查看: 1359|回复: 0
基于51单片机LCD1602和数码管显示倒计时程序Proteus仿真图
使用8051单片机控制的倒计时器程序,通过连接LCD显示屏和数码管来实现倒计时功能
系统接1个按键用于启动,1个蜂鸣器用于提示计时时间到,两个数码管用于显示时间。
功能:系统上电数码管显示60;当按键按下时,系统开始倒计时,同时数码管显示当前时间;当计时为0时,蜂鸣器响。
  1. #include<reg52.h>
  2. sbit buzzer=P3^3;
  3. sbit key=P3^2;
  4. sbit m=P3^0;
  5. sbit n=P3^1;
  6. sbit RS=P3^4;
  7. sbit RW=P3^5;
  8. sbit E=P3^6;
  9. unsigned char a[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  10. unsigned char b[10]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
  11. unsigned char DJS=0;
  12. unsigned int count;
  13. unsigned char s = 60; // 倒计时初始值
  14. void delay(unsigned char t)
  15. {
  16.          unsigned char i,j;
  17.          for (i = 0; i < t; i++)
  18.     for (j = 0; j < 250; j++);
  19. }
  20. void writecommand(unsigned char command)
  21. {
  22.                                 RS=0;
  23.                                 RW=0;
  24.                                 P1=command;
  25.                                 delay(5);
  26.                                 E=1;
  27.                                 delay(5);
  28.                                 E=0;
  29. }
  30. void writecount(unsigned char count)
  31. {
  32.                                 RS=1;
  33.                                 RW=0;
  34.                                 P1=count;
  35.                                 delay(5);
  36.                                 E=1;
  37.                                 delay(5);
  38.                                 E=0;
  39. }
  40. void cursor(unsigned char H,m)
  41. {
  42.                         if(H==0)
  43.         {
  44.                                 writecommand(0x80+m);
  45.         }
  46.                         else if(H==1)
  47.         {
  48.                                 writecommand(0x80+0x40+m);
  49.         }
  50. }
  51. void LCDstring(unsigned char *string)
  52. {
  53.                                 while(*string!='\0')
  54.                                 writecount(*string++);
  55. }
  56. void LCDInit()
  57. {
  58.                                 E=0;
  59.                                 writecommand(0x38);
  60.                                 writecommand(0x0c);
  61.                                 writecommand(0x06);
  62.                                 writecommand(0x01);
  63. }
  64. //void on()
  65. //{
  66. //                                writecommand(0x0c);
  67. //}
  68. //void off()
  69. //{
  70. //                                writecommand(0x08);
  71. //}
  72. void ShowInit()
  73. {
  74.                                 cursor(0,0);
  75.                                 LCDstring("LCD");
  76.                                 cursor(0,5);
  77.                                 writecount(0x31);
  78.                                 cursor(0,6);
  79.                                 writecount(0x36);
  80.                                 cursor(0,7);
  81.                                 writecount(0x30);
  82.                                 cursor(0,8);
  83.                                 writecount(0x32);
  84.                                 cursor(0,10);
  85.                                 writecount(b[6]);
  86.                                 cursor(0,11);
  87.                                 writecount(b[0]);
  88.                                 cursor(1,0);
  89.                                 LCDstring("Test--Program--");
  90. }
  91. void display()
  92. {
  93.         if (DJS == 1)                                                //倒计时进行中
  94. {
  95.                         if (s> 0)
  96.                 {
  97.                                 cursor(0,10);
  98.                                 writecount(b[s/10]);    //显示定时器T0产生的 分(十位)
  99.                                 writecount(b[s%10]);    //显示定时器T0产生的 分(个位)
  100.                                 n = 0;                                         //开数码管1
  101.                                 m = 1;
  102.                                 P2 = a[s/10];                         //显示十位数字
  103.                                 delay(10);                      //延时10毫秒
  104.                                 m = 0;                          //开数码管2
  105.                                 n = 1;
  106.                                 P2 = a[s%10];                         //显示个位数字
  107.                                 delay(10);                             //延时10毫秒
  108.
  109.                 }
  110.                         else
  111.                 {
  112.                                 buzzer = 0;
  113.                                 delay(250);
  114.                                 buzzer = 1;
  115.                                 DJS = 0;                                 //倒计时结束,清零
  116.                                 cursor(0,10);
  117.                                 writecount(b[6]);            //LCD显示数字为6
  118.                                 writecount(b[0]);            //LCD显示数字为0
  119.                 }
  120. }
  121.                 else                                                         //倒计时为0,显示60秒
  122.         {
  123.                         n = 0;                                        //开数码管1
  124.                         m = 1;
  125.                         P2 = a[6];                                     //显示数字为6
  126.                         delay(20);                                    // 延时10毫秒
  127.                         m = 0;                                         //开数码管2
  128.                         n = 1;
  129.                         P2 = a[0];                                     // 显示数字为0
  130.                         delay(20);                                     // 延时10毫秒
  131.                         s= 60;                                       // 重置倒计时初始值
  132.
  133.         }
  134. }
  135. void main()
  136. {
  137.                 TMOD= 0x01;
  138.                 TL0 = (65536 - 1000)%256;
  139.                 TH0 = (65536 - 1000)/256;
  140.                 EA = 1;
  141.                 ET0 = 1;
  142.                 TR0 = 1;
  143.                 EX0=1;
  144.                 IT0=1;
  145.                 LCDInit();
  146.                 ShowInit();
  147.                 while(1)
  148. {
  149.                 display();
  150. }
  151. }
  152. void Int0() interrupt 0
  153. {
  154.                 delay(10);
  155.                 if(key==0)
  156. {
  157.                 DJS=1;
  158. }
  159. }
  160. void Int1() interrupt 1
  161. {
  162.                 TL0 = (65536-1000)%256;
  163.                 TH0 = (65536-1000)/256;
  164.                 count++;
  165.                 if(count == 500)
  166. {
  167.         count = 0;
  168.         s--;
  169. }
  170. }
Keil代码与Proteus仿真下载:
LCD1602.zip (31.88 KB, 下载次数: 23)
