STM32F407的6路串口接收发送DMA 例程
单片机源程序如下:- /*
- 该工程为寄存器版本,不过在库函数中仍可添加使用
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "dma.h"
- #include "malloc.h"
- u8 TestData[10] = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0A};
- int main(void)
- Stm32_Clock_Init(336,8,2,7);//设置时钟,168Mhz
- delay_init(168); //延时初始化
- Init_USART1(84,115200); //初始化串口波特率为115200
- Init_USART2(42,115200);
- Init_USART3(42,115200);
- Init_UART4(42,115200);
- Init_UART5(42,115200);
- Init_USART6(84,115200);
- my_mem_init(SRAMIN); //初始化内部内存池
- my_mem_init(SRAMCCM); //初始化内部CCM内存池
- //USART1发送 --- DMA2,数据流7,CH4---USART1_TXD 外设为串口1,存储器为USART1_TX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA2_Stream7,4,(u32)&USART1->DR,(u32)USART1_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
- //USART1接收 --- DMA2,数据流5,CH4---USART1_RXD 外设为串口1,存储器为USART1_RX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA2_Stream5,4,(u32)&USART1->DR,(u32)USART1_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
- MYDMA_Enable(DMA2_Stream5,(u32)USART1_RX_BUF,USART_LEN);//开始一次DMA传输!
- //USART2发送 --- DMA1,数据流6,CH4---USART2_TXD 外设为串口2,存储器为USART2_TX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA1_Stream6,4,(u32)&USART2->DR,(u32)USART2_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
- //USART2接收 --- DMA1,数据流5,CH4---USART2_RXD 外设为串口2,存储器为USART2_RX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA1_Stream5,4,(u32)&USART2->DR,(u32)USART2_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
- MYDMA_Enable(DMA1_Stream5,(u32)USART2_RX_BUF,USART_LEN);
- //USART3发送 --- DMA1,数据流3,CH4---USART3_TXD 外设为串口3,存储器为USART3_TX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA1_Stream3,4,(u32)&USART3->DR,(u32)USART3_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
- //USART3接收 --- DMA1,数据流1,CH4---USART3_RXD 外设为串口3,存储器为USART3_RX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA1_Stream1,4,(u32)&USART3->DR,(u32)USART3_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
- MYDMA_Enable(DMA1_Stream1,(u32)USART3_RX_BUF,USART_LEN);
- //USART4发送 --- DMA1,数据流4,CH4---USART4_TXD 外设为串口4,存储器为USART4_TX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA1_Stream4,4,(u32)&UART4->DR,(u32)UART4_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
- //USART4接收 --- DMA1,数据流2,CH4---USART4_RXD 外设为串口4,存储器为USART4_RX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA1_Stream2,4,(u32)&UART4->DR,(u32)UART4_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
- MYDMA_Enable(DMA1_Stream2,(u32)UART4_RX_BUF,USART_LEN);
- //USART5发送 --- DMA1,数据流7,CH4---UART5_TXD 外设为串口5,存储器为UART5_TX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA1_Stream7,4,(u32)&UART5->DR,(u32)UART5_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
- //USART5接收 --- DMA1,数据流0,CH4---UART5_RXD 外设为串口5,存储器为UART5_RX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA1_Stream0,4,(u32)&UART5->DR,(u32)UART5_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
- MYDMA_Enable(DMA1_Stream0,(u32)UART5_RX_BUF,USART_LEN);
- //USART6发送 --- DMA2,数据流6,CH5---USART6_TXD 外设为串口6,存储器为USART6_TX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA2_Stream6,5,(u32)&USART6->DR,(u32)USART6_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
- //USART6接收 --- DMA2,数据流1,CH5---USART6_RXD 外设为串口6,存储器为USART6_RX_BUF,长度为:USART_LEN
- MYDMA_Config(DMA2_Stream1,5,(u32)&USART6->DR,(u32)USART6_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
- MYDMA_Enable(DMA2_Stream1,(u32)USART6_RX_BUF,USART_LEN);
- while(1)
- // myDMAprintf(USART1,"usart = %d\tch = %f\r\n",1,1.567);
- // myDMAprintf(USART2,"usart = %d\tch = %f\r\n",2,1.567);
- myDMAprintf(USART3,"usart = %d\tch = %f\r\n",3,1.567);
- // myDMAprintf(UART4,"usart = %d\tch = %f\r\n",4,1.567);
- // myDMAprintf(UART5,"usart = %d\tch = %f\r\n",5,1.567);
- myDMAprintf(USART6,"usart = %d\tch = %f\r\n",6,1.567);
- // myDMAarray(USART1,(u32)TestData,10);
- // myDMAarray(USART2,(u32)TestData,10);
- // myDMAarray(USART3,(u32)TestData,10);
- // myDMAarray(UART4,(u32)TestData,10);
- // myDMAarray(UART5,(u32)TestData,10);
- // myDMAarray(USART6,(u32)TestData,10);
- delay_ms(1000);
原理图: 无
仿真: 无
代码:
DMA发送&接收.7z
(87.28 KB, 下载次数: 41)
