好久没有发帖子了,感谢平台一直帮助我,我今天分享一种彩灯WS2811幻彩芯片的程序,里面有各种模式 渐变、跳变、闪烁、跑马、追逐等模式,还可以写更多的,主控采用目前比较流行且有性价的辉芒微FT60F211RB芯片SOP-8,FLASH的,才2毛多,在实际应用中绝对实用,可以大量投产。附件中有PCB原代码,及图片视频等资料,可以参考。
制作出来的实物图如下:
正面实拍
反面实拍
- /* 文件名:main.c
- * 功能: 触摸
- * IC: FT60F123RB 16MHZ 2T模式
- * 晶振: 16M/2T
- #include "FMD.h"
- #include "SYSCFG.h";
- //***********************宏定义*****************************
- #define uchar unsigned char
- #define uint unsigned int
- #define ulong unsigned long
- #define RGB_count 16
- #define RGB_speed 90
- uint shudu=0;
- #define DIN RA4 //IO输出
- uchar mod;
- const uchar table[]={255,0,0,0,255,0,0,0,255,255,255,0,255,0,255,0,255,255};
- const uchar table1[]={255,0,0,255,0,0,255,0,0,0,255,0,0,255,0,0,255,0,0,0,255,0,0,255,0,0,255,255,255,0,255,255,0,255,255,0,255,0,255,255,0,255,255,0,255,0,255,255,0,255,255,0,255,255};
- //读取EEPROM的函数
- uchar n,i,num;
- uchar EEPROMread(uchar EEAddr)
- uchar ReEEPROMread;
- EEADR = EEAddr; //将地址写入EEADR寄存器
- RD = 1;
- NOP();
- NOP();
- NOP();
- NOP();
- ReEEPROMread = EEDAT; //EEPROM的读数据 ReEEPROMread = EEDATA;
- RD = 0;
- return ReEEPROMread;
- //函数名称:EEPROMwrite
- //功能: 写数据到EEPROM
- //输入参数:EEAddr 需要写入数据的地址
- // Data 需要写入的数据
- //返回参数:无
- void EEPROMwrite(uchar EEAddr,uchar Data)
- GIE = 0; //写数据必须关闭中断
- while(GIE); //等待GIE为0
- EEADR = EEAddr; //EEPROM的地址 写入目标地址
- EEDAT = Data; //EEPROM的写数据 EEDATA = Data; 写入目标数据
- EEIF = 0; //中断标志位清0
- EECON1 |= 0x34; //置位WREN1,WREN2,WREN3三个变量.
- WR = 1; //置位WR启动编程
- NOP();
- NOP();
- NOP();
- NOP();
- while(WR); //等待EE写入完成
- GIE = 1;
- /***************EEPROM初始化***************************************/
- void EEPROM_init()
- EEPROMwrite(0x55,0xaa);
- /*************0码*******************/
- void DIN_bit_0()
- DIN=1;
- DIN=0; //1+3+4*7
- /*************1码*******************/
- void DIN_bit_1()
- DIN=1; //1+3+4*7+1
- NOP(); NOP(); NOP(); NOP(); NOP(); NOP();
- DIN=0;
- /*************reset码*******************/
- void reset()
- uchar a,b;
- DIN=0;
- for(b=1;b>0;b--)
- for(a=1;a>0;a--);
- NOP(); //if Keil,require use intrins.h
- /*************数据传输******************/
- void send_dat(uchar dat)
- { //高位先传
- uchar i;
- for(i=8;i>0;i--)
- if(dat & 0x80)
- DIN_bit_1();
- else
- DIN_bit_0();
- dat <<=1;
- void send_rgb(uchar g,uchar r,uchar b)
- send_dat(g);
- send_dat(r);
- send_dat(b);
- /***************延时******************/
- void delay(uint t)
- unsigned j;
- while(t--)
- for(j=0;j<100;j++);
- void delay1(uchar t)
- unsigned j;
- while(t--)
- for(j=0;j<10;j++);
- * 函数名:POWER_INITIAL
- * 功能: 上电系统初始化
- * 输入: 无
- * 输出: 无
- void SYS_INITIAL (void)
- OSCCON = 0B01110000;//WDT 32KHZ IRCF=110=16MHZ/4=4MHZ,0.25US/T
- //Bit0=1,系统时钟为内部振荡器
- //Bit0=0,时钟源由FOSC<2:0>决定即编译选项时选择
- OPTION = 0B00000000; //Bit3 PSA 预分频器分配位 0= 预分频器分配给Timer0模块 1:分配给WDT
- //Bit2:0:预分频比选择位 000: 1:2
- INTCON = 0; //暂禁止所有中断
- PORTA =0B00000000;
- TRISA = 0B00000100; // 0-输出 1-输入
- WPUA = 0B00000100; //PA端口上拉控制 1-开上拉 0-关上拉
- void jiabian1(uchar sudu)//渐变
- uchar i,n;
- send_dat(255);//先赋值给R
- send_dat(0);
- send_dat(0);
- // G渐亮//R渐灭
- for(i=0;i<255;i++)
- for(n=RGB_count;n>0;n--)
- send_dat(255-i);
- send_dat(i);
- send_dat(0);
- reset();
- delay1(sudu);
- delay1(250);
- // G渐亮//R渐灭
- send_dat(0);
- send_dat(255-i);
- send_dat(i);
- reset();
- delay1(sudu);
- delay1(250);
- // RGB渐亮
- send_dat(i);
- send_dat(i);
- send_dat(255);
- reset();
- delay1(sudu);
- delay1(250);
- // B不变//RG渐灭
- send_dat(255);
- send_dat(255-i);
- send_dat(255-i);
- reset();
- delay1(sudu);
- delay1(250);
- void huxi(uchar sudu)//呼吸
- uchar i,n;
- // R渐亮
- send_dat(i);
- send_dat(0);
- send_dat(0);
- reset();
- delay1(sudu);
- // R渐灭
- for(i=255;i>0;i--)
- send_dat(i);
- send_dat(0);
- send_dat(0);
- reset();
- delay1(sudu);
- // G渐亮
- send_dat(0);
- send_dat(i);
- send_dat(0);
- reset();
- delay1(sudu);
- // G渐灭
- send_dat(0);
- send_dat(i);
- send_dat(0);
- reset();
- delay1(sudu);
- // B渐亮
- send_dat(0);
- send_dat(0);
- send_dat(i);
- reset();
- delay1(sudu);
- // B渐灭
- send_dat(0);
- send_dat(0);
- send_dat(i);
- reset();
- delay1(sudu);
- // RG渐亮
- send_dat(i);
- send_dat(i);
- send_dat(0);
- reset();
- delay1(sudu);
- // RG渐灭
- send_dat(i);
- send_dat(i);
- send_dat(0);
- reset();
- delay1(sudu);
- // BR渐亮
- send_dat(i);
- send_dat(0);
- send_dat(i);
- reset();
- delay1(sudu);
- // BR渐灭
- send_dat(i);
- send_dat(0);
- send_dat(i);
- reset();
- delay1(sudu);
- // BG渐亮
- send_dat(0);
- send_dat(i);
- send_dat(i);
- reset();
- delay1(sudu);
- // BG渐灭
- send_dat(0);
- send_dat(i);
- send_dat(i);
- reset();
- delay1(sudu);
- // BGR渐亮
- send_dat(i);
- send_dat(i);
- send_dat(i);
- reset();
- delay1(sudu);
- // RBG渐灭
- send_dat(i);
- send_dat(i);
- send_dat(i);
- reset();
- delay1(sudu);
- void paoma1(uint sudu)
- uchar i,num;
- //R跑马灯增加*******************
- for(i=0;i<=RGB_count;i++)
- for(num=0;num<i;num++)
- send_dat(255);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- //G跑马灯增加*******************
- send_dat(0);
- send_dat(255);
- send_dat(0);
- reset();
- delay(sudu);
- //B跑马灯增加*******************
- send_dat(0);
- send_dat(0);
- send_dat(255);
- reset();
- delay(sudu);
- //RG跑马灯增加*******************
- send_dat(0);
- send_dat(255);
- send_dat(255);
- reset();
- delay(sudu);
- //RB跑马灯增加*******************
- send_dat(255);
- send_dat(0);
- send_dat(255);
- reset();
- delay(sudu);
- //BG跑马灯增加*******************
- send_dat(255);
- send_dat(255);
- send_dat(0);
- reset();
- delay(sudu);
- //RGB跑马灯增加*******************
- send_dat(255);
- send_dat(255);
- send_dat(255);
- reset();
- delay(sudu);
- /********************反向*****************/
- void paoma2(uchar sudu)
- uchar i,num;
- send_dat(255);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- for(num=RGB_count;num>0;num--)
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(0);
- send_dat(255);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(0);
- send_dat(0);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(0);
- send_dat(255);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(255);
- send_dat(0);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(255);
- send_dat(255);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(255);
- send_dat(255);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- void paoma3(uchar sudu)
- uchar i,n,num,t;
- send_dat(255);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(0);
- send_dat(255);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(0);
- send_dat(0);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(0);
- send_dat(255);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(255);
- send_dat(0);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(255);
- send_dat(255);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- send_dat(255);
- send_dat(255);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- void liushui(uchar sudu)
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);//1250
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- /*********R***************/
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- reset();
- delay(sudu);
- void paoma5(uint sudu)
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(255);
- send_dat(255);
- send_dat(255);
- send_dat(0);
- send_dat(255);
- send_dat(255);
- send_dat(255);
- send_dat(0);
- reset();
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(255);
- send_dat(255);
- send_dat(255);
- send_dat(0);
- send_dat(255);
- send_dat(255);
- send_dat(255);
- send_dat(0);
- send_dat(255);
- send_dat(0);
- send_dat(2);
- reset();
- delay(sudu);
- void shanshuo(uint sudu)
- /**************R***********/
- uchar n;
- send_dat(255);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- /**************G***********/
- send_dat(0);
- send_dat(255);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- /**************B***********/
- send_dat(0);
- send_dat(0);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(255);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(255);
- send_dat(0);
- send_dat(255);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu);
- /*for(n=RGB_count;n>0;n--)
- send_dat(255);
- send_dat(255);
- send_dat(0);
- reset();
- delay(sudu);
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay(sudu); */
- void zondong(uint sudu)//多个灯为例 1个灯一组 流动
- uchar n,b,a;
- for(n=0;n<RGB_count;n++)
- b=3*n;
- for(a=0;a<(RGB_count*3);a++)//先扫描出整排灯,静态的初始状态
- send_dat(table[b]);//先取出表格内的3位数 然后通过移位个数*3 因为我们是3位数相加而来
- b++;
- if(b>=(RGB_count*3))//这里面是取数据到最后一位了,要直接清0,从而实现移位
- b=0;
- reset();
- void zondong2(uint sudu)//6个灯为例 3个灯一组 流动
- uchar n,b,a;
- for(n=0;n<6;n++)
- b=9*n;//取样9个
- for(a=0;a<(6*9);a++)//先扫描出整排灯,静态的初始状态
- send_dat(table1[b]);//先取出表格内的3位数 然后通过移位个数*3 因为我们是3位数相加而来
- b++;
- if(b>=(6*9))//这里面是取数据到最后一位了,要直接清0,从而实现移位
- b=0;
- reset();
- * 函数名: main
- * 功能: 主函数
- * 输入: 无
- * 输出: 无
- void main()
- SYS_INITIAL();//系统初始化
- mod=EEPROMread(0x01);
- mod++;
- if(mod>3)
- mod=0;
- EEPROMwrite(0x01,mod);
- switch (mod)
- case 0:
- for(n=0;n<=RGB_count;n++)
- send_dat(0);
- send_dat(0);
- send_dat(0);
- reset();
- delay1(100);
- shudu=50;
- break;
- case 1:
- shudu=30;
- break;
- case 2:
- shudu=1500;
- break;
- case 3:
- shudu=600;
- break;
- while(1)
- switch (mod)
- case 0:
- if((shudu>0)&&(shudu<20))
- shudu+=2;
- else if((shudu>20)&&(shudu<100))
- shudu+=10;
- else if((shudu>100)&&(shudu<2000))
- shudu+=1000;
- if(shudu>2000)
- shudu=1;
- paoma1(shudu);
- break;
- case 1:
- //jiabian1(shudu);
- zondong2(3000);
- break;
- case 2:
- shudu+=200;
- if(shudu>2000)
- shudu=200;
- huxi(shudu);
- //zondong(shudu);
- break;
- case 3:
- shudu+=50;
- if(shudu>1000)
- shudu=50;
- shanshuo(shudu);
- break;
- /*case 8:
- send_dat(0);
- send_dat(255);
- send_dat(255);
- reset();
- //delay1(100);
- break;
- case 9:
- send_dat(255);
- send_dat(0);
- send_dat(255);
- reset();
- delay1(100);
- break;
- case 10:
- send_dat(255);
- send_dat(255);
- send_dat(255);
- reset();
- delay1(100);
- break;*/
PCB和视频下载:
PCB与视频.7z
(8.41 MB, 下载次数: 125)
