查看: 1907|回复: 4
LCD1602.h(8): error C129: missing ';' before 'LCD1602_RS'
ID:1044527 发表于 2022-9-12 11:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问这个错误该怎么办?改了很久都不对
#ifndef __LCD1602_H__
#define __LCD1602_H__
#define LCD1602_PORT P0
//#include <reg52.h>
#include <STC89C5xRC.H>
Sbit LCD1602_RS = P2^6;
Sbit LCD1602_RW = P2^5;
Sbit LCD1602_EN = P2^7;
extern void LCD1602_delay_ms(unsigned int n);
extern void LCD1602_write_com(unsigned char com);
extern void LCD1602_printc(unsigned char dat);
extern void LCD1602_prints(unsigned char *s);
extern void LCD1602_Init();
extern void LCD1602_set_position( bit hang, unsigned char x);           //LCD?????x?
extern void LcdPrintNum(unsigned int num);
#endif
ID:123289 发表于 2022-9-12 14:09 | 只看该作者
错误在【LCD1602.h】中找。
ID:155507 发表于 2022-9-12 14:31 | 只看该作者
  1. #ifndef __LCD1602_H__
  2. #define __LCD1602_H__
  3. #define LCD1602_PORT P0
  4. //#include <reg52.h>
  5. #include <STC89C5xRC.H>
  6. sbit LCD1602_RS = P2^6;  //Sbit LCD1602_RS = P2^6; Sbit 的S是小写 <-----------------
  7. sbit LCD1602_RW = P2^5;  //Sbit LCD1602_RW = P2^5;
  8. sbit LCD1602_EN = P2^7;  //Sbit LCD1602_EN = P2^7;
  9. //????????
  10. extern void LCD1602_delay_ms(unsigned int n);
  11. extern void LCD1602_write_com(unsigned char com);
  12. extern void LCD1602_printc(unsigned char dat);
  13. extern void LCD1602_prints(unsigned char *s);
  14. extern void LCD1602_Init();
  15. extern void LCD1602_set_position( bit hang, unsigned char x);           //LCD?????x?
  16. extern void LcdPrintNum(unsigned int num);
  17. #endif
ID:59202 发表于 2022-9-12 19:58 | 只看该作者
你把小写sbit写成大写Sbit了,在keil编辑器中对关键字的字体和颜色做一下设置,比如设置成蓝色或红色,斜体字等,一眼就可以看出关键字是否写正确了
ID:282850 发表于 2022-9-14 00:22 | 只看该作者
具体不好说,一种是问题在其它C或h中,另一种是把#include <STC89C5xRC.H>放在文件最前,不要在#ifndef 及#define内试试
