查看: 426|回复: 1
m8单片机串口通讯程序
ID:1104531 发表于 2024-1-11 21:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
个人认为,AVR系列的串口使用还是比较容易出错,如果采用传统的查询方式太耗系统时间,而且现在关于AVR的教材大多给你的是查询发送方式,中断接收方式。
本例子是采用中断接收,中断发送方式。希望对大家有所帮助。
//ICC-AVR
// Target : M8
// Crystal: 4.0000Mhz
#include <iom8v.h>
#include <macros.h>
#define DISABLE_UARTTX()        UCSRB&=~BIT(TXCIE)
#define ABLE_UARTTX()                UCSRA|=BIT(TXC);UCSRB|=BIT(TXCIE)
unsigned char ucRecv;
unsigned char ucRecvOk;
unsigned char ucSendData[8]="Recv OK!";
unsigned char ucComSendCnt,ucComSendPtr;
void InitPort(void)
         PORTB = 0xFF;
         DDRB  = 0x00;
         PORTC = 0x7F; //m103 output only
         DDRC  = 0x00;
         PORTD = 0xFE;
         DDRD  = 0x02;
//UART0 initialize
// desired baud rate: 2400
// actual: baud rate:2404 (0.2%)
void InitUart0(void)
         UCSRB = 0x00; //disable while setting baud rate
         UCSRA = 0x00;
         UCSRC = BIT(URSEL) | 0x06;
         UBRRL = 0x67; //set baud rate lo
         UBRRH = 0x00; //set baud rate hi
         UCSRB = 0x98;
#pragma interrupt_handler uart0_rx_isr:iv_USART0_RXC
void uart0_rx_isr(void)
        unsigned char ucTmp;
//uart has received a character in UDR
        ucTmp=UDR;
        if (ucTmp=='A')
                ucRecv=ucTmp;
                ucRecvOk=0x01;
#pragma interrupt_handler uart0_tx_isr:iv_USART0_TXC
void uart0_tx_isr(void)
//character has been transmitted
         if (ucComSendCnt!=0)
                 ucComSendPtr+=1;
                 UDR=ucSendData[ucComSendPtr];
                ucComSendCnt-=1;
        }else
                //PORTB&=~BIT(PB_COM_LED);                                        //串口指示灯灭
                DISABLE_UARTTX();
                //PORTB^=BIT(PB_COM_LED);                                        //串口指示灯灭
//call this routine to initialize all peripherals
void InitMcu(void)
//stop errant interrupts until set up
         CLI();                         //disable all interrupts
         InitPort();
         InitUart0();
         MCUCR = 0x00;
         GICR  = 0x00;
         TIMSK = 0x00;         //timer interrupt sources
         SEI();                         //re-enable interrupts
                                         //all peripherals are now initialized
void main(void)
        unsigned char i;
        InitMcu();
                if (ucRecvOk==0x01)
                        CLI();
                        ucRecvOk=0;
                        SEI();
                        ucComSendCnt=7;
                        ucComSendPtr=0;
                        ABLE_UARTTX();
                        UDR=ucSendData[0];
m8 串口通讯.zip
44.24 KB, 下载次数: 4, 下载积分: 黑币 -5
收藏收藏1 分享淘帖 顶 踩
ID:229502 发表于 2024-2-11 21:18 | 只看该作者
楼主能否有个注解,对初学者更友好
