查看: 1279|回复: 3
分享一个74HC595驱动数码管,亮度可调的单片机代码
ID:101869 发表于 2022-11-14 20:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
利用的类似占空比调整方式实现,整体程序采用框架编程方式,移植方便,新手作品欢迎指正.
  1. #include "all.H"
  2. u8 data HC595_Write_Buffer[2];
  3. void HC595_Init()
  4. {
  5.         P5M1 = 0x00;
  6.         P5M0 = 0x30; // P5(双双推推双双双双)
  7.         P3M1 = 0x00;
  8.         P3M0 = 0x08; // P3(双双双双推双双双)
  9.         HC595_DS = 1;
  10.         HC595_SH = 0;
  11.         HC595_ST = 0;
  12. }
  13. void HC595_Write_Data_Drive()
  14. {
  15.         u8 data i;
  16.         HC595_DS = 1;
  17.         HC595_SH = 0;
  18.         HC595_ST = 0;
  19.         for (i = 0; i < 8; i++)
  20.         {
  21.                 HC595_SH = 0;
  22.                 HC595_DS = HC595_Write_Buffer[1] & 0x80;
  23.                 HC595_Write_Buffer[1] <<= 1;
  24.                 HC595_SH = 1;
  25.         }
  26.         for (i = 0; i < 8; i++)
  27.         {
  28.                 HC595_SH = 0;
  29.                 HC595_DS = HC595_Write_Buffer[0] & 0x80;
  30.                 HC595_Write_Buffer[0] <<= 1;
  31.                 HC595_SH = 1;
  32.         }
  33.         HC595_ST = 1;
  34.         HC595_SH = 0;
  35.         HC595_DS = 1;
  36.         HC595_ST = 0;
  37. }
  1. #include "all.H"
  2. u8 data SMG_Write_Buffer[8];
  3. bit blink_flag;
  4. u8 code SMG_SEG[24] = {
  5.         0x3F, //"0"
  6.         0x06, //"1"
  7.         0x5B, //"2"
  8.         0x4F, //"3"
  9.         0x66, //"4"
  10.         0x6D, //"5"
  11.         0x7D, //"6"
  12.         0x07, //"7"
  13.         0x7F, //"8"
  14.         0x6F, //"9"
  15.         0x77, //"A"
  16.         0x7C, //"B"
  17.         0x39, //"C"
  18.         0x5E, //"D"
  19.         0x79, //"E"
  20.         0x71, //"F"
  21.         0x76, //"H"
  22.         0x38, //"L"
  23.         0x37, //"n"
  24.         0x3E, //"u"
  25.         0x73, //"P"
  26.         0x5C, //"o"
  27.         0x40, //"-"
  28.         0x00, //熄灭
  29. };
  30. u8 code SMG_GRID[9] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0x00};
  31. void SMG_Display_Ser()
  32. {
  33.         static u8 count = 0;
  34.         static bit places_Display_flag = 0;
  35.         count++;
  36.         if (count > 7)
  37.         {
  38.                 count = 0;
  39.         }
  40.         switch (count) //判断count的值,
  41.         {
  42.         case 0: //如果是0显示第1位数码管
  43.         case 1: //如果是1显示第2位数码管
  44.         case 2: //如果是2显示第3位数码管
  45.         case 3: //如果是3显示第4位数码管
  46.         case 4: //如果是4显示第5位数码管
  47.         case 5: //如果是5显示第6位数码管
  48.         case 6: //如果是6显示第7位数码管
  49.         case 7: //如果是7显示第8位数码管
  50.                 if (SMG_Write_Buffer[count] != 0 && !places_Display_flag)
  51.                 {
  52.                         places_Display_flag = 1;
  53.                 }
  54.                 if (!blink_flag || !places_Display_flag)
  55.                 {
  56.                         HC595_Write_Buffer[0] = 0x00;
  57.                         HC595_Write_Buffer[1] = 0x00;
  58.                 }
  59.                 if ((blink_flag) && (places_Display_flag || count == 7))
  60.                 {
  61.                         HC595_Write_Buffer[0] = SMG_SEG[SMG_Write_Buffer[count]];
  62.                         //根据count顺序,从SMG_Write_Buffer中轮流提取数据,再找到该数据的模型段码
  63.                         HC595_Write_Buffer[1] = SMG_GRID[count]; //根据count的顺序 找到对应的位选码
  64.                 }
  65.                 HC595_Write_Data_Drive(); //缓存数据传输到595芯片中去
  66.                 if (count == 7)
  67.                 {
  68.                         places_Display_flag = 0;
  69.                 }
  70.                 break;
  71.         }
  72. }
Keil代码下载: Keil代码.7z (17.85 KB, 下载次数: 22)
参与人数 1黑币 +10 收起 理由
admin + 10 共享资料的黑币奖励!
收藏收藏1 分享淘帖 顶 踩
ID:262 发表于 2022-11-14 23:25 | 只看该作者
电路是如何连接的呢?
ID:194257 发表于 2022-11-15 08:48 | 只看该作者
挺好的驱动方式,只需要三根口线就可以了,显示效果还能得到保证。程序写的也比较简练。
ID:433219 发表于 2022-11-15 17:01 | 只看该作者
heicad 发表于 2022-11-14 23:25
电路是如何连接的呢?
  估计是:一片 595 ->接8个 seg段,   另外一片595 接 8个 位
