查看: 4126|回复: 12
求助:网上找来的单片机程序,想添加控制继电器功能
ID:816562 发表于 2023-2-12 19:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    网上找来的程序,基于51单片机的倒计时装置,定时时间到后蜂鸣器鸣叫,倒计时结束,想添加一个控制继电器功能,就是计时开始继电器吸合,计时结束继电器释放,不知道怎么加,请各位大佬帮帮忙,在此谢过了!
    以下是源码:
//        Copyright (C) 2020 Jobcrazy
//        All rights reserved
#include <reg52.h>
//Button registers
sbit Step1m = P3^6;  //按键3,+1分钟
sbit Step10m = P3^5;  //按键2,+10分钟
sbit Step1h = P3^4;  //按键1,+1小时
sbit StepStart = P3^7;  //按键4,开始计时
//Beep register
sbit Beep = P1^6;  //蜂鸣器
//Relay
sbit Relay = P1^7;  //继电器
//Time Led Dot register
sbit TIME_DOT = P1^5;  //数码管":"
//Time Led Segment register
sbit ShuMa_Duan_0 = P1^0;  //数码管1
sbit ShuMa_Duan_1 = P1^1;  //数码管2
sbit ShuMa_Duan_2 = P1^2;  //数码管3
sbit ShuMa_Duan_3 = P1^3;  //数码管4
//Initial settings
#define DEFAULT_HOUR 00
#define DEFAULT_MINUTE 00
#define DEFAULT_SECOND 00
volatile int Hour = DEFAULT_HOUR;
volatile int Minute = DEFAULT_MINUTE;
volatile int Second = DEFAULT_SECOND;
//Led Number Definitions
code unsigned char ShuMa_Data[10] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92,0x82,0xF8,0x80,0x90};
//Led Number Indexes
volatile int Shi_Left = 0;
volatile int Ge_Left = 0;
volatile int Shi_Right = 0;
volatile int Ge_Right = 0;
//Delay 1 minisecond
void Delay_1ms( int i )
    for( ; i > 0; --i )
        int j = 0;
        for( ; j < 110; ++j )
//Timer Settings
void Init_Timer()
    TMOD = 0x11; //Using timer 0 and timer 1
    TH0  = 0xB8;
    TL0  = 0x00;  //Timer0 = 20ms
    TH1  = 0xB8;
    TL1  = 0x00;  //Timer1 = 20ms
    TR0  = 0x01;  //Enable Timer 0
    TR1  = 0x00;
//Enable Timer
void Init_Interrupt()
    ET0 = 1;
    ET1 = 1;
    EA = 1;
//Show Number on the Timer Led
void  ShuMa(unsigned char ShuMa_Wei, unsigned char ShuMa_Index)
    P2 = ShuMa_Data[ShuMa_Index];
    if( ShuMa_Wei == 0 )
        ShuMa_Duan_0 = 0;
        ShuMa_Duan_1 = 1;
        ShuMa_Duan_2 = 1;
        ShuMa_Duan_3 = 1;
    else if( ShuMa_Wei == 1 )
        ShuMa_Duan_0 = 1;
        ShuMa_Duan_1 = 0;
        ShuMa_Duan_2 = 1;
        ShuMa_Duan_3 = 1;
    else if( ShuMa_Wei == 2 )
        ShuMa_Duan_0 = 1;
        ShuMa_Duan_1 = 1;
        ShuMa_Duan_2 = 0;
        ShuMa_Duan_3 = 1;
    else if( ShuMa_Wei == 3 )
        ShuMa_Duan_0 = 1;
        ShuMa_Duan_1 = 1;
        ShuMa_Duan_2 = 1;
        ShuMa_Duan_3 = 0;
    //We must delay 1ms here, or else the Led will not show a correct number
    Delay_1ms(1);
//Convert the time to a displayable format
void CalcSecond()
    if( 0 < Hour )
        Shi_Left = Hour / 10;
        Ge_Left = Hour % 10;
        Shi_Right = Minute / 10;
        Ge_Right =  Minute % 10;
        Shi_Left = Minute / 10;
        Ge_Left = Minute % 10;
        Shi_Right = Second / 10;
        Ge_Right = Second % 10;
//Counter Timer
void Interrupt_Timer_0() interrupt 1
    static int Counter = 0;
    TH0 = 0xB8;
    TL0 = 0x00;
    ++Counter;
    if( 49 < Counter )
        //Ths scope will run 1 time per second
        Counter = 0;
        TIME_DOT = ~TIME_DOT;
        Second--;
        //Let's see how long time is left
        if( Second < 0 )
            Second = 59;
            Minute -= 1;
        if( Minute < 0 )
            if( 0 < Hour )
                Hour--;
                Minute = Second = 59;
                Hour = Minute = Second = 0;
                TR0 = 0; //Disable counter timer
                TR1 = 1; //Enable Beep Timer
        CalcSecond();
//Beep timer
void Interrupt_Timer_1() interrupt 3
    static int n = 0, Counter = 0;
    TH1 = 0xB8;
    TL1 = 0x00;
    ++Counter;
    if( Counter < 10 )
        Beep = 0;
    else if( Counter < 30 )
        Beep = 1;
    else if( Counter > 49 )
        Counter = 0;
        n++;
        if( n >= 5 )
            n = 0;
            //Disable two timers
            TR0 = 0;
            TR1 = 0;
//Covert time to be recognizable
void formatTime()
    if( Minute >= 60 )
        Minute = 0;
        Hour = Hour + 1;
    if( Hour >= 99 )
        Hour = 0;
        Minute = 0;
        Second = 0;
    CalcSecond();
    //To avoid long press
    int Pressed = 0;
    //Light Timer Dot
    TIME_DOT = 0;
    //Turn Off Beep
    Beep = 1;
    //Make P3 output high-level signal
    P3 = 0xFF;
    CalcSecond();
    //Infinite loop
        formatTime();
        //Show time the led screen
        ShuMa( 0, Shi_Left );
        ShuMa( 1, Ge_Left );
        ShuMa( 2, Shi_Right );
        ShuMa( 3, Ge_Right );
        if( 0 == TR0 && 0 == TR1 ) //If timer is not running
            if( 0 == Step1m && 0 == Pressed )
                //If Step1m button is pressed down
                Pressed = 1;
                Minute = Minute + 1;
            else if( 0 == Step10m && 0 == Pressed )
                //If Step10m button is pressed down
                Pressed = 1;
                Minute = Minute + 10;
            else if( 0 == Step1h && 0 == Pressed )
                //If Step1h button is pressed down
                Pressed = 1;
                Hour = Hour + 1;
            else if( 0 == StepStart && 0 == Pressed )
                //If StepStart button is pressed down
                Pressed = 1;
                if ( 0 != Hour || 0 != Minute || 0 != Second )
                    Init_Timer();
                    Init_Interrupt();
                if( 1 == Step1m && 1 == Step10m && 1 == Step1h && 1 == StepStart )
                    //If no button is pressed down
                    Pressed = 0;
Timer-master.zip
46.24 KB, 下载次数: 6
收藏收藏1 分享淘帖 顶 踩
ID:996773 发表于 2023-2-13 09:14 | 只看该作者
搞汇编的我真心看不懂这c语言,天书一样,倒计时是很简单的程序,用c写怎么这么长?对于汇编来说,只要在蜂鸣器不工作的时候加一条clr p0.1或者0.2任意端口拉低就可以用这个口驱动继电器了
ID:161164 发表于 2023-2-13 09:30 | 只看该作者
  1. //...
  2. sbit Relay = Px^y;
  3. void main()
  4. {
  5. //...
  6. while(1)
  7. {
  8. //...
  9. Relay = !TR0;
  10. }
  11. }
ID:816562 发表于 2023-2-13 19:16 来自触屏版 | 只看该作者
lkc8210 发表于 2023-2-13 09:30
万分感谢,我通过您的代码问题已经解决!
ID:492633 发表于 2023-2-13 21:17 来自触屏版 | 只看该作者
蜂鸣器是0启动1关闭,那你可以用npn型三极管直接驱动继电器,当蜂鸣器不响时继电器导通,蜂鸣器响时继电器关闭
ID:579397 发表于 2023-2-13 23:05 | 只看该作者
                    Init_Timer();
                    Init_Interrupt();
Relay=~Relay;
Relay=~Relay;
                    Pressed = 0;
ID:579397 发表于 2023-2-13 23:08 | 只看该作者
我也做了一个,用18650电池的
kingzr00 发表于 2023-2-13 19:16
万分感谢,我通过您的代码问题已经解决!
数码管没有消隐
ID:816562 发表于 2023-2-14 00:54 来自触屏版 | 只看该作者
3wjkdhus 发表于 2023-2-13 21:17
蜂鸣器是0启动1关闭,那你可以用npn型三极管直接驱动继电器,当蜂鸣器不响时继电器导通,蜂鸣器响时继电器 ...
感谢你提供的解决思路,蜂鸣器是计时结束时响5声,如果用蜂鸣器的引脚驱动继电器,当计时结束时就会重复开关5次,有可能对电气造成伤害,不过现在问题已经解决了!
ID:816562 发表于 2023-2-14 00:55 来自触屏版 | 只看该作者
hi等你 发表于 2023-2-13 09:14
搞汇编的我真心看不懂这c语言,天书一样,倒计时是很简单的程序,用c写怎么这么长?对于汇编来说,只要在蜂 ...
感谢,问题已经解决了!
ID:816562 发表于 2023-2-16 23:40 来自触屏版 | 只看该作者
已经组装好了,达到预期效果!
ID:816562 发表于 2023-2-16 23:42 来自触屏版 | 只看该作者
完成效果
ID:816562 发表于 2023-2-18 15:49 来自触屏版 | 只看该作者
                    Init_Timer() ...
谢谢!
