- #include "./sys/sys.h"
- #include "./delay/delay.h"
- #include "./usart/usart.h"
- #include "./LED/led.h"
- #include "./LCD/lcd.h"
- #include "./KEY/key.h"
- #include "./RTC/rtc.h"
- //#include "./RTC/bsp_rtc.h"
- #include "./BEEP/beep.h"
- #include "usmart.h"
- #include "malloc.h"
- #include "./SDIO/sdio_sdcard.h"
- #include "./W25QXX/w25qxx.h"
- #include "./src/ff.h"
- #include "./exfuns/exfuns.h"
- #include "text.h"
- #include "piclib.h"
- #include "./TOUCH/touch.h"
- #include "./USART2/usart2.h"
- #include "./USART3/usart3.h"
- #include "./MPU6050/mpu6050.h"
- #include "sim800c.h"
- #include "./gps.h"
- #include "./OV7670/ov7670.h"
- #include "./NRF24L01/24l01.h"
- #include "./TIMER/timer.h"
- //#include "./OV7670/sccb.h"
- #include "./OV2640/ov2640.h"
- #include "MQTTPacket.h"
- #include "StackTrace.h"
- #include "inv_mpu.h"
- #include "inv_mpu_dmp_motion_driver.h"
- #include "./T9INPUT/t9input.h"
- #include "stdarg.h"
- #include <string.h>
- #include <stdio.h>
- #include <stdlib.h>
- /* 私有变量 ------------------------------------------------------------------*/
- FATFS mfs; /* FatFs文件系统对象 */
- FIL mfile; /* 文件对象 */
- FRESULT mf_res; /* 文件操作结果 */
- char mfpath[] = "0:TEXT"; /* 保存当前扫描路径 */
- BYTE WriteBuffer[100] = "欢迎使用智能终端\r\n";
- UINT file_num;
- nmea_msg gpsx; //GPS信息
- const u8 *port = (u8 *)"1883"; //端口固定为1883
- const u8 *ipaddr = (u8 *)"118.190.146.251";
- typedef struct
- float temp[3];
- float humi[3];
- float gps[3];
- uint8_t door[4];
- short mpu[6];
- }menu_message,*menu_message_;
- uint16_t screen_w = 800; //屏幕宽度
- uint16_t screen_h = 480; //屏幕高度
- uint8_t line_w = 3; //分界线宽
- uint8_t menu_num = 4; //菜单组数
- uint8_t cur_menu_item,old_menu_item; //当前菜单
- uint8_t tmp_buf[33]; //NRF缓存
- u8 mqtt_msg[200]={0}; //MQTT消息包缓存
- u16 len; //消息包有效长度
- u8 gprs_tcp_flag; //TCP连接标志
- u8 mqtt_data_flag; //MQTT消息类型标志
- u8 send_data_flag; //发布消息标志
- u8 temp_data[] = "##################------000000000000"; //36字节 MQTT消息内容缓存
- u8 message_type; //消息类型,区别TOPIC主题
- u8 about_text_size = 24; //关于字体大小
- u8* const Info_Show[13]=
- "温度1","温度2","温度3",
- "湿度1","湿度2","湿度3",
- "GPS经度","GPS纬度",
- "车门信息","陀螺仪状态",
- "服务器IP","蓝牙地址","阈值设置"
- menu_message menu_mess;
- //_t9_obj * t9in; //输入法
- //私有函数声明
- void sim800c_init(void); //SIM800C初始化
- void gprs_send_data(u8 * data,u8 lenth); //GPRS发送数据
- u8 *my_strstr(const u8 *s1,u16 n1,const u8 *s2,u16 n2); //字符串查找
- void Start_Gprs_TCP(void); //GPRS建立TCP连接
- void Stop_Gprs_Connect(void); //关闭GPRS连接
- void Gps_Msg_Show(void); //显示GPS定位信息
- void send_model_temp_humi(menu_message * mes,u8 * space,u8 type); //MQTT发送内容包装
- int main(void)
- int sys_run_times=0;
- unsigned char valtest=0;
- u8 key,fontok=0;
- u8 *p1,*p2,*p3;
- u8 hbeaterrcnt=0; //心跳错误计数器,连续5次心跳信号无应答,则重新连接
- // t9in = 0;
- gprs_tcp_flag = 0;
- mqtt_data_flag = 0;
- send_data_flag = 0;
- message_type = 0;
- delay_init(); //延时函数初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
- uart_init(115200); //串口初始化为115200
- usmart_dev.init(72); //初始化USMART
- GENERAL_TIMx_Configuration(); //通用定时器初始化:1ms中断一次
- LED_Init(); //初始化与LED连接的硬件接口
- KEY_Init(); //初始化按键
- LCD_Init(); //初始化LCD
- BEEP_Init(); //蜂鸣器初始化
- W25QXX_Init(); //初始化W25Q128
- tp_dev.init(); //初始化触摸屏
- usart3_init(115200); //初始化串口3
- my_mem_init(SRAMIN); //初始化内部内存池
- exfuns_init(); //为fatfs相关变量申请内存
- f_mount(fs[0],"0:",1); //挂载SD卡
- f_mount(fs[1],"1:",1); //挂载FLASH.
- key=KEY_Scan(0);
- if(key==KEY0_PRES&&((tp_dev.touchtype&0X80)==0))//强制校准
- LCD_Clear(WHITE); //清屏0
- TP_Adjust(); //屏幕校准
- TP_Save_Adjdata();
- fontok=font_init(); //检查字库是否OK
- if(fontok||key==KEY1_PRES) //需要更新字库
- POINT_COLOR=RED; //设置字体为红色
- LCD_ShowString(60,50,200,16,16,(u8 *)"ALIENTEK STM32");
- while(SD_Init()) //检测SD卡
- LCD_ShowString(60,70,200,16,16,(u8 *)"SD Card Failed!");
- delay_ms(200);
- LCD_Fill(60,70,200+60,70+16,WHITE);
- delay_ms(200);
- LCD_ShowString(60,70,200,16,16,(u8 *)"SD Card OK");
- LCD_ShowString(60,90,200,16,16,(u8 *)"Font Updating...");
- key=update_font(20,110,16,(u8 *)"0:"); //从SD卡更新
- while(key) //更新失败
- LCD_ShowString(60,110,200,16,16,(u8 *)"Font Update Failed!");
- delay_ms(200);
- LCD_Fill(20,110,200+20,110+16,WHITE);
- delay_ms(200);
- LCD_ShowString(60,110,200,16,16,(u8 *)"Font Update Success!");
- delay_ms(1500);
- //RTC_CheckAndConfig(&systmtime);
- RTC_Init(); //RTC初始化
- delay_ms(1000);
- RTC_Get();
- printf("time:%02d-%02d-%02d.%02d:%02d:%02d\r\n",calendar.w_year%100,calendar.w_month,calendar.w_date,calendar.hour,calendar.min,calendar.sec);
- init_gps();
- NRF24L01_Init();
- while(NRF24L01_Check()){;}
- NRF24L01_RX_Mode();
- LCD_Clear(BLACK);
- key = 0;
- piclib_init(); //初始化画图
- //I2C初始化
- i2c_CfgGpio();
- //MPU6050初始化
- MPU6050_Init();
- //检测MPU6050
- // while(!MPU6050ReadID()){;}
- while(sim800c_send_cmd((u8 *)"AT",(u8 *)"OK",100))//检测是否应答AT指令
- Show_Str(40,55,200,16,(u8 *)"未检测到模块!!!",16,0);
- delay_ms(800);
- Show_Str(40,55,200,16,(u8 *)"尝试连接模块...",16,0);
- delay_ms(400);
- printf("SIM800C Check OK\r\n");
- p1=mymalloc(SRAMIN,100); //申请100字节内存
- while(1)
- if(NRF24L01_RxPacket(tmp_buf)==0)
- printf("NRF24L01:%s\r\n",(char *)tmp_buf);
- switch(tmp_buf[17])
- case '0'://终端1
- menu_mess.temp[0] = tmp_buf[19] == '+' ? ((tmp_buf[20] - '0') * 10 + (tmp_buf[21] - '0') * 1 + (tmp_buf[23] - '0') * 0.1 + (tmp_buf[24] - '0') * 0.01) : \
- -((tmp_buf[20] - '0') * 10 + (tmp_buf[21] - '0') * 1 + (tmp_buf[23] - '0') * 0.1 + (tmp_buf[24] - '0') * 0.01);
- if(tmp_buf[27] != '#')
- menu_mess.humi[0] = (tmp_buf[27] - '0') * 10 + (tmp_buf[28] - '0') * 1;
- break;
- case '1'://终端2
- menu_mess.temp[1] = tmp_buf[19] == '+' ? ((tmp_buf[20] - '0') * 10 + (tmp_buf[21] - '0') * 1 + (tmp_buf[23] - '0') * 0.1 + (tmp_buf[24] - '0') * 0.01) : \
- menu_mess.humi[1] = (tmp_buf[27] - '0') * 10 + (tmp_buf[28] - '0') * 1;
- break;
- case '2'://终端3
- menu_mess.temp[2] = tmp_buf[19] == '+' ? ((tmp_buf[20] - '0') * 10 + (tmp_buf[21] - '0') * 1 + (tmp_buf[23] - '0') * 0.1 + (tmp_buf[24] - '0') * 0.01) : \
- menu_mess.humi[2] = (tmp_buf[27] - '0') * 10 + (tmp_buf[28] - '0') * 1;
- break;
- case '3'://终端4
- menu_mess.door[0] = tmp_buf[19] == 0x17 ? 0x11 : 0x10;
- break;
- default :
- break;
- sys_run_times++;
- if(gprs_tcp_flag == 17)
- //构建MQTT连接
- switch(mqtt_data_flag)
- case 0:
- sim800c_send_cmd("AT+CIPSTATUS","OK",500); //查询连接状态
- if(strstr((const char*)USART3_RX_BUF,"CONNECT OK"))
- len=mqtt_connect_message(mqtt_msg,"STM32","admin","public");//id=123456,用户名和密码为空
- gprs_send_data((u8 *)mqtt_msg,len);
- delay_ms(600);
- len=mqtt_subscribe_message(mqtt_msg,"home/temp",1,1); //订阅test主题
- printf("MQTT Connect and subscribe OK\r\n");
- mqtt_data_flag = 1;
- break;
- case 1:
- if(17 == send_data_flag)
- MQTTString topicString = MQTTString_initializer;
- RTC_Get();
- send_model_temp_humi(&menu_mess,(u8 *)temp_data,message_type);
- temp_data[24] = calendar.w_year%100/10+'0';
- temp_data[25] = calendar.w_year%10+'0';
- temp_data[26] = calendar.w_month%100/10+'0';
- temp_data[27] = calendar.w_month%10+'0';
- temp_data[28] = calendar.w_date%100/10+'0';
- temp_data[29] = calendar.w_date%10+'0';
- temp_data[30] = calendar.hour%100/10+'0';
- temp_data[31] = calendar.hour%10+'0';
- temp_data[32] = calendar.min%100/10+'0';
- temp_data[33] = calendar.min%10+'0';
- temp_data[34] = calendar.sec%100/10+'0';
- temp_data[35] = calendar.sec%10+'0';
- printf("数据发送中...\r\n"); //提示数据发送中
- if(0 == message_type)
- topicString.cstring = "L180309001/YY0118050001/Temp"; //发送的主题
- else if(1 == message_type)
- topicString.cstring = "L180309001/YY0118050001/EGps";
- else if(2 == message_type)
- topicString.cstring = "L180309001/YY0118050001/Gyro";
- else if(3 == message_type)
- topicString.cstring = "L180309001/YY0118050001/Door";
- else if(4 == message_type)
- topicString.cstring = "L180309001/YY0118050001/Point";
- message_type++;
- if(message_type>=5)
- message_type = 0;
- len = MQTTSerialize_publish(mqtt_msg, 200, 0, 0, 0, 0, topicString, (u8 *)temp_data, strlen((const char *)temp_data)); /* 2 */
- printf("MQTT Send data OK\r\n");
- send_data_flag = 0;GPIOB -> ODR ^= GPIO_Pin_5;
- break;
- if(USART3_RX_STA&0X8000) //接收到一次数据了
- USART3_RX_BUF[USART3_RX_STA&0X7FFF]=0; //添加结束符
- printf("%s",USART3_RX_BUF); //发送到串口
- if(hbeaterrcnt) //需要检测心跳应答
- if(strstr((const char*)USART3_RX_BUF,"SEND OK"))hbeaterrcnt=0;//心跳正常
- p2=(u8*)strstr((const char*)USART3_RX_BUF,"+IPD");
- if(p2) //接收到TCP/UDP数据
- p3=(u8*)strstr((const char*)p2,",");
- p2=(u8*)strstr((const char*)p2,":");
- p2[0]=0; //加入结束符
- sprintf((char*)p1,"收到%s字节",p3+1); //接收到的字节数
- printf("%s\r\n",(char*)p1);
- USART3_RX_STA=0;
- else
- Start_Gprs_TCP(); //创建TCP连接
- if(17 == (sys_run_times%100))
- menu_mess.gps[0] = (float)(gpsx.longitude/100000);
- menu_mess.gps[1] = (float)(gpsx.latitude/100000);
- menu_mess.gps[2] = (float)(gpsx.speed/1000);
- send_data_flag = 17;
- printf("Send flag OK\r\n");
- hbeaterrcnt++;
- printf("hbeaterrcnt:%d\r\n",hbeaterrcnt); //方便调试代码
- else if(27 == (sys_run_times%5000))
- len = mqtt_ping_message(mqtt_msg); /* 2 */
- printf("heart Send OK\r\n");
- switch(KEY_Scan(0))
- case KEY0_PRES:
- f_close(&mfile);
- while(1)
- printf("System Stop\r\n");
- delay_ms(1000);
- break;
- default:
- break;
- delay_ms(6);
- // printf("Sys_Time:%d \r\n",sys_run_times);
- while(1)
- printf("Error\r\n");
- delay_ms(500);
- u8 *p1,p2[100];
- u8 res=0;
- p1=mymalloc(SRAMIN,100); //申请50个字节的内存
- sim800c_send_cmd((u8 *)"ATE0",(u8 *)"OK",200); //不回显
- USART3_RX_STA=0;
- sim800c_send_cmd("AT+SAPBR=3,1,\"Contype\",\"GPRS\"","OK",200); //配置承载场景1
- sim800c_send_cmd("AT+SAPBR=3,1,\"APN\",\"CMNET\"","OK",200);
- sim800c_send_cmd("AT+SAPBR=1,1",0,200); //激活一个GPRS上下文
- delay_ms(5);
- sim800c_send_cmd("AT+CNTPCID=1","OK",200); //设置CNTP使用的CID
- sim800c_send_cmd("AT+CNTP=\"202.120.2.101\",32","OK",200); //设置NTP服务器和本地时区(32时区 时间最准确)
- sim800c_send_cmd("AT+CNTP","+CNTP: 1",600); //同步网络时间
- USART3_RX_STA=0;
- if(sim800c_send_cmd("AT+CPIN?","OK",200))res|=1<<0; //查询SIM卡是否在位
- USART3_RX_STA=0;
- if(0 == res)
- sim800c_send_cmd("AT+CIPCLOSE=1","CLOSE OK",100); //关闭连接
- sim800c_send_cmd("AT+CIPSHUT","SHUT OK",100); //关闭移动场景
- if(sim800c_send_cmd("AT+CGCLASS=\"B\"","OK",1000)) printf("SIM800C Init1 FAIL\r\n"); //设置GPRS移动台类别为B,支持包交换和数据交换
- if(sim800c_send_cmd("AT+CGDCONT=1,\"IP\",\"CMNET\"","OK",1000)) printf("SIM800C Init2 FAIL\r\n"); //设置PDP上下文,互联网接协议,接入点等信息
- if(sim800c_send_cmd("AT+CGATT=1","OK",500)) printf("SIM800C Init3 FAIL\r\n"); //附着GPRS业务
- if(sim800c_send_cmd("AT+CIPCSGP=1,\"CMNET\"","OK",500)) printf("SIM800C Init4 FAIL\r\n"); //设置为GPRS连接模式
- if(sim800c_send_cmd("AT+CIPHEAD=1","OK",500)) printf("SIM800C Init5 FAIL\r\n"); //设置接收数据显示IP头(方便判断数据来源)
- printf("SIM800C Start OK\r\n");
- USART3_RX_STA=0;
- sprintf((char*)p2,"AT+CIPSTART=\"%s\",\"%s\",\"%s\"","TCP",ipaddr,port);
- if(0==sim800c_send_cmd(p2,"OK",500)) //发起连接
- delay_ms(1500);delay_ms(1000);
- USART3_RX_STA = 0;
- gprs_tcp_flag = 17;
- printf("SIM800C TCP Connect OK\r\n");
- else
- printf("SIM800C TCP Connect Fail\r\n");
- myfree(SRAMIN,p2);
- long val;
- u8 t;
- //if(strlen(space)<36)return;
- switch(type)
- case 0: //温湿度+RTC
- for(t = 0;t < 3;t ++)
- val = (int)(mes->temp[t] * 100);
- if(val<0)
- space[t * 6] = '-';
- else
- space[t * 6] = '+';
- val = val >= 0 ? val : -val;
- space[t * 6 + 1] = val % 10000 /1000 + '0';
- space[t * 6 + 2] = val % 1000 /100 + '0';
- space[t * 6 + 3] = '.';
- space[t * 6 + 4] = val % 100 /10 + '0';
- space[t * 6 + 5] = val % 10 /1 + '0';
- val = (int)(mes->humi[t]);
- space[18 + t * 2] = val % 100 / 10 + '0';
- space[18 + t * 2 + 1] = val % 10 / 1 + '0';
- printf("Temp_Data:%s\r\n",(u8 *)space);
- break;
- case 1: //GPS+RTC
- for(t = 0;t < 2;t ++)
- val = (long)(mes->gps[t] * 100000);
- if(val<0)
- space[t * 10] = '-';
- else
- space[t * 10] = '+';
- space[t * 10 + 1] = val % 100000000 /10000000 + '0';
- space[t * 10 + 2] = val % 10000000 /1000000 + '0';
- space[t * 10 + 3] = val % 1000000 /100000 + '0';
- space[t * 10 + 5] = val % 100000 /10000 + '0';
- space[t * 10 + 6] = val % 10000 /1000 + '0';
- space[t * 10 + 7] = val % 1000 /100 + '0';
- space[t * 10 + 8] = val % 100 /10 + '0';
- space[t * 10 + 9] = val % 10 /1 + '0';
- space[t * 10 + 4] = '.';
- val = (int)(mes->gps[2] * 10);
- space[20] = val % 10000 / 1000 + '0';
- space[21] = val % 1000 / 100 + '0';
- space[22] = val % 100 / 10 + '0';
- space[23] = val % 10 / 1 + '0';
- printf("Gps_Data:%s\r\n",(u8 *)space);
- break;
- case 2: //陀螺仪+RTC
- MPU6050ReadAcc((short *)(mes->mpu));
- space[t * 2] = ((mes -> mpu[t]) >> 8) & 0xFF;
- space[t * 2 + 1] = (mes -> mpu[t]) & 0xFF;
- MPU6050ReadGyro((short *)(mes->mpu));
- space[6 + t * 2] = ((mes -> mpu[t]) >> 8) & 0xFF;
- space[6 + t * 2 + 1] = (mes -> mpu[t]) & 0xFF;
- for(t = 12;t < 24;t ++)
- space[t] = '#';
- printf("Gyro_Data:%s\r\n",(u8 *)space);
- break;
- case 3: //开关门+RTC
- space[0] = mes->door[0] + '0';
- for(t = 1;t < 24;t ++)
- space[t] = '#';
- printf("Door_Data:%s\r\n",(u8 *)space);
- break;
- case 4: //点熄火+RTC
- space[0] = mes->door[1] + '0';
- space[t] = '#';
- printf("Point_Data:%s\r\n",(u8 *)space);
- break;
- default :
- break;
- //在str1字符串中找出str2字符串(不包括str2的串结束符,忽略str中的\0)
- //返回该位置的指针,如找不到,返回空指针
- int n,x=0,y=0;
- if (*s2)
- while(1)
- if(*s1==*s2)//找到s2第一次出现,两种情况考虑
- for (n=0;n<n2;n++)
- if (*(s1+n)==*(s2+n))
- y++;
- if (y>=n2)
- //if (!*(s2+n+1)) //s2下一个字符是否为'\0'
- return (u8 *)s1;
- if (x+n>=n1-1) //防止数组越界
- return NULL;
- if (*(s1+n+1)!=*(s2+n+1))//查找的下一个字符不相等,一个字符相等
- break;
- else
- break;
- s1++;
- x++;
- if(x>=n1)
- break;
- return NULL;
- else
- return (u8*)s1;
- void gprs_send_data(u8 *data,u8 lenth)
- if(sim800c_send_cmd("AT+CIPSEND",">",500)==0) //发送数据
- //u3_printf("%s",(u8 *)data);
- my_u3_send((char *)mqtt_msg,lenth);
- delay_ms(10);
- if(sim800c_send_cmd((u8*)0X1A,"SEND OK",5000)==0)
- printf("GPRS数据发送成功!\r\n");//最长等待10s
- else
- sim800c_send_cmd((u8*)0X1B,0,0); //ESC,取消发送
原理图: 无
仿真: 无
代码:
GPRS MQTT STM32.7z
(1.56 MB, 下载次数: 30)
