查看: 1106|回复: 0
Nations G031源码 点亮LED灯
ID:1036413 发表于 2022-6-22 16:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
LED闪烁的程序源码:
#include "main.h"
#include <stdio.h>
#include <stdint.h>
* @brief  Main program.
int main(void)
    /*SystemInit() function has been called by startup file startup_n32g031.s*/
    /* Initialize Led1~Led3 as output pushpull mode*/
    LedInit(PORT_GROUP, LED1_PIN | LED2_PIN | LED3_PIN);
    /*Turn on Led1~Led3*/
    LedOn(PORT_GROUP, LED1_PIN | LED2_PIN | LED3_PIN);
    while (1)
        /*LED1_PORT, LED2_PORT and LED3_PORT are the same port group.
         *Enable Led2 blink and not effect Led1 and Led2 by Exclusive-OR operation.*/
        LedBlink(PORT_GROUP, LED2_PIN);
        LedOff(PORT_GROUP, LED3_PIN);
        /* Insert delay */
        Delay(0x28FFFF);
         LedOff(PORT_GROUP, LED1_PIN);
      Delay(0x28FFFF);
        LedOn(PORT_GROUP, LED1_PIN | LED3_PIN);
        Delay(0x28FFFF);
void Delay(uint32_t count)
    for (; count > 0; count--)
}void LedInit(GPIO_Module* GPIOx, uint16_t Pin)
    GPIO_InitType GPIO_InitStructure;
    /* Check the parameters */
    assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
    /* Enable the GPIO Clock */
    if (GPIOx == GPIOA)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA, ENABLE);
    else if (GPIOx == GPIOB)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB, ENABLE);
    else if (GPIOx == GPIOC)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOC, ENABLE);
    else if (GPIOx == GPIOF)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOF, ENABLE);
        return;
    /* Configure the GPIO pin */
    if (Pin <= GPIO_PIN_ALL)
        GPIO_InitStruct(&GPIO_InitStructure);
        GPIO_InitStructure.Pin = Pin;
        GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUTPUT_PP;
        GPIO_InitPeripheral(GPIOx, &GPIO_InitStructure);
void LedOn(GPIO_Module *GPIOx, uint16_t Pin)
    GPIO_SetBits(GPIOx, Pin);
void LedOff(GPIO_Module* GPIOx, uint16_t Pin)
    GPIO_ResetBits(GPIOx, Pin);
}void LedBlink(GPIO_Module* GPIOx, uint16_t Pin)
    GPIO_TogglePin(GPIOx, Pin);
#ifdef USE_FULL_ASSERT
void assert_failed(const uint8_t* expr, const uint8_t* file, uint32_t line)
    while (1)
#endif // USE_FULL_ASSERT
