查看: 1889|回复: 0
CH32V103读取DS3231源程序
ID:678336 发表于 2022-4-18 19:57 | 显示全部楼层 |阅读模式
CH32V103提供了两组硬件IIC,经过一段时间探索觉得比较好用。这里提供了使用I2C1读写DS3231的例程代码,利用printf()函数在串口助手中显示读取的DS3231日期时间数据。例程在MounRiver开发环境下调试通过,上传供交流。
  1. /*
  2. *@Note
  3.         串口打印调试例程:
  4.     USART1_Tx(PA9)。
  5.         本例程演示硬件I2C1读写DS3231。
  6. */
  7. #include "debug.h"
  8. /* Global typedef */
  9. /* Global define */
  10. /* Global Variable */
  11. /*********************************************************************/
  12. void Set_IIC(void) //选择I2C1
  13. {
  14.     I2C_InitTypeDef  I2C_InitStructure; //声明i2c
  15.     GPIO_InitTypeDef  GPIO_InitStructure; //声明GPIO
  16.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE); //打开i2c1时钟
  17.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE); //打开GPIO时钟
  18.     GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7; //i2c1引脚
  19.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //GPIO端口输出速率
  20.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;//I2C必须复用开漏输出
  21.     GPIO_Init(GPIOB, &GPIO_InitStructure); //GPIO端口B,SCL-PB6,SDA-PB7
  22.     I2C_DeInit(I2C1); //外设寄存器配置为默认
  23.     I2C_AcknowledgeConfig(I2C1,ENABLE);
  24.     I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
  25.     I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
  26.     I2C_InitStructure.I2C_OwnAddress1 = 0x30;
  27.     I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
  28.     I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  29.     I2C_InitStructure.I2C_ClockSpeed = 400000;
  30.     I2C_Cmd(I2C1, ENABLE);
  31.     I2C_Init(I2C1, &I2C_InitStructure);
  32. }
  33. void DS3231_ByteWrite(u8 addr, u8 data)
  34. {
  35.     I2C_AcknowledgeConfig(I2C1,ENABLE);
  36.     I2C_GenerateSTART(I2C1,ENABLE);
  37.     while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT));
  38.     I2C_Send7bitAddress(I2C1,0xD1,I2C_Direction_Transmitter);
  39.     while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
  40.     I2C_SendData(I2C1,addr);
  41.     while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTING));
  42.     I2C_SendData(I2C1,data);
  43.     while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  44.     I2C_GenerateSTOP(I2C1,ENABLE);
  45. }
  46. u8 DS3231_ByteRead(u8 nAddr)
  47. {
  48.     I2C_AcknowledgeConfig(I2C1,ENABLE);
  49.     I2C_GenerateSTART(I2C1,ENABLE);
  50.     while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT)){;}
  51.     I2C_Send7bitAddress(I2C1,0xD0,I2C_Direction_Transmitter);
  52.     while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)){;}
  53.     I2C_SendData(I2C1,nAddr);
  54.     while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED)){;}
  55.     I2C_GenerateSTART(I2C1,ENABLE);
  56.     while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT)){;}
  57.     I2C_Send7bitAddress(I2C1,0xD1,I2C_Direction_Receiver);
  58.     while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)){;}
  59.     I2C_AcknowledgeConfig(I2C1,DISABLE);
  60.     I2C_GenerateSTOP(I2C1,ENABLE);
  61.     while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_RECEIVED)){;}
  62.     return I2C_ReceiveData(I2C1);
  63. }
  64. u8 BCD2HEX(u8 val)   //BCD转换为Byte
  65. {
  66.     u8 i;
  67.     i= val&0x0f;
  68.     val >>= 4;
  69.     val &= 0x0f;
  70.     val *= 10;
  71.     i += val;
  72.     return i;
  73. }
  74. u16 B_BCD(u8 val)//B码转换为BCD码
  75. {
  76.     u8 i,j,k;
  77.     i=val/10;
  78.     j=val%10;
  79.     k=j+(i<<4);
  80.     return k;
  81. }
  82. u8 tt=0;
  83. int main(void)
  84. {
  85.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  86.     Delay_Init();
  87.     USART_Printf_Init(115200);
  88.     printf("****************\r\n");
  89.     printf("This is DS3231 example\r\n");
  90.     Set_IIC();
  91.     printf("Set IIC OK!\r\n");
  92.     Delay_Ms(3000);
  93.     //修改日期时间,只用一次
  94.     //tt=B_BCD(22);
  95.     //DS3231_ByteWrite(0x06, tt);//修改年
  96.     //tt=B_BCD(4);
  97.     //DS3231_ByteWrite(0x05, tt);//修改月
  98.     //tt=B_BCD(18);
  99.     //DS3231_ByteWrite(0x04, tt);//修改日
  100.     //tt=B_BCD(16);
  101.     //DS3231_ByteWrite(0x02, tt);//修改时
  102.     //tt=B_BCD(30);
  103.     //DS3231_ByteWrite(0x01, tt);//修改分
  104.     //tt=B_BCD(0);
  105.     //DS3231_ByteWrite(0x00, tt);//修改秒
  106.     while(1)
  107.     {
  108.         printf("********* \r\n");
  109.         tt=BCD2HEX(DS3231_ByteRead(0x06));
  110.         printf(" year:%d\n",tt);
  111.         tt=BCD2HEX(DS3231_ByteRead(0x05));
  112.         printf(" month:%d\n",tt);
  113.         tt=BCD2HEX(DS3231_ByteRead(0x04));
  114.         printf(" day:%d\n",tt);
  115.         tt=BCD2HEX(DS3231_ByteRead(0x02));
  116.         printf(" hour:%d\n",tt);
  117.         tt=BCD2HEX(DS3231_ByteRead(0x01));
  118.         printf(" min:%d\n",tt);
  119.         tt=BCD2HEX(DS3231_ByteRead(0x00));
  120.         printf(" sec:%d\n",tt);
  121.         printf(" ********* %d\n");
  122.         Delay_Ms(995);
  123.     }
  124. }
MounRiver_Studio代码工程下载:
DS3231-I2C1.7z (126.57 KB, 下载次数: 4)
参与人数 1黑币 +40 收起 理由
admin + 40 共享资料的黑币奖励!
