie2==0)
- return 7;
- while(lie2==0);
- if(lie3==0) //1
- key_delay();
- if(lie3==0)
- return 1;
- while(lie3==0);
- if(lie4==0) //4
- key_delay();
- if(lie4==0)
- return 4;
- while(lie4==0);
- return 0xff;
- #endif
